MHB Distance between point and line
  • Thread starter Thread starter Yankel
    Line Point
To find the equation of the line through the origin that maintains a specific distance from points A(2,1) and B(1,4), the sum of the distances must equal \(\sqrt{8}\). The distance formula used is \[d=\frac{\left | Ax+By+C \right |}{\sqrt{A^{2}+B^{2}}}\], leading to the equation \[\frac{-2A-B}{\sqrt{A^{2}+B^{2}}}+\frac{A+4B}{\sqrt{A^{2}+B^{2}}}=\sqrt{8}\]. By recognizing that the line passes through the origin, the constant C is set to 0, simplifying the equation to involve only one variable, A. This approach allows for the determination of the line's slope as \(-A\).
Yankel
Hello all,
I need your assistance with the following:
Find the equation of the line that goes through the origin (0,0) if it is known that the sum of distances of the line from A(2,1) and B(1,4) is equal to \[\sqrt{8}\], and it is also known that the line is between the points.
The formula I am supposed to use is:
What I did, is I set the equation to be:
\[\frac{-2A-B-C}{\sqrt{A^{2}+B^{2}}}+\frac{A+4B+C}{\sqrt{A^{2}+B^{2}}}=\sqrt{8}\]
The absolute value was omitted since the line is between the points, i.e. one point is below and one above.
I am stuck with 1 equation and 2 variables. How do I proceed ? Since the point (0,0) is on the line, I know that C is 0 in the equation Ax+By+C=0, but this parameter is not important anyway (C-C=0).
Thank you !
Mathematics news on Phys.org
The family of lines passing through the origin may be written:
$$Ax+y=0$$
where the slope is $-A$. Now you will have only 1 variable in your equation. ;)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
