MHB Distance between points in a triangle
  • Thread starter Thread starter Yankel
    Points Triangle
In an equilateral triangle with a side length of 2, placing five points inside ensures that at least two points are within 1 unit of each other, as demonstrated by the pigeonhole principle. By dividing the triangle into four smaller equilateral triangles, at least one of these smaller triangles must contain at least two points. The maximum distance between any two points within one of these smaller triangles is 1 unit, as shown by geometric reasoning involving arcs. Concerns about points lying on the edges of the smaller triangles do not disprove the theory, as the maximum distance still holds true. The discussion highlights the application of geometric principles and the pigeonhole principle in proving point proximity within a triangle.
Yankel
Hello all,
Below there is a problem:
There are five points inside an equilateral triangle of side length 2. Show that at least two of the points are within 1 unit distance from each other.
I have plotted such a triangle using "Geogebra", and attaching the picture.
I know that if I create another equilateral triangle within the original one, I get four triangles. Then, according to the pigeonhole principle, with 5 points (pigeons) and 4 triangle (holes), at least two points will be in the same triangle.
My questions are:
1) What is the geometrical reasoning for claiming that two points within a triangle will have a distance of 1 units max ? I couldn't prove it.
2) What happens if a point in the bigger triangle happens to be on the edge of the inner black triangle? Doesn't it disproof the theory ?
Thank you in advance !
Mathematics news on Phys.org
Yankel said:
Hello all,
My questions are:
Suppose there are 2 points in the triange CDE.
the largest distance between any 2 points in CDE (The points in the edges included) is 1.
to prove the same draw an arc with centre C and distance 1
DE line segment shall be in the arc and any poins in DE shall be < 1 (unless end point D or E for which distance = 1)
so maximum distance is 1
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
