Distance of a ball in a circle
In summary: A and B respectively. If so, the error is evident.In summary, the conversation discusses a problem involving a ball attached to a rope that is fixed at one end and given an initial downward velocity. The ball moves through three quarters of a circle and arrives at a point where the rope is barely under tension. The problem involves calculating the initial velocity and potential energy of the ball at different points in the circle. There is some confusion about the use of distance in the potential energy equation, but it is determined that the equations used by the poster are incorrect and need to be adjusted to account for the distance from the center of the circle to the particle. The final outcome of the problem is unclear due to missing information.
duplaimp
33
In the figure on the right, a 4.0 kg ball is attached to the end of a 1.6 m rope, which is fixed at O.
The ball is held at A, with the rope horizontal, and is given an initial downward velocity. The ball moves through three quarters of a circle and arrives at B, with the rope barely under tension.
K1 + U1 = K2 + U2
I tried with the following:
R = 1.6m
m = 4kg
K1 = [itex]\frac{1}{2}[/itex]m[itex]v_{a}^{2}[/itex]
U1 = mgR
K2 = [itex]\frac{1}{2}[/itex]m[itex]v_{b}^{2}[/itex]
U2 = mgR
But in a solution I found it was used U2 = mg2R
Why it was used 2R and not R? The distance to use in a circle is from the center to the particle or is from the bottom to the particle?
Because as A is in a distance R from center and B too, I tried with R for both but it seems that it needs to be done using a distance from bottom
That U equation is for Potential energy. The equation is mass x g x distance. The distance you would use isn't too important. U1 and U2 just have to be measured from the same spot so that the change in potential energy would be mgR.
Ok, so from center A will be -R and B will be R?
Sorry I guess i wasn't too clear. Its the height that you would be measuring so if you did use the center you would just need to look at how high each point is from the center.
If it were R, how fast would the ball be traveling at the top of the circle?
K1 + U1 = K2 + U2
R = 1.6m
m = 4kg
U1 = mgR
U2 = mgR
I keep reading the problem, and don't find a question? Are you trying to calculate vo perhaps?
Forget that - I misinterpreted your equations.
You have U = mgR at A. How could it also be mgR at B, given that B is height R above A?
Assuming the question is, 'what is the initial imparted velocity', use energy conservation. Note that the tension on the rope imparts force to the mass but since it's always orthogonal to the directin of motion, that force does no work.
So, simply, initial kinetic energy = change in potential energy.
When the ball arrives at B the tension in the rope becomes zero. This does not necessarily mean that the ball has come to rest.
It is not 100% clear what the question is asking but, in my experience of questions of this sort, I would say the ball completes a circle.
If that is the case then the ball has KE at point B, as well as PE.
I think you've made the same presumption I made in my first post on this thread, that the poster has made the usual mistake of forgetting about centripetal acceleration. But the question posed concerns the potential energy at B. duplaimp appears to have measured the PE at A relative to the bottom of the loop but that at B relative to A.
Haruspex: I agree, some information missing. My inclination is that it would be a mistake to assume that the ball comes to rest at B.
This is the problem with the Original Post! There is no question posed !
It doesn't say what question the poster was trying to answer, but it does pose this question from the poster:
duplaimp said:
U1 = mgR
U2 = mgR
Not wonderfully clear, I agree, but I think there's enough circumstantial evidence to interpret U1 and U2 as representing the PEs at A and B respectively. If so, the error is evident.
Understood. Seems OP was unaware that the standard formula U = mgh had had the h value replaced by "the height above lowest point" value - R and 2R respectively.
Let
vi = initial velocity at A
vf = final velocity at B
EDIT:
Technician is right, the velocity at B is not zero. Matter of fact, it's v = vf = sqrt(gR). That result should be obvious: at the top, the centripetal force still has to be mv^2/R and that has to be equal to mg + T, but T(B) = 0.
So we have the complete picture: 1/2 mvi^2 = 1/2 mvf^2 + mgR. With vf known, vi is immediately determined.
There is no information missing.
rude man said:
Let
I think electrician is right, the velocity at B is not zero. Matter of fact, it's v = vf = sqrt(gR). That result should be obvious: at the top, the centripetal force still has to be mv^2/R and that has to be equal to mg + T, but T(B) = 0.
Good work, electrician.
It is not clear that OP had any difficulty coping with the centripetal acceleration etc - he just wondered why U was mgR in one position and mg2R in the other. Presumably he had forgotten that the R and 2R referred to the height above a reference point, not the distance from the centre.
So it's agreed there is no "missing information"?
The only possible questions are what are the initial & final velocities & I have answered both.
I eventually found the OP's question.
It is at the bottom
"But in a solution I found it was used U2 = mg2R
Because as A is in a distance R from center and B too, I tried with R for both but it seems that it needs to be done using a distance from bottom"
It is at the bottom
OK, so that's easy to find when you know the velocity at B.
You don't need to find the velocity anywhere - you just have to realize that the potential energy U is calculated using the vertical displacement above some reference point/level - and the the solution OP had seen that reference level was the bottom of the circle.
Point A is One Radius above the reference point, so the usual mgh had become mgR
Point B is two Radii above the reference point, so the usual mgh had become mg2R.
Related to Distance of a ball in a circle
What is the distance of a ball in a circle?
The distance of a ball in a circle refers to the length of the path the ball travels along the circumference of the circle.
How is the distance of a ball in a circle calculated?
The distance of a ball in a circle can be calculated using the formula d = 2πr, where d is the distance, π is pi (approximately 3.14), and r is the radius of the circle.
Does the size of the circle affect the distance of the ball?
Yes, the size of the circle does affect the distance of the ball. A larger circle will have a greater circumference, resulting in a longer distance for the ball to travel.
Can the distance of a ball in a circle be negative?
No, the distance of a ball in a circle cannot be negative. Distance is always a positive value and represents the length of the path traveled.
What units are used to measure the distance of a ball in a circle?
The distance of a ball in a circle is typically measured in units of length, such as meters, centimeters, or feet.
