Distance traveled by a Ball affected by friction after t seconds
The discussion focuses on calculating the distance traveled by a ball affected by friction and rolling resistance on a flat surface. Participants suggest that the ball experiences a constant rate of deceleration due to rolling resistance, complicating the calculation of distance. There is also consideration of whether air resistance should be factored in, particularly for a golf ball rolling on carpet at an initial velocity of 6.5 m/s. Accurate estimates of deceleration may require direct measurements to account for both rolling and air resistance. Further testing is recommended to refine the calculations and obtain precise results.
Volt582
Thread moved from the technical math forums to the schoolwork forums
Hi everyone,
i have been trying to find an answer to this problem I have but couldnt find any good answers...
(I dont know much about this stuff, but need a formula for a Project I am currently working on).
So The problem goes as follows:
Assuming we have a ball with a mass of m which is rolling on a flat surface with an initial velocity of v. Lets call the friction coefficiant between the surface and the Ball p. How much distance will the ball have traveled after t seconds when it is constantly affected by friction?
Volt582 said:
Hi everyone,
A rolling ball is slowly by rolling resistance, rather than friction. In any case, we can assume a constant rate of deceleration. What do you know about motion with constant acceleration?
When I have a constant acceleration I should be able to calculate the distance... But how could you calculate the deceleration?
And maybe another question: Do you think that air resistance should be accounted for as well when we are working with a golf ball on a carpet which is approximately traveling with an initial velocity of 6.5 m/s?
Rolling resistance is quite complicated. In any case, you are probably going to have to measure things if you want an accurate estimate.
Probably. But, it would take a bit of work to distinguish the effects of air resistance from rolling resistance. What you will measure directly is a deceleration that involves them both.
mhh ok... Then we will have to perform some more tests. Thanks anyway!
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
