Distance travelled by a car considering only air friction?
The discussion centers on calculating the distance a 3-ton car would travel at an initial speed of 17 km/h, considering only air friction. The initial calculation using the formula Vf² = Vi² + 2·a·d yielded a distance of 22.84 meters, which participants questioned as too low. It was clarified that air resistance is not constant and depends on velocity, making the initial formula inappropriate for this scenario. Participants emphasized the need to consider the variable nature of air friction when calculating distance, suggesting a more complex approach involving integrals. Ultimately, the conversation highlights the importance of accurately accounting for changing forces in physics calculations.
Suekdccia
Moved from the technical forums to the schoolwork forums.
TL;DR Summary: Distance traveled by a car considering only air friction?
How much distance would a 3-ton car travel if its initial speed was 17 km/h and we only take into account air's friction? (Assume that the car has an airfoil-like shape, so that the resistance against the air is very low)
I tried to calculate this with the formula Vf² = Vi² + 2·a·d (taking as 0.05 the coefficient of friction of the airfoil-like car against the air) and the resulting distance is 22,84 meters, but it seems too low to me. Am I messing up with something?
Air resistance is not like friction, it depends on the velocity. What research have you done into solving problems that involve air resistance? Wikipedia might be a good place to start...
Update with a link -- https://en.wikipedia.org/wiki/Drag_(physics)
Likes topsquark and Lnewqban
You should not use that formula because acceleration is not constant in your case.
Its value will be very high when velocity of the car is still high, but that value will progresively tend to zero at a square ratio as the velocity is degraded by air drag.
Likes topsquark and berkeman
Solving that formula for d gives me about 17 meters.
Our numbers do not agree. Yes, in addition to using the wrong formula, you seem to be messing something up. Please show your work.
Here is how you arrive at the equation you used:
The work done ##W## is defined as:
$$W = \int Fdx$$
Knowing that ##F=ma##, the work done based on acceleration is:
$$W= \int madx$$
If we want to know the work based on velocity alone:
$$W = \int madx = \int m\frac{dv}{dt}dx = \int m\frac{dx}{dt}dv = \int mvdv$$
Both equations should give the same amount of work, so:
$$\int_{v_i}^{v_f} mvdv = \int_{x_i}^{x_f} madx$$
$$\frac{1}{2}m(v_f^2 - v_i^2) = ma(x_f - x_i)$$
$$v_f^2 = v_i^2 + 2a(x_f - x_i)$$
Which is the equation you used. This assumes that ##F = ma##, where ##a## is constant.
But that is not the case here. The problem identifies the force ##F## that you need to use with the work ##Fdx##. And the work done based on velocity is still ##mvdv##. All you need to do is to equate both as done previously and resolve the integrals. [Hint: the air friction force varies with velocity.]
Likes berkeman and topsquark
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
