DISTANCE travelled by the projectile
  • Thread starter Thread starter judas_priest
    Projectile
To calculate the distance traveled by a projectile, it is essential to distinguish between horizontal and vertical motion. The horizontal displacement can be calculated using the formula Δd_H = v_H Δt, while the total distance along the projectile's curved path requires integrating the instantaneous speed over time. For a projectile launched from a height, the total distance can be derived from the integral of the velocity function v(t) over the time of flight. The discussion highlights that while calculating displacement is straightforward, determining the total distance involves more complex calculations, including potential hyperbolic trigonometric substitutions. Understanding these principles is crucial for accurately solving projectile motion problems.
judas_priest
What is the DISTANCE traveled by the projectile?
I know how to calculate the displacement, but this includes both x and y components, so how do I calculate the distance? I'm sure it must include both height and vertical displacement components
I have no clue really. Everything I try to do, it just gives me the displacement. I just don't know how to get the 'h' factor in? Do I use pythagaros? Because it doesn't apply for a curved surface.
Wait are you trying to find the distance the object flew in total or are you trying to find its horizontal displacement ( I'm sure it's displacement though ).
With that in mind, to get the horizontal displacement of an object use :
$$\vec{Δd}_H = \vec{v}_H Δt = \frac{ \vec{v}_R^2 sin(2θ) }{ \vec{a} }$$
depending on which information you have been given or have been able to retrieve.
What is ##\vec{v}_R?## That equation does not make sense. You cannot square a vector or divide by one.
@judas_priest: Distinguish between horizontal and vertical motion. Write the equation for the displacement of the body in each direction. Then find the horizontal displacement in terms of known quantities by eliminating variables between the two equations.
CAF123 said:
What is ##\vec{v}_R?## That equation does not make sense. You cannot square a vector.
##\vec{v}_R## is the resultant velocity ( Hypotenuse ).
EDIT : Yeah you're right, It should be :
$$\frac{v_R^2 sin(2 \theta)}{a}$$
without the vector quantities.
Most elementary projectile mechanics question limit themselves to asking about the maximum horizontal distance traveled by the projectile, also known as the range. This is very easy to work out, and the well-known formula for a projectile launched on a flat surface has already been quoted. For a projectile launched from a height, the answer is quite simple to work out from first principles.
But if the question is actually asking for the total distance traveled by the projectile on its curved path, it's not impossible. Tedious, but not impossible. The distance is simply ##\displaystyle \int_0^T v(t)dt##, where ##T## is the total time of flight, and ##v(t)## is the instantaneous speed of the projectile expressed as a function of time.
Using the resultant of the horizontal and vertical components of velocity at time ##t##, it is possible to get an expression for ##v(t)##. Integrating that is a little tough, and a hyperbolic trig substitution is probably the quickest way. And simplifying the resulting mess is daunting. But an answer can be derived fairly quickly.
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up ##Mg \sin \theta ## will act downwards and maximum static friction will act downwards ## \mu Mg \cos \theta ## Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
