Distortion to correct farsightedness(Hyperopia)
  • Thread starter ECCsimmons
In summary: This conversation discusses the idea of using digital distortions to aid a farsighted person in reading. The thought is that by distorting the image as if it were going through a lens, the image could be properly focused onto the retina. However, it is stated that distortions and farsightedness are two different types of aberrations and cannot be corrected using the same method. The person also mentions the difficulty in testing this idea without access to someone who needs reading glasses. They also mention getting bombarded with information about digital cameras and lens correction when trying to research this topic.
ECCsimmons
I was thinking the other day about the idea of the eye using a lens to focus light onto the retina at the correct distance, and was curious whether a digital distortion could ever be used to aid a farsighted person to read something (say this forum post?). The idea being that you could distort the image as if it were going through an optical lens, like your reading glasses, and thus allowing the proper focusing of the image onto the retina for a person given their prescription(this would obviously take many tests to be accurate). I was first thinking of something like a pincushion/barrel distortion, but I highly doubt such a simple distortion would be accurate.
Thing is I have no way to test anything I create because nobody in my immediate vicinity needs reading glasses! and I have no way to relate to what they see without their glasses. It doesn't help that when I try to do research on something like this I get pounded with digital camera information and related software, dealing with lens correction and distortion.
Thx for any info guys!
I am afraid that distortions has nothing to do with farsightedness. Those are two different types of aberrations, because one is related to field (the image is in focus - i.e. it's sharp) and the other is related to wavefront aberrations (e.g. coma, astigmatism, etc. - the image is sharp only in specific areas). You just can't correct for example spherical aberration (which is causing farsightedness) using distortions. To be able to correct farsightedness you need to use the same type of aberrations but with opposite sign.
"near sightedness" and "farsightedness" both involve eyes focusing light off the retina. (One is before, the other behind, the retina, but I don't recall which.)
In either case, the lens is ground to move the focus to the retina.
FAQ: Distortion to correct farsightedness(Hyperopia)
What is farsightedness (hyperopia)?
Farsightedness, also known as hyperopia, is a common vision condition in which distant objects can be seen clearly, but close objects appear blurry.
How does farsightedness (hyperopia) occur?
Farsightedness occurs when the eyeball is too short or the cornea is too flat, causing light to focus behind the retina instead of directly on it. This results in difficulty seeing objects up close.
What is distortion to correct farsightedness (hyperopia)?
Distortion is a method used to correct farsightedness by altering the shape of the cornea or lens to help light focus correctly on the retina. This can be done through eyeglasses, contact lenses, or surgery.
How effective is distortion for correcting farsightedness (hyperopia)?
Distortion is a highly effective method for correcting farsightedness. It can improve vision and reduce the need for eyeglasses or contact lenses. However, the success of the treatment depends on the severity of the condition and the individual's unique eye anatomy.
Are there any risks associated with distortion to correct farsightedness (hyperopia)?
As with any medical procedure, there are some risks associated with distortion to correct farsightedness. These may include dry eyes, infection, or overcorrection. It is important to discuss these risks with an eye care professional before undergoing any treatment.
