Abphysics
- 2
So I was wondering that why does time move slower the faster you get ? And does it happen at all or is this is just fake ?
Why isn't a good question, how is explained by relativity and it is called time dilation. It happens near large masses also.Abphysics said:So I was wondering that why does time move slower the faster you get ?
The Global Positioning System (GPS) takes both forms into account to keep precise time.Abphysics said:And does it happen at all or is this is just fake ?
It doesn't. It just looks that way to observers who are moving relative to you. YOU, right now as you read this, are moving at almost the speed of light relative to an accelerated particle at CERN. Did you watch slow down when you realized that?Abphysics said:So I was wondering that why does time move slower the faster you get ? And does it happen at all or is this is just fake ?
You are answering as though time DOES slow down, but as I just explained, it doesn'tjerromyjon said:Why isn't a good question, how is explained by relativity and it is called time dilation. It happens near large masses also.
It is all relative. The time that passes on the ISS is not the same amount as the time that passes on Earth due to relative velocity and the strength of the gravitational field.phinds said:You are answering as though time DOES slow down, but as I just explained, it doesn't
You are missing the point. The OPs post indicates that he believes that time DOES move slower (in the local frame, although he likely doesn't know the terminology) and you are misleading him into thinking that might be true. If you want to explain differential aging to him, fine, but please stop misleading him.jerromyjon said:It is all relative. The time that passes on the ISS is not the same amount as the time that passes on Earth due to relative velocity and the strength of the gravitational field.
I am trying to explain it from a scientific perspective. I know what you are saying when you say:phinds said:you are misleading him into thinking that might be true.
phinds said:YOU, right now as you read this, are moving at almost the speed of light relative to an accelerated particle at CERN.
No matter what you will still perceive your time to be unaffected. If you hop on a spaceship and travel at near the speed of light for some time and turn around and come back a year later by your clock everyone here on Earth will be older by much more than a year!phinds said:Did you watch slow down when you realized that?
None of which involves time passing faster or more slowly for anyone involved.jerromyjon said:If you hop on a spaceship and travel at near the speed of light for some time and turn around and come back a year later by your clock everyone here on Earth will be older by much more than a year!
Yes, it's real, and rather than respond directly to your question, which is potentially problematic in its wording, I'll just give a quick primer (the wiki link is also pretty good for a start):Abphysics said:So I was wondering that why does time move slower the faster you get ? And does it happen at all or is this is just fake ?
According to Einstein's theory of relativity, distortions in time occur when an object is moving at speeds close to the speed of light. This is due to the fact that as an object approaches the speed of light, its mass increases and time slows down, resulting in a distortion of time.
Distortions in time can greatly affect space travel, as the closer a spacecraft gets to the speed of light, the slower time will pass for the astronauts on board. This means that while only a few years may have passed for the astronauts, decades or even centuries may have passed on Earth.
While it is not possible for humans to travel at the speed of light, distortions in time can still occur on Earth. For example, satellites in orbit experience a slight difference in time compared to clocks on the ground due to their high speeds. However, the effects are very small and only noticeable with highly precise instruments.
No, distortions in time cannot be reversed. Time will always appear to pass slower for objects moving at high speeds compared to those at rest. This phenomenon is a fundamental aspect of Einstein's theory of relativity and has been proven through various experiments and observations.
Besides time dilation, distortions in time can also cause length contraction, where objects moving at high speeds appear shorter in the direction of motion. This effect has also been observed and confirmed through experiments and is another important aspect of Einstein's theory of relativity.
