Distribution and direction of Unruh radiation
In summary: So if I am at a constant radius from a mass, I am accelerating upwards relative to a free-fall observer. Does that mean that looking up when standing on the Moon, I should see a thermal contribution to the sky at a temperature a little less than ##10^{-20} K##?One source on this (Scholarpedia) states:"From the point of view of Rindler quantization (2) the detector is responding to the particles whose presence was calculated in (4). From the point of view of Minkowski quantization (1) the excitation of the detector is correlated with emission, not absorption, of particles (Unruh and Wald, 1984
GeorgeDishman
419
29
If an observer accelerates through a simple vacuum, it is often said that they see Unruh radiation with acceleration of ##2.5*10^{20} m/s^2## equivalent to a temperature of 1K, but I haven't seen the polar distribution described, one might assume it was from 'ahead' of the direction of acceleration, is that correct?
If so, by the equivalence principle, if I am at a constant radius from a mass, I am accelerating 'upwards' relative to a free-fall observer. Does that mean that looking up when standing on the Moon, I should see a thermal contribution to the sky at a temperature a little less than ##10^{-20} K##?
  • "From the point of view of Rindler quantization (2) the detector is responding to the particles whose presence was calculated in (4). From the point of view of Minkowski quantization (1) the excitation of the detector is correlated with emission, not absorption, of particles (Unruh and Wald, 1984); thus a stationary (or inertial) observer "sees" the detector radiating, .."
This makes me think perhaps an observer on the Moon wouldn't see a thermal sky, rather an observer at infinity would see thermal radiation from the surface, i.e. this is Hawking Radiation?
Likes tionis
  1. That's not what the equivalence principle says.
  2. The gravitational equivalence of Unruh radiation is Hawking radiation.
  3. I do not believe you get Hawking radiation from non-black holes. The standard derivation relies on a horizon, and without a BH you don't have one. If you get radiation, it's from some other means.
Likes craigthone and tionis
Of course, that's the key, thank you! When accelerating through Minkowski space, the horizon is behind you so that's where the Unruh radiation must appear to originate, not from in front.
Yes, if you are accelerating upwards relative to a free-fall observer, the radiation would appear to come from 'below' which is then consistent with Hawking Radiation, that solves my puzzle.
That you would say that surprises me, in what way have I got it wrong?
Hi George. See below:
''The radiation will be isotropic. Ie, it will obey detailed balance-- the radiation received depends both on the radiation there and the cross section of the detector for radiation from that direction. The cross section is the same for emission and reception, so in directions where it is difficult to emit, it is also difficult to receive. But taking into account the anisotropy of the detector, the thermal spectrum is isotropic. Note that the detector is also in a strong gravitational field, so the Tolman relation says that the temperature has a gradient, and if the detector is sensitive to that gradient, it will see "up" as different from sideways.
No, on Earth or the moon there is no such radiation. Note that the wavelength for radiation with a temp of 10^-20 is about 10^18 m (ie about 100 light years), so the radiation will be sensitive to changes in space on that kind of scale. Also the moon has no horizon which also prevents it from having such radiation. An observer at infinity also will not see radiation from the moon.''
The equivalence principle does not say you can swap gravity for acceleration. It takes 16 numbers to describe gravity and 3 to do acceleration. It's really more the reverse - it tells how to tell apart gravity from acceleration.
Likes craigthone
Ah OK. The descriptions I've seen are that acceleration is equivalent to a uniform gravitational field hence it is valid where the region is small enough that tidal components are negligible and I intended the comment that way. I should have been explicit about that.
Yes, my silly mistake was getting the horizon on the wrong side of the observer, there's no limit going upwards ;-)
Would yould like to say more about the meaning of equivalence priciple?
Please start a new thread if you have a specific question about the equivalence principle.
Related to Distribution and direction of Unruh radiation
What is Unruh radiation?
Unruh radiation is a theoretical concept in physics proposed by physicist William Unruh. It suggests that an accelerating observer in empty space would perceive a thermal distribution of particles, even though there are no particles present. This is similar to the concept of Hawking radiation for black holes.
How is the distribution of Unruh radiation determined?
The distribution of Unruh radiation is determined by the acceleration of the observer. The higher the acceleration, the higher the temperature and thus the distribution of particles. This is in accordance with the principles of quantum mechanics and relativity.
What is the direction of Unruh radiation?
The direction of Unruh radiation is perpendicular to the direction of acceleration. This means that if an observer is accelerating in a certain direction, the radiation would be emitted in a direction perpendicular to that acceleration.
Is Unruh radiation observable?
Currently, there is no direct experimental evidence for the existence of Unruh radiation. However, there have been studies that suggest it may be indirectly observable through the effects it has on accelerating particles.
What implications does Unruh radiation have in the field of physics?
The concept of Unruh radiation has implications in various fields of physics, including quantum mechanics, relativity, and particle physics. It also has potential implications for phenomena such as the black hole information paradox and the expansion of the universe.
