Distribution function for specific 1D problem
In summary, the question is about the distribution function for particles moving on a 1D axis with a force that causes them to eventually disappear when their average velocity is negative. The particles are influenced by a probability density function for velocity and are assumed to be independent and have a continuous velocity function over time. This problem can be thought of as an experiment where particles are placed on the axis and their trajectories are recorded until they eventually disappear, with the average of all these trajectories representing the most probable trajectory. Alternatively, it can be thought of as particles bouncing off a wall at X=0 and the question is about the probability density function for their position on the axis after a long time has passed.
gugk
Hello!
Maybe someone will be able to suggest something about the following quite simple problem:
1D problem on axis "X". Particle moves only along "X" axis and starts its motion from X=0. However, when "X<0" particle disappears. Particle is influenced by some kind of force in such way that we know only the density probability function of particle velocity F[v]. In the case, when the average velocity (can be found from F[v]) is negative, we can conclude that any particle after some time eventually will disappear, since the probability to go to negative "X" is bigger.
The question: if we have infinite number of such particles (and as a result infinite number of trajectories that ends on X<0), what is distribution function for these particles on the axis "X"?
Thank you very much for any suggestions and relevant to this problem sources.
Mathematics news on Phys.org
More information would be needed to model this, including:
1. what are the initial positions of all the particles? This could be given as a distribution, for example a uniform distribution on [0,1].
2. what, if any, are the dependencies between
(a) velocities of particle p at time s and at time t (##s\neq t##)
(b) velocities of particle p and particle q at time t (##p\neq q##)
(c) velocities of particle p at time s and particle q at time t (##p\neq q## and ##s\neq t##)
For the problem to make any physical sense the velocity of a particle would need to be a continuous function of time, which requires strong dependency in (a). A Wiener Process (Brownian Motion with drift) could be a suitable process for the velocity of a particle. That requires specification of two parameters for each particle ##p##:
I. instantaneous drift ##\mu_p## of velocity
II. instantaneous volatility ##\sigma_p## of velocity
A simple model would have ##\mu_p=\mu\forall p## and ##\sigma_p=\sigma\forall p## and all particles' velocity processes independent of one another.
Sorry that I didn't formulate the problem clear enough from the beginning.
I am interested in the simplest case, when particles are independent and velocity is a continuous function of time - (a) we know only the probability to have some velocity at the next time moment (from the probability density function of particle velocity F[v]).
To imagine the problem in different way, we can think that we do experiment:
we put the first particle at X=0 and record it trajectory. When the first particle eventually disappears (since the probability to move to negative X bigger), we put the second particle and do the same procedure. Each particle will have its own trajectory. If we average all these trajectories, we obtain the most probable trajectory - that says what is the probability to find the particle on some interval.
Or similarly, we can think that on the X<0 there is a wall that does not allow particle to move to negative value of X (particle doesn't bounce from the wall, just stay at X=0 if the force is directed to negative direction of X). And, assuming that from the beginning of that motion passed long time (initial condition will stop play the role, the particle mostly will be near the wall, even if it started far away), what is the probability density function for this particle on the axis X? What is the probability to find particle at some interval on the axis X in any fixed time?
Related to Distribution function for specific 1D problem
What is a distribution function for a specific 1D problem?
A distribution function for a specific 1D problem is a mathematical function that describes the probability of a particle in a one-dimensional system having a certain position and momentum. It can also be used to calculate the average properties of a large number of particles in the system.
What is the purpose of a distribution function?
The purpose of a distribution function is to provide a complete statistical description of a system by taking into account the position and momentum of all particles in the system. It allows us to calculate important properties such as the average position, momentum, and energy of the particles.
How is a distribution function related to the probability density function?
A distribution function and a probability density function are mathematically related. The distribution function is the integral of the probability density function over a certain range of values. In other words, it represents the cumulative probability of finding a particle with a certain position and momentum in the system.
Can a distribution function be used for any 1D problem?
Yes, a distribution function can be used for any 1D problem as long as the system is one-dimensional and the particles in the system are non-interacting. It is a powerful tool for analyzing and understanding the behavior of particles in a wide range of systems, from atoms and molecules to galaxies and the universe as a whole.
How is a distribution function determined experimentally?
A distribution function can be determined experimentally by measuring the position and momentum of a large number of particles in a system and then using statistical methods to analyze the data. This allows us to construct a distribution function that accurately describes the behavior of the particles in the system.
  • General Math
  • Quantum Physics
  • General Math
  • Quantum Physics
  • General Math
  • Materials and Chemical Engineering
