MattGeo
- 28
- 3
Suppose there is a spring-mass system arranged as shown in my crude drawing. This occurs on a frictionless surface. The spring is 0.5 meters long and is at its natural length. The 2 masses are initially at rest and the left mass is 1 kg and the right mass is 3 kg. If a 10 N force is applied leftward as shown on the 3 kg mass, then what will be the kinetic energy of the system once the force has been applied through a displacement of 10 meters? Additionally, what will be the potential energy stored in the spring due to its compression, assuming spring constant is 0.5 N/m? What will be the spring force at maximum compression?
My first inclination was to calculate the spring force at maximum compression and the magnitude of its compression. I arrived at this calculating the acceleration of the center of mass of the system.
Applying Newton's second law to the entire system the block system should accelerate at 2.5 m/s^2 and then using this fact you can deduce that the net force on the 1 kg1 kg block is 2.5 N and the net force on the 3 kg block is 7.5 N, meaning that the spring force at maximum compression is 2.5 N.
By considering the average force exerted by the spring to be 1.25 N I concluded that there must be 6.25 J of energy stored in the spring and 93.75 J of energy showing up as kinetic energy of the 2-mass system after 10 m of displacement. I feel like this must be incorrect though. I can't tell if I am even thinking about the displacement correctly. The spring is being compressed while the system begins to move.
Application of the force to the 3 kg mass will cause it to begin to accelerate but the moment it does, it will start applying a force to the other block, causing it to accelerate, with some tiny lag before it starts moving of course.
As long as the 10 N force is continuously applied and the acceleration is constant, would the spring compress to a stable compressed length or would it actually undergo oscillations while being accelerated?
Upon further thought I think I should be considering the displacement of the center of mass but also the relative displacement between the 2 masses and assume that the center of mass moves in proportion to m2/(m1+m2)
I keep confusing myself with this problem but if anyone could help to walk me through it, it would be great.
