Distribution of force acting upon two charged objects
In summary, Coulomb's law states that two point charges of opposite sign will attract each other in a vacuum. This law applies even if one charge is significantly larger than the other, as long as the charges are point charges with no mass. In terms of motion, the force between the charges will be equal and opposite, according to Newton's third law. When considering mass, the acceleration of each particle can be calculated using Newton's second law. Point charges are simply a convenient way to calculate the force between two charges without having to take into account the distribution of charge throughout the volume of the objects. This concept can also be applied to magnets, where the force distribution may be altered due to the shape of the magnetic field.
NTL01
Coulombs law states 2 point charges of opposite sign will attract where
acting simultaneously on two point charges
and
as follows:
The formula calculates the force that will act and implies the force be equally experienced by both points of charge even if one charge is much greater than the other
In a vacuum , two such charges will move toward each other.
My first question is do they move at the same velocity and acceleration even though their charges are radically different in sign and strength.
Of course one stipulation of the law is that the charges are point charges and have no mass.
What if we complicate the problem by allowing each "entity" to have both charge and mass. Further let us say that q1 has large mass and low charge , and Q2 the opposite.
Question 2
Will the force F be experienced by both entities equally, or must the equation be re written to allow for some differential force with a lower value on q1 and a larger for q2 ( or possibly vice versa)
In a vacuum , what will motion look like.One would assume the smaller mass Q2 will be accelerated at a higher rate and move toward the larger mass at a much higher velocity and the large mass Q1 will hardly move at all
Is that what happens , or does the F get distributed in FAVOR of Q1 so the acceleration and velocity are normalized despite the difference in mass.?
I don't know if there's a good way to talk about forces and accelerations together without talking about mass. You don't need to have massless point charges for Coulombs law to be applicable. It just says you have two point charges separated by a distance, here's the magnitude and direction of the force between those charges. You can easily just set the left hand side of that equation to ##F=ma## and just calculate the acceleration assuming whatever mass you want. But say that you had two point charges of equivalent mass that you don't care about. Their accelerations would be equal in magnitude and opposite in direction, ie: Newtons 3rd law, regardless of the magnitude of each individual charge. When you take changing mass into account you just simply calculate acceleration for each particle from Newtons 2nd law, which then describes the motion.
A good analogy is the force of gravity the Earth exerts on a falling body like a parachutist. The magnitude of the gravitational force acting on the parachutist, pulling them towards the Earth, is the exact same as the magnitude of the gravitational force acting on the Earth, pulling it towards the parachutist: ##G\frac{M_{earth}m_{parachutist}}{r^2}##. But the mass of the Earth will be something like 22 orders of magnitude greater than the mass of the parachutist. So while the parachutist undergoes the familiar 9.8ms-2 acceleration, the Earth only budges a tiny unmeasurable amount, again from ##F=ma##.
I think you might be getting hung up on point charges. They're just a convenience people use when calculating these type of forces and they aren't real in this sense. If you give a point charge a mass it doesn't automatically become infinitely dense or something, you just say its a point in space that has mass and charge and go about doing physics with it.
This is the first I've heard of massless point charges. Point charges are assumed so that things such as the distribution of charge throughout he volume of the object do not need to be considered. Also, the force on the two charges will definitely be equal irrespective of their charges and this much is evident from Newton's 3rd Law.
Thank you both Ajay and Laner
Laners gravitation analogy really did the trick for me.
It got me wondering about magnets, which in attract mode ( opposite polarities) follow a very similar inverse square and scalar as electrostatics
Would we figure/ do we know if the distribution of force is identical between two dissimilar strength magnets for the same reasons?
The shape of the field is different when two magnets oppose each other than two point charges becasue the field of each magnet folds back into itself to form a "circuit"
Does the filed shape alter the force distribution in any way?
Related to Distribution of force acting upon two charged objects
1. What is the relationship between the distance between two charged objects and the force acting upon them?
The force between two charged objects is directly proportional to the product of their charges and inversely proportional to the square of the distance between them. This is known as Coulomb's Law.
2. How does the distribution of charges on two objects affect the force between them?
If the charges on both objects are evenly distributed, the force between them will be evenly distributed as well. However, if one object has a higher concentration of charge in a specific area, the force will be stronger in that area.
3. Can the distribution of force between two charged objects be affected by external factors?
Yes, the distribution of force between two charged objects can be affected by the presence of other charged objects in the vicinity. This is known as the principle of superposition, where the total force acting on an object is the sum of the forces from all other objects.
4. How does the medium between two charged objects affect the force between them?
The medium between two charged objects can affect the force between them by influencing the strength of the electric field. For example, a medium with a higher dielectric constant will weaken the force between two charged objects.
5. Is the distribution of force between two charged objects affected by the size or magnitude of the charges?
Yes, the distribution of force between two charged objects is directly proportional to the magnitude of the charges on the objects. The larger the charges, the greater the force between them.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
16K
