Distribution of sample means and variances
The discussion focuses on the distribution of sample means and variances derived from i.i.d. Normal random variables. Participants are exploring the distributions of Xbark + Xbarn-k, the ratio of variances, and the expected value of S2 given Xbar. Key points include the understanding that Xbark and Xbarn-k are normally distributed, and the challenge lies in determining how their sums and ratios affect overall distributions. There is also a correction regarding the formula for sample variance, emphasizing the importance of proper notation in statistical calculations. Overall, the conversation highlights the complexities of statistical distributions in the context of sample means and variances.
Aria1
Let X1,X2,...,Xn be i.i.d. Normal(μ,σ2) random variables, where the sample size n≥4. For 2≤k≤n-2, we define:
Xbar = (1/n)SUM(Xi) from i=1 to n
Xbark = (1/k)SUMXi) from i=1 to k
Xbarn-k = (1/n-k-1)SUMXi from i=k+1 to n
S2=(1/n-1)SUM(Xi-Xbar)2 from i=1 to n
S2k=(1/k-1)SUM(Xi-Xbark)2 from i=1 to k
S2n-k=(1/n-k-1)SUM(Xi-Xbarn-k)2 from i=k+1 to n
Find distribution of:
a) Xbark + Xbarn-k.
b) ((k-1)S2k + (n-k-1)S2n-k)/σ2
c) S2k/S2n-k
d) Evaluate E(S2 | Xbar = xbar) Explain.
**I am not asking for someone to do the proof for me(this is a lot of work), but I would love a verbal explanation for what the distributions of each of those might be/why? THANKS!
a) I know Xbark is distributed Norm(μ,σ2/k) and Xbarn-k is distributed Norm(u,σ2/n-k), but I don't know how adding the two distributions together impacts the overall distribution.
b) Same idea where I know I am adding a χ2 distribution with parameter k-1 to a χ2 distribution with parameter n-k-1 all over σ2, but do not have a deep enough conceptual understanding to comprehend how adding them together affects it.
c) For this one I got as far as finding a χ2 distribution with parameter k-1 divided by χ2 distribution with parameter n-k-1
So, I've gotten a little further with this one, and I think part (b) is a chi-square distribution with parameter n and part (c) is an F-distribution with parameters k-1 and n-k-1. I am still not sure just how to do part (a) though, and the concept that is actually giving me trouble is how the constant 1/k affects the distribution. If X had a standard normal distribution, then I think Xbark would yield be distributed Norm(0,k2). However, given the mean and standard deviation as μ and σ2, I am not sure how this might change the answer.
As for part (d), I solved to: (1/(n-1))SUM E(Xi2) -nxbar, but have no idea how to follow it up from there or if I'm going the wrong direction entirely. Any hints would be much appreciated. Thank you :)
a) Xbark + Xbarn-k.
c) S2k/S2n-k
Are you not using a textbook or course notes? Surely many of these items are discussed therein.
However, just in case you do not have a textbook, I will give a couple of hints. You say (correctly) that Xbark and Xbarn-k are normally distributed, and you give their means and variances. Are they dependent or independent? If they were independent, what could you say about their sum? Ditto for the terms (k-1)S2k and (n-k-1)S2n-k.
BTW: your definitions of S2, etc., are incorrect: this is NOT equal to
(1/n-1)SUM(Xi-Xbar)2 from i=1 to n, which is
\left( \frac{1}{n}-1\right) \sum_{i=1}^n (X_i - \bar{X})^2.
The correct formula is
\frac{1}{n-1} \sum_{i=1}^n (X_i - \bar{X})^2.
which would be written as (1/(n-1)) SUM (Xi-Xbar)2, i=1..n. That is, you need 1/(n-1), not 1/n-1.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
