A Distribution of sum of two circular uniform RVs in the range [0, 2 pi)
  • A
  • Thread starter Thread starter nikozm
    Distribution
The discussion focuses on deriving the distribution of the sum of two circular uniform random variables (RVs) within the range [0, 2 pi). Participants seek clarification on whether the sum remains modulo 2 pi, especially when one RV is circular and the other is uniformly distributed over a different range. There is uncertainty regarding the implications of the modulo operation, as different definitions can lead to varying results. The complexity of the calculations involved in this scenario is acknowledged, with a request for assistance in determining the correct range of the resulting distribution. The conversation highlights the need for clear definitions in mathematical operations to avoid confusion in results.
nikozm
TL;DR Summary
distribution; uniform
Hello,
I would like to know the analytical steps of deriving the distribution of sum of two circular (modulo 2 pi) uniform RVs in the range [0, 2 pi).
Any help would be useful
Thanks in advance!
Easiest way is <br /> P(0 \leq Z = (\Theta + \Phi) \mod 2 \pi &lt; z ) = P(0 \leq \Theta + \Phi &lt; z) + P(2\pi \leq \Theta + \Phi &lt; z + 2\pi)<br /> for z \in [0, 2\pi) and \Theta, \Phi are independent and uniformly distributed on [0, 2\pi).
I try to utilize this formula to a similar case, but the result seems too complicated. What if one of two RVs is a circular (mod 2 pi) uniformly distributed in [0, 2 pi) and the other one is an independent uniform RV in the range [-2^(-q) pi, 2^(-q) pi], where q is a nonnegative integer greater or equal than one. I presume that their sum is also a uniform RV, but I am not sure about its range.
Can you help me on this.
Thank you so much in advance.
In the original it is not clear to me that the sum is also mod 2pi. If not then the result will be different.
Same here. Is the result mod 2pi? Unfortunately Wikipedia gives two definitions of the mod operator and the answer differs in the two cases. So you are right to be uncertain.
Wikipedia : In computing, the modulo operation returns the remainder or signed remainder of a division, after one number is divided by another.
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
