Divergence in spherical coordinates.
In summary, the conversation discusses verifying the equation for a vector field A, where A is equal to a constant k divided by the square of the distance R, and the equation for the divergence of A. The expert summarizer explains that the last part of the equation is a partial derivative of k with respect to R, which is zero since k is a constant. The conversation ends with the person wanting to verify the solution to a problem in Electrodynamics.
yungman
5,738
290
I want to verify:
[tex]\vec A=\hat R \frac{k}{R^2}\;\hbox{ where k is a constant.}[/tex]
[tex]\nabla\cdot\vec A=\frac{1}{R^2}\frac{\partial (R^2A_R)}{\partial R}+\frac{1}{R\sin\theta}\frac{\partial (A_{\theta}\sin\theta)}{\partial \theta}+\frac{1}{R\sin\theta}\frac{\partial A_{\phi}}{\partial \phi}[/tex]
[tex]\Rightarrow\;\nabla\cdot\vec A=\frac{1}{R^2}\frac{\partial \left(R^2\frac{k}{R^2}\right)}{\partial R}= \frac{1}{R^2}\frac{\partial k}{\partial R}=0[/tex]
I don't have any problem with that until the last part. What does [itex]\partial k/\partial R[/itex] mean? If "k" is the unit vector in the z direction, it is a constant, and any derivative of it is 0.
He defines ##k## as a constant. So ##\frac{\partial k}{\partial R}## is the partial derivative of ##k## with respect to the variable ##R## which is zero, as he gets.
Thanks, this is part of a problem in Electrodynamics where the solution manual claimed it is not zero. I just want to verify.
Thanks for the help.
Related to Divergence in spherical coordinates.
1.
What is divergence in spherical coordinates?
In spherical coordinates, divergence is a measure of how much a vector field diverges or spreads out at a particular point. It is typically represented by the symbol ∇ ⋅ F, where ∇ is the vector differential operator and F is the vector field.
2.
How is divergence calculated in spherical coordinates?
In spherical coordinates, divergence is calculated using the formula:
∇ ⋅ F = 1/r² ∂(r²Fr)/∂r + 1/(r sinθ) ∂(Fθ sinθ)/∂θ + 1/(r sinθ) ∂Fφ/∂φ
where r is the radial distance, θ is the polar angle, and φ is the azimuthal angle.
3.
What is the physical significance of divergence in spherical coordinates?
In physics, divergence in spherical coordinates is often used to describe the flow of a fluid or the distribution of a magnetic or electric field. It represents the amount of "source" or "sink" at a given point, indicating where the vector field is either spreading out or converging.
4.
How does divergence in spherical coordinates relate to other coordinate systems?
Divergence can be calculated in various coordinate systems, including Cartesian, cylindrical, and spherical. In spherical coordinates, the divergence formula includes terms that account for the curvature of the coordinate system, making it more suitable for problems with spherical symmetry.
5.
What are some applications of divergence in spherical coordinates?
Divergence in spherical coordinates is used in many fields, including fluid dynamics, electromagnetism, and quantum mechanics. It is particularly useful in problems involving spherical objects, such as the Earth's magnetic field or the flow of air around a spherical object.
