Divergence in spherical coordinates
In summary, the conversation discusses calculating the divergence and flux of the vector function \vec{F}(\vec{r})=\frac{r\hat{r}}{(r^2+{\epsilon}^2)^{3/2}} in various scenarios. The solution involves using the spherical coordinates divergence formula and substituting different values for ##\epsilon##. Part b) involves finding the flux outward through a sphere of radius R centered at the origin and verifying that it is equal to the integral of the divergence inside the sphere. Part c) shows that the flux is independent of R in the limit ##\epsilon \rightarrow 0##.
wifi
115
Problem:
For the vector function [tex]\vec{F}(\vec{r})=\frac{r\hat{r}}{(r^2+{\epsilon}^2)^{3/2}}[/tex]
a. Calculate the divergence of ##\vec{F}(\vec{r})##, and sketch a plot of the divergence as a function ##r##, for ##\epsilon##<<1, ##\epsilon##≈1 , and ##\epsilon##>>1.
b. Calculate the flux of ##\vec{F}## outward through a sphere of radius R centered at the origin, and verify that it is equal to the integral of the divergence inside the sphere.
c. Show that the flux is ##4 \pi## (independent of R) in the limit ##\epsilon \rightarrow 0##.
Solution:
a. Calculating the divergence is simply a matter of plugging the function correctly into the spherical coordinates divergence formula. I get [tex]F_r=\frac{r}{(r^2+{\epsilon}^2)^{3/2}} \Rightarrow \frac{\partial F}{\partial r}=3r^2(r^2+{\epsilon}^2)^{-3/2}-3r^4(r^2+{\epsilon}^2)^{-5/2} [/tex]
Therefore,
[tex]\nabla \cdot \vec{F}= 3(r^2+{\epsilon}^2)^{-3/2}-3r^2(r^2+{\epsilon}^2)^{-5/2} [/tex]
So for the different values of ##\epsilon## do I just substitute?
Also can someone point me in the right direction for parts b. and c.? Thanks.
Anyone?
Check your ∂F/∂r.
Anyway, the end result is correct.
As for b), what is flux?
ehild
Yes, you can substitute different values of ##\epsilon## to get a better understanding of how the divergence changes. When ##\epsilon## is very small, the divergence is close to 3/r^2, which means that the vector field is diverging strongly away from the origin. As ##\epsilon## increases, the divergence decreases and approaches 0 as ##\epsilon## approaches infinity. This means that the vector field becomes more uniform and less divergent as ##\epsilon## increases.
b. To calculate the flux, we use the divergence theorem, which states that the flux of a vector field through a closed surface is equal to the volume integral of the divergence over the enclosed volume. In this case, the closed surface is a sphere of radius R centered at the origin. Therefore, the flux is given by:
\Phi=\int_V \nabla \cdot \vec{F} dV
Since the vector field is spherically symmetric, we can use the divergence formula in spherical coordinates to simplify the integral. This gives us:
\Phi=\int_0^{2\pi} \int_0^{\pi} \int_0^R \left(3(r^2+{\epsilon}^2)^{-3/2}-3r^2(r^2+{\epsilon}^2)^{-5/2}\right) r^2 \sin{\phi} dr d\phi d\theta
Solving this integral gives us:
\Phi=\frac{4\pi}{3}\left(1-\frac{R^3}{(R^2+{\epsilon}^2)^{3/2}}\right)
c. To show that the flux is independent of R in the limit ##\epsilon \rightarrow 0##, we simply take the limit as ##\epsilon## approaches 0 in the above equation. This gives us:
\lim_{\epsilon \rightarrow 0} \Phi=\frac{4\pi}{3}
Therefore, the flux is independent of R in the limit ##\epsilon \rightarrow 0##, which means that the vector field is uniform and non-divergent in this limit. This is consistent with our previous understanding that as ##\epsilon## approaches 0, the vector field becomes more uniform and less divergent.
Related to Divergence in spherical coordinates
1. What is divergence in spherical coordinates?
Divergence in spherical coordinates is a measure of the rate at which a vector field is flowing outwards or inwards from a point in three-dimensional space. It is also known as radial flux density.
2. How is divergence calculated in spherical coordinates?
In spherical coordinates, divergence is calculated using the radial component of the vector field and the scale factor for the spherical coordinates. The formula for divergence in spherical coordinates is given by:
div F = (1/r^2) ∂(r^2F_r)/∂r + (1/rsinθ) ∂(sinθF_θ)/∂θ + (1/rsinθ) ∂F_ϕ/∂ϕ
3. What is the physical interpretation of divergence in spherical coordinates?
The physical interpretation of divergence in spherical coordinates is the net flow of a vector field per unit volume at a given point. A positive divergence indicates a net flow outwards from the point, while a negative divergence indicates a net flow inwards towards the point.
4. How is divergence related to the concept of a source or sink in spherical coordinates?
In spherical coordinates, a source or sink is represented by a point where the divergence is non-zero. A positive divergence at a point indicates a source, where the vector field is flowing outwards from the point. Conversely, a negative divergence at a point indicates a sink, where the vector field is flowing inwards towards the point.
5. What are some applications of divergence in spherical coordinates?
Divergence in spherical coordinates is used in many fields, including fluid mechanics, electromagnetism, and meteorology. It can be used to model fluid flow, calculate electric and magnetic fields, and study atmospheric phenomena such as wind patterns and air circulation.
