Altabeh said:
I'm so curious to see how the method is verified.
Then how about you reread the line
you purposely deleted when quoting me in your post. "Tensor Tools for Calculus" is a freely available program. If you have access to Mathematica, give it a try yourself.
To make sure this isn't another reading comprehension issue, please note I said it verified the method
in this case (ie. the divergence term I was working on). Nowhere did I claim I have been able to verify the method in generality.
Not trusting my math, and not trusting a computational package is one thing, but this comment is just offensive:
Altabeh said:
Put the results in this thread or otherwise I sure know that if I can call this a "method", it does not work at all!
You are
sure the method doesn't work here (or at all)!?
You have repeatedly stated how easy it is to do the calculation I am struggling with (the divergence of g^{ab}R_{cd}R^{cd}). Yet instead of showing me how to do it, you deridingly give me "hints" which seem to lead no-where, or just insult me.
Look, I can't show the math here because I had to resort to using a computational package. I still don't know how to work it out by hand, except for using the method I suggested, which I can't prove in generality either. But if you are going to disagree with my result even after a computational package verified it... then please PLEASE, just show some math here. If it is so simple for you, and you are so sure the result is wrong, then please just work out the divergence of g^{ab}R_{cd}R^{cd} as that will actually answer the openning question of this thread.
Altabeh said:
The reason I already gave umpteen times before is that the approach does not include any appropriate function or parameter like, f(R) in the f(R) gravity theories, which has this advantage that cancels out with the extra non-vanishing terms of the divergence of the field equations on a purely geometrical (or mathematical) basis. (See for example the explanation below the equation 8 in
http://arxiv.org/abs/gr-qc/0505128). This does not occur by accident or by the use of a cheap guess as in your theory.
I stated that I worked out that my method works in general for f(R) theory, and you instead claimed that f(R) theory leads to violation of energy-momentum conservation unless careful choices of the function f(R) are made. I then wrote out the math explicitly showing that my method worked for f(R) theory
in general. You called the math complete nonsense and dismissed my result without consideration. Now you've come all the way around and seem to agree with me on f(R) theory, but still after all this time you are not listening.
In trying to work out that divergence relation, I was using what amounts to f(R,P,Q) = P - R, in the paper mentioned previously
http://arxiv.org/PS_cache/astro-ph/pdf/0410/0410031v2.pdf.
What you are claiming amounts to:
There are choices of f(R,P,Q) that lead to field equations which violate energy-momentum conservation,
despite the action having no explicit time or spatial dependence.
I find that claim much MUCH more unlikely than the claim I made to arrive at the divergence relation:
JustinLevy said:
Applying the method, we then get:
\nabla_b\left(g^{ab}R_{cd}R^{cd}\right) = 2\nabla_b\left(2R^{ca}R_c{}^{b} -2 \nabla^c\nabla^d R_c{}^{(a} \delta_d{}^{b)} + \nabla^c \nabla_c R^{ab} + g^{ab} \nabla^c \nabla^d R_{cd} \right)
If you believe the divergence relation I obtained is wrong, then finally stop leading us around and actually show the math which makes you so "sure" I am wrong. Showing the math will also answer the opening question of this thread, so will be directly useful as well.
