Divergence of forward Coulomb scattering?
In summary: I would love to help you out, but it seems i do not understand this phenomena very well. Could you explain to me what "Divergence" means for this exactly?I would love to help you out, but it seems i do not understand this phenomena very well. Could you explain to me what "Divergence" means for this exactly?
Xela
Hi,
I have a question about the divergence of forward Coulomb (Bhabha/Moller) scattering.
I guess the classical analog of it is the Rutherford cross-section divergence, but that can be explained by the infinite impact parameter.
In the QED version - the Bhabha/Moller scattering, it is the matrix element for given states that diverges - not only the cross-section, and I can't see how two plane-wave particles can have an impact parameter that could resolve this divergence.
Also, it seems that the divergence stems from the zero-momentum divergent photon propagator here. I saw explanations that this is typical for any infinite range interaction.
Could somebody please explain what is the solution for this divergence. Is this an unphysical one? What was the wrong assumption that caused it?
Zero-energy propagator probably means infinite-lifetime virtual photon. Does this has anything to do with the divergence?
http://en.wikipedia.org/wiki/Bhabha_scattering
Coulomb interaction between 2 charged particles is about the 1st thing we learn in high-school after the Newton laws. Doesn't this bother anyone? Am I missing something here?
Thank you.
Thanks for the response. I guess I should formulate the question better. By "divergence" I mean an infinite result. This seems unphysical for probability amplitudes.
The phenomenon here is: one electron is scattered by another one. In the matrix element for electron-electron scattering there is a photon propagator that has 1/(p1-p2) with p1 - initial electron 4-momentum, and p2 the final electron 4-momentum. So for forward scattering (p1=p2 with no deflection), the matrix element has division by zero => infinite amplitude.
There are cases of other infinities for very high momenta that are explained by the wrong assumption of point particles. But I think this is not applicable here.
Does this makes the problem clearer?
Would you have scattering with 0 deflection? Also, from what I've just looked up on Bhabha Scattering, it is for electron-positron scattering. Is that what you meant or can you substitute an electron for that positron?
I think yes - a very weak scattering. Or even if we decide to call this case "no scattering" - the calculation for this case is still problematic. I wouldn't be surprised if forward scattering probability would come out close to 1, but an infinite one looks like a mathematical problem
Bhabha is electron-positron, and electron-electron is called Moller scattering, but both have the same problem.
I'm sorry, i wish i could have helped you. All i really found at all was the matrix element picture at http://en.wikipedia.org/wiki/Bhabha_scattering that has what looks like your equation. All i saw there was 1/(k1-k2)^2
Hopefully someone else will be able to help!
Hi again.
Well, I'm a bit surprised I didn't get any answers.
If the subject doesn't look that interesting - I think it is interesting. Infinite probability without explanations of the simplest electron-electron scattering looks like a serious problem in QED, which is the most accurate physical theory we have.
If it is because nobody has an answer - this makes it even more interesting. But my guess is that I just misunderstood something here, and I'd appreciate it very much if some one could point me to the issue.
Thank you.
Related to Divergence of forward Coulomb scattering?
1. What is the concept of "Divergence of forward Coulomb scattering"?
The divergence of forward Coulomb scattering is a phenomenon that occurs when a charged particle, such as an electron, is scattered by a Coulomb field in the forward direction. This means that the scattered particle moves in the same direction as the incident particle, with a slight deviation due to the interaction with the Coulomb field.
2. How does the divergence of forward Coulomb scattering affect particle trajectories?
The divergence of forward Coulomb scattering can cause deviations in the trajectories of charged particles, leading to changes in their momentum and energy. This can be observed in high-energy particle accelerators, where precise control of particle trajectories is essential.
3. What factors influence the magnitude of the divergence of forward Coulomb scattering?
The magnitude of the divergence of forward Coulomb scattering is influenced by several factors, including the strength of the Coulomb field, the charge and mass of the particle, and the angle of incidence. As the strength of the Coulomb field increases, the magnitude of the scattering also increases.
4. How is the divergence of forward Coulomb scattering calculated?
The divergence of forward Coulomb scattering is calculated using quantum mechanical equations, such as the Rutherford scattering formula, which takes into account the Coulomb force and the initial and final positions of the particles. This calculation allows for the prediction of the scattering angles and the trajectory of the scattered particle.
5. What are some practical applications of the divergence of forward Coulomb scattering?
The divergence of forward Coulomb scattering has many practical applications, including in particle accelerators, where it is used to control and manipulate the trajectories of accelerated particles. It is also used in medical imaging techniques, such as Compton scattering, to produce images of body tissues and structures.
  • Quantum Physics
9K
  • Quantum Physics
  • Electromagnetism
  • Quantum Physics
