Divergent limit + divergent limit = convergent limitIs it possible?
The discussion centers on evaluating limits using the Method of Frobenius, specifically examining three limits as x approaches 0. The first two limits are divergent, resulting in infinity and negative infinity, while the sum of these two limits yields a convergent limit of -1. This raises confusion about the property of limits, which states that the limit of a sum equals the sum of the limits, but only if both individual limits exist. The conclusion emphasizes that the initial assumption about summing divergent limits leading to a convergent limit is incorrect, as the necessary conditions for the theorem are not met.
gikiian
As a part of Method of Frobenius, I am encountered with the following problems:
Evaluate the following limits:
Q1. \stackrel{limit}{_{x→0}}\frac{1-2x}{x}
Q2. \stackrel{limit}{_{x→0}}\frac{x-1}{x}
Q3. \stackrel{limit}{_{x→0}}\frac{1-2x}{x}+\frac{x-1}{x}
In context of the above problems, I am having difficulty in verifying the following property of limits:
\stackrel{limit}{_{x→a}}(f(x)+g(x))=\stackrel{limit}{_{x→a}}f(x)+ \stackrel{limit}{_{x→a}}g(x)​
N/A
A1. \stackrel{limit}{_{x→0}}\frac{1-2x}{x}=∞ (i.e. the limit is divergent)
A2. \stackrel{limit}{_{x→0}}\frac{x-1}{x}=-∞ (i.e. the limit is divergent)
A3. \stackrel{limit}{_{x→0}}\frac{1-2x}{x}+\frac{x-1}{x}=\frac{1-2x+x-1}{x}=\frac{-x}{x}=-1 (i.e. the limit is convergent)I am just confused by the apparent fact that sum of two divergent limits can be a convergent limit. Even though this is apparent in my problem, I still want to make sure if I am not messing up anywhere.
N/A
You cannot verify that "result" because it is just false, as your example shows. There is a somewhat similar true result, but it involves some extra hypotheses that your example fails to satisfy.
you're not summing two divergent limits. You're summing two functions whose individual limits at the same point are both divergent.
What the theorem states is that if both limits on the right side exist, then the limit on the left exists and equals the sum of the limits on the right. That's all.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
