Divergent partial wave amplitudes
In summary: Your Name]In summary, the forum user is encountering divergent results in their calculations of partial wave amplitudes in various processes, specifically in the case of electron-electron scattering in QED. They believe this is due to the propagator going on shell, causing the forward scattering amplitude to become infinite. To overcome this issue, they need to introduce a cut in the integral using a regularization technique, such as the Feynman gauge. This will allow for a finite and physically meaningful result. They are advised to consult with colleagues or a textbook for guidance on the best approach for their specific calculation.
mike372
I want to calculate the partial wave amplitudes for various processes but get divergent results in certain cases which I assume is related to the propagator going on shell - the forward scattering amplitude is infinite. I guess I have to introduce some sort of cut but don't know how to do this.
As an example consider electron - electron scattering in QED with both electrons having the same spin. The full amplitude goes as:
[tex]
\mathcal{M}=-e^2 4 m^2 \left(\frac{1}{t}-\frac{1}{u}\right)
[/tex]
Now calculating the J=1 partial wave...
[tex]
\mathcal{M}^{(1)}=\frac{1}{32\pi}\int_{-1}^1\: \mathcal{M} \cos{\theta} \: d(\cos{\theta}) =\frac{e^2 m^2}{8\pi p^2}\int_{-1}^1\: \frac{\cos^2{\theta}}{1-\cos^2{\theta}}d(\cos{\theta})
[/tex]
which diverges. The partial wave amplitude cannot be infinite so how do I get around the problem?
I understand your frustration with encountering divergent results in your calculations. This is a common issue in physics, and it often indicates that our current understanding of the system is incomplete. In this case, the infinite result for the J=1 partial wave amplitude is indeed related to the propagator going on shell.
To address this issue, you can introduce a cut in the integral to avoid the singularities. This is known as a regularization technique. There are several different methods for regularization, such as dimensional regularization or introducing a momentum cutoff. These methods essentially modify the integral in a mathematically consistent way to avoid the divergences.
In the specific case of electron-electron scattering in QED, one commonly used method is called the "Feynman gauge." In this gauge, the propagator is modified to include a term that cancels out the singularities. This allows for a finite result for the J=1 partial wave amplitude.
I recommend consulting with your colleagues or a textbook on QED to determine the best approach for your specific calculation. Regularization techniques can be complex and require a good understanding of the underlying theory. However, with the right approach, you should be able to obtain finite and physically meaningful results for your partial wave amplitudes.
Best of luck with your calculations!
Related to Divergent partial wave amplitudes
1. What are divergent partial wave amplitudes?
Divergent partial wave amplitudes refer to the behavior of the scattering amplitude at high energies or momenta. As the energy or momentum increases, the amplitude may diverge, meaning it becomes infinitely large. This can happen due to the presence of resonances or other physical phenomena.
2. How are divergent partial wave amplitudes calculated?
Divergent partial wave amplitudes are typically calculated using quantum field theory, specifically perturbation theory. This involves breaking down the scattering process into smaller, simpler components and then using mathematical techniques to calculate the amplitude at each stage. The divergences are then dealt with using renormalization techniques.
3. Why are divergent partial wave amplitudes important?
Divergent partial wave amplitudes are important in understanding the behavior of particles at high energies or momenta. They can provide insight into the underlying physical processes and can also be used to make predictions about future experiments. Additionally, understanding and properly dealing with divergences is crucial for the accuracy and validity of theoretical calculations in particle physics.
4. How do divergent partial wave amplitudes affect experimental results?
Divergent partial wave amplitudes can have a significant impact on experimental results. For example, if an amplitude diverges at a certain energy or momentum, it can lead to a peak or sharp increase in the scattering cross section at that point. This can affect the interpretation of experimental data and may require further investigation to understand the underlying physical processes.
5. Can divergent partial wave amplitudes be observed directly?
No, divergent partial wave amplitudes cannot be observed directly. They are purely theoretical constructs used to describe and predict the behavior of particles at high energies or momenta. However, their effects can be indirectly observed through experiments and measurements of scattering cross sections and other related quantities.
