Diversity gain in Wireless Communications
In summary, achieving "full diversity gain over Rayleigh fading channel" means utilizing multiple receive antennas in a MISO system to exploit independent propagation paths for increased system capacity and data throughput. This results in a diversity gain of L, where L is the number of independent fading paths.
crixus
What is meant by achieving "full diversity gain over Rayleigh fading channel"?
crixus: you have not provided the context for this quote, the type of system involved, nor even a complete sentence, so my response will be very generic.
A Rayleigh channel is a communications channel (path) consisting of a large number of multipath reflections of random amplitude and phase. Temporal fluctuations in the received signal strength have a Rayleigh statistical distribution. It is seen in an urban area when the transmitter is a cellphone that is moving (walking or traveling in a car), for example.
Diversity is a method to either mitigate or exploit the multipath propagation. The simplest form is switching from an antenna whose signal has temporarily faded to one elsewhere that is receiving a strong signal. There are more sophisticated electronic and signal coding diversity approaches, as you might imagine. In a MIMO system, the independent propagation paths are exploited so that (conceptually, anyway) each carries a different data stream, increasing system capacity and data throughput. Indoor IEEE 802.16 wireless LAN computer routers work this way. The gain obtained in all these cases is called diversity gain.
Thanks for replying. In fact I was able to figure out. Like if we have a MISO system with each antenna transmitting same symbol then diversity gain would be 1. However if I have multiple receive antennas then diversity gain would be L = no of independent fading paths. Thus "full diversity gain" is achieved in the latter case.
Related to Diversity gain in Wireless Communications
What is diversity gain in wireless communications?
Diversity gain refers to the improvement in signal quality and reliability that can be achieved through the use of multiple antennas or paths in wireless communication systems. It allows for better coverage, increased data rates, and reduced interference.
How is diversity gain measured?
Diversity gain is typically measured in decibels (dB) and is calculated by comparing the signal quality with and without diversity techniques. The higher the diversity gain, the better the signal quality and reliability.
What are the different types of diversity gain?
There are several types of diversity gain, including spatial diversity, temporal diversity, frequency diversity, and polarization diversity. These techniques use different methods to exploit the diversity of the wireless channel and improve signal quality.
What are some examples of diversity techniques used in wireless communications?
Some examples of diversity techniques include multiple-input multiple-output (MIMO) systems, which use multiple antennas at both the transmitter and receiver to improve signal quality, and receive diversity, which uses multiple antennas at the receiver to improve reliability.
What are the benefits of diversity gain in wireless communications?
The main benefits of diversity gain include increased coverage and range, improved signal quality and reliability, and higher data rates. This can lead to better overall performance and user experience in wireless communication systems.
  • Electrical Engineering
