MHB Divide Fractions: Is Subtraction of Exponents Correct?
  • Thread starter Thread starter DawnC
    Fractions
When dividing exponential fractions with the same base, the correct operation is to subtract the exponents. For example, in the expression x^9/x^4, the calculation follows the rule a^b/a^c = a^(b-c), resulting in x^(9-4) = x^5. This can also be demonstrated by canceling the common base in the fraction. It is important to note that this subtraction of exponents applies only when the bases are identical. Therefore, the statement about subtracting exponents when dividing fractions is accurate in the context of exponential expressions.
DawnC
When you divide a fraction, you minus the exponent - correct?
Example: x^9/x^4 you take the 9-5 = 5 so it would be x^5 -correc?
Mathematics news on Phys.org
Yes, one of the rules of exponents is:
$$\frac{a^b}{a^c}=a^{b-c}$$
Thus, we find:
$$\frac{x^9}{x^4}=x^{9-4}=x^5$$
Another way to look at this is to write:
$$\frac{x^9}{x^4}=\frac{x^5\cdot x^4}{x^4}=\frac{x^5\cdot\cancel{x^4}}{\cancel{x^4}}=x^5$$
This relies on another rule of exponents:
$$a^b\cdot a^c=a^{b+c}$$
Divide a fraction? Dividing a fraction means something like this : $\displaystyle\frac{\frac{a}{b}}{c}$ .
What you want to say is : When you solve an exponential fraction, you subtract the exponents - correct?
Yes, correct, but only when the bases are same.
We subtract the exponent of the denominator from the exponent of the numerator.
$\displaystyle\frac{a^m}{a^n}=a^{m-n}$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
