Dividing an equation by a variable
In summary, we discussed the topic of when it is appropriate to multiply and divide by a variable in equations. It was stated that dividing by a variable can result in losing or gaining solutions, and it is generally not safe to add, subtract, or otherwise manipulate equations without considering the possible solutions. The importance of using brackets and understanding the equation's structure was also emphasized.
Kajan thana
151
Hello guys,
I am confused about when we can multiply and divide by the variable. I know the if zero is hidden as a factor then we can not divide or multiply.
eg. x/2x+1=0 are we allowed to divide both side 2x+1. Although zero is hidden value of x, there are no other ways to solve this equation.
Another eg. cos(x)((-4sin^2(x)-1)=0
if we pluck x=0 into the equation, we will see it will not satisfy the equation so this shows x does not take the value of zero, does this mean that we can divide the equation by the variable by the variable..
and also are allowed divide zero by the variable?
Mathematics news on Phys.org
Hi, given an equation ##a=b##, by the equivalence principle you can multiply ##x## both sides and the result doesn't change ##x\cdot a=x\cdot b## (also when ##x=0## you have trivially that ##0=0##). In principle you can think that dividing will be the same thing, this is true but only when the division makes sense...
Likes Kajan thana
Kajan thana said:
eg. x/2x+1=0
Do you mean ##\frac x 2 x +1=0## (what a computer would assume), ##\frac x {2x} + 1 =0## or ##\frac x {2x+1} = 0## (what I assume)? Brackets are important. 2x+1 is in a denominator. You know that it cannot be zero for all values of x where the equation makes sense.
You can multiply both sides by 0, but then the equation gets trivial, as 0=0 is always true and "[something] => [something true]" does not have any information.
Yes.
Likes Kajan thana
Yes.
mfb said:
x2x+1=
This equation.
For the equation above we know x being zero does not satisfy the equation , then if we divide it by cos(x), are we not losing a set of solution.
Kajan thana said:
This equation.
Which one? "x2x+1" would be equal to ##2x^2+1##.
Please use brackets.
Kajan thana said:
This equation.
It doesn't work if you copy it like that.
x=0 and cos(x)=0 are completely different things.
Likes Kajan thana
And also will we loose any values if divide the 0 by the variable?
Possibly. It's usually not a good idea to divide both sides of an equation by a variable.
Here's a very simple example:
##x^2 = x##
If you divide both sides by x, you get x = 1, but the original equation has two solutions: x = 1 and x = 0.
For this equation, a better strategy is to bring all variables to one side, and then factor.
##x^2 - x = 0 \\
\Rightarrow x(x - 1) = 0 \\
\Rightarrow x = 1 \text{ or } x = 0##
If you do divide by a variable, keep in mind that you are possibly losing the solution x = 0.
The counterpart to dividing both sides of an equation by a variable is multiplying both sides of an equation by a variable. Here's an example of an equation in polar coordinates that shows this technique:
Convert the following equation in polar form to rectangular form:
##r = \cos(\theta)##
I'm going to mulitply both sides by r, noting that r = 0 is already a solution of this equation (when ##\theta## is any odd multiple of ##\pi/2##).
##r^2 = r\cos(\theta) \\
\Rightarrow x^2 + y^2 = x \\
\Rightarrow x^2 - x + y^2 = 0 \\
\Rightarrow x^2 - x + 1/4 + y^2 = 1/4 \\
\Rightarrow (x - 1/2)^2 + y^2 = (1/2)^2##
In the second line, I converted ##r^2## to its rectangular form of ##x^2 + y^2##, and converted ##r\cos(\theta)## to x.
In the fourth line above, I completed the square in the x terms, and in the fifth line, I factored the expression in x.
The last line is the equation of a circle centered at (1/2, 0), of radius 1/2.
Likes Kajan thana
Yes, and in general, you have to keep in mind that you may be losing or gaining solutions, no matter what you do to both sides of an equation. It isn't even completely safe to add and subtract things to both sides of an equation. For example:
## x - \frac{1}{(x-3)} = 3 - \frac{1}{(x-3)} ## can be transformed to ##x = 3## by adding ##\frac{1}{(x-3)}## to both sides.
That almost goes without saying. If you add or subtract, or multiply by or divide by an expression that might be undefined, you have to be careful.
Likes Kajan thana
I don't understand this question :
secθ(cosecθ-2)=(cosecθ-2)
For the question above we know that cosecθ can't be zero so we can divide RHS by (cosecθ-2) and we will not solution but truly if we take the (cosecθ-2) from RHS to LHS and factorise it we will get two sets of solutions. I don't understand where we will loose a solution, is there any way to determine if I am going to loose some solutions when I divide. At the start I thought if zero is not a solution then we can do whatever we want and still won't loose any solution.
Please explain this.
Thank you.
If you divide by (cosec##\theta##-2) , what you need to consider is whether there is value of ##\theta## such that (cosec##\theta## - 2) = 0.
There is no general way to solve equations that can be done without thinking. However, in textbooks and in many real life situations, we encounter equations that aren't particularly tricky and we can solve them by "doing the same thing to both sides" several times. People, including myself, often use the procedure of solving the equation with manipulations without thinking much about them. Then they check their solutions by substitution in the original equal to see if all their answers actually work. They use graphs to see if they left out any solutions.
Solving an equation by pure logical deduction would involve considering a number of "cases" instead of writing out a singe sequence of steps. Very few people want to teach solving equations deductively because mastering logical deduction that splits into several cases is hard. Furthermore, it would be a pain in the neck to grade homework that went into that much detail. (Homework that's easy is to grade has is a single sequence of steps to check. )
From the point of view of logical deduction, when you want to divide both sides of an equation by a factor F, you actually need to consider the cases 1) F is a non-zero number 2) F is zero. You need to consider how each of those cases provides with a solution to the equation or eliminates certain numbers from being solutions.
For example:
## (x + 2) \sqrt{x - 2} = \sqrt{x-2}##
case 1) Assume ## \sqrt{x-2}## is a non-zero number.
Then we may divide both sides by ##\sqrt{x-2}## obtaining the equation ##(x+2) = 1##, which has the solution x = -1. However, x = -1 makes ##\sqrt{x-2}## undefined, which contradicts the assumption of case 1) that ##\sqrt{x-2}## is a non-zero number. So x =-1 is not a solution to case 1)case 2) Assume ##\sqrt{x-2} = 0##.
This implies x = 2. By substituting x = 2 in the original equation we see that x = 2 is a solution.
Likes Kajan thana
For example:
Thank you made much more sense now, but I feel like case 1 fall under the principle of case 2 for some reason. Or am I thinking in a wrong way?
It's much simpler to rearrange the equation by bringing all terms to one side.
secθ(cosecθ-2) - (cosecθ-2) = 0
(cosecθ-2)(secθ - 1) = 0
Now, either cosecθ = 2 or secθ = 1
The rest is just solving for θ from the two equations above.
Likes Kajan thana
You're thinking the wrong way if you think that assumption made in case 1 applies to case 2. "Non-zero" means ##\neq 0##.
Likes Kajan thana
The way way I think of this question is, if I want to divide the equation by factor F then I will equal the F to zero to find the value of X; then I will pluck it into the original equation. If the LHS = RHS then i will know that we can not divide by that factor so i will make the equation equal to zero then factories it out.
The usual slang is to "plug" it in. ( "To pluck" means "to pull out".)
You are saying that you do the cases in order. Case 1) first. Case 2) second. That doesn't mean that Case 2) "is part of" Case 1).
You consider the case when the factor is zero. You solve for those value(s) of X that make the factor zero. If any of those values make the LHS=RHS in the original equation, you append those values to the list of solutions.
Next you do case 2. Assume the factor is not zero and divide both sides of the equation by the factor. You proceed to find other solutions of the reduced equation. However if a solution of the reduced equation makes the factor zero, it is not appended to the list of solutions of the original equation because it contradicts the assumption of case 2.There are also cases to consider in the simple operation of subtracting an expression from both sides of an equation.
Case 1): The expression is a number.
Case 2) The expression does not represent a number.
Consider the following steps, which omit any mention of cases:
original equation: ##(x+2)\sqrt{x-2} = \sqrt{x-2}##
step 1) ##(x+2)\sqrt{x-2} - \sqrt{x-2} = 0##
step 2) ##( (x+2) - 1) (\sqrt{x-2}) = 0##
step 3) ##(x+1)(\sqrt{x-2}) = 0##
It would seem the solutions to the original equation are x = -1 and x = 2. However x = -1 is not a solution. The flaw in the work is step 2) where ##\sqrt{x-2}## is subtracted from both sides. To subtract an expression from both sides, we must assume the expression is a number. In order for ## \sqrt{x-2} ## to be a number, we must assume ##x \geq 2##.As I mentioned in a previous post, it is tedious work to solve equations by a deductive process. To do so correctly, you must consider cases. Most teachers don't expect students to solve equations by precise logical reasoning. They give guidelines that correct the results of flawed steps such as "Always substitute your answers in the original equation to see if they actually work". That is good practical advice.
Likes Kajan thana
Next you do case 2. Assume the factor is not zero and divide both sides of the equation by the facou proceed to find other solutions of the reduced equation. However if a solution of the reduced equation makes the factor zero, it is not appended to the list of solutions of the original equation because it contradicts the assumption of case 2.There are also cases to consider in the simple operation of subtracting an expression from both sides of an equation.
Thank you for the help, it makes much more sense now. :smile::smile:
Related to Dividing an equation by a variable
1. What is the purpose of dividing an equation by a variable?
Dividing an equation by a variable allows us to solve for a specific unknown value in the equation. It helps us isolate the variable and find its numerical value.
2. Can you divide both sides of an equation by a variable?
Yes, you can divide both sides of an equation by a variable as long as the variable is not equal to 0. This is because dividing by 0 is undefined.
3. What is the result of dividing a variable by itself in an equation?
The result of dividing a variable by itself in an equation is always 1. This is because any number divided by itself is equal to 1.
4. Can dividing an equation by a variable change the solution?
Yes, dividing an equation by a variable can change the solution. This is because it reduces the complexity of the equation and allows for easier solving, potentially leading to a different solution.
5. Are there any rules or restrictions when dividing an equation by a variable?
Yes, when dividing an equation by a variable, we must make sure that the variable is not equal to 0 and that we are not dividing by a variable that is already isolated on one side of the equation. Additionally, we must apply the same operation to both sides of the equation to maintain balance and accuracy.
  • General Math
  • General Math
  • General Math
  • General Math
  • General Math
