MHB Divisibility and Digit Counting: Solving the Five-Digit Number Challenge
The discussion focuses on calculating the number of five-digit numbers that are divisible by 3 and contain the digit 6. A total of 90,000 five-digit numbers exist, with 30,000 of them being divisible by 3. To find those that do not contain the digit 6, the calculation shows there are 17,496 such numbers. Subtracting this from the total divisible by 3 yields 12,504 five-digit numbers that meet the criteria. The use of modulo arithmetic is highlighted as an effective tool for solving this counting problem.
anemone
MHB
POTW Director
How many five digit numbers are divisible by 3 and contain the digit 6?
Mathematics news on Phys.org
My answer is $\boxed{12504}$.
[sp]Altogether, there are $90000$ numbers with five digits. Exactly one-third of these (starting with 10002 and ending with 99999) are divisible by 3. So altogether there are $30000$ five-digit numbers divisible by 3. Now we must subtract all such numbers that contain no 6s.
To count how many five-digit multiples of 3 contain no 6s, look at how many ways there are to choose each of the five digits in the number. There are eight choices for the leading digit (which could be 1,2,3,4,5,7,8 or 9). For each of the second, third and fourth digits, there are nine choices (because we could also have a 0 in those positions). For the final digit, there are three choices. To see why, notice that the sum of the five digits must be a multiple of 3. If the sum of the first four digits is $=1\pmod3$ then the last digit must be 2,5 or 8. If the sum of the first four digits is $=2\pmod3$ then the last digit must be 1,4 or 7. And if the sum of the first four digits is $=0\pmod3$ then the last digit must be 0,3 or 9 (since it can't be 6!). So in every case there are exactly three choices.
Thus altogether there are $8*9^3*3 = 17496$ five-digit multiples of 3 containing no 6s, and subtracting that number from $30000$ we get $12504$ as the answer.[/sp]
Well done, Opalg! Your answer is of course correct and for your information, I didn't solve this problem, however, I did find a solution which was very nearly identical to yours, and I never realized that modulo arithmetic could be a tool to solve counting problems like this.
I like your explanation so much and whenever it has come time to read your explanatory posts, you have never failed to enlighten us with your clever step-by-step working and so I thank you for participating and for this brilliant solution! My hat is truly off to you, Mr. Opalg!
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
