Divisibility of Mersenne numbers?
In summary: Keep up the good work!In summary, the conversation discusses the proof for three parts related to the Mersenne numbers. Part a shows that if one number divides another, then the Mersenne number of the first also divides the Mersenne number of the second. Part b is proven using the Euclidean algorithm and demonstrates that if one number does not divide another, then the greatest common divisor of the Mersenne numbers is the same as the greatest common divisor of the remainders when the larger number is divided by the smaller one. Lastly, part c uses the previous results to show that the greatest common divisor of two Mersenne numbers is the Mersenne number of their greatest common divisor.
morbius27
Let M_n= 2^(n) - 1 be the n-th Mersenne number.
a) Show that, if m|n, then M_m|M_n
b) Show that, if m<n and m does not divide n, then GCD(M_n,M_m) = GCD(M_m,M_r) where r is the remainder of n upon division by m
c) Let m,n be arbitrary natural numbers, and let d = GCD(m,n). Using the above results, show that GCD(M_n,M_n) = M_d
2. The attempt at a solution
So I figured out part a quite easily, by letting n=mk and using congruences, but I'm stuck on part b as I am unsure whether this can by proved using only congruences or if I need to incorporate the Euclidean algorithm. Any ideas?
Hello there! Great job on solving part a, that's a good start. For part b, you can use the Euclidean algorithm to prove it. Here's how you can approach it:
Let m and n be two natural numbers such that m < n and m does not divide n. We can write n = mq + r, where q is the quotient and r is the remainder upon division by m. Since m does not divide n, we know that r is non-zero.
Now, let's consider the GCD of M_n and M_m. By definition, GCD(M_n, M_m) is the largest number that divides both M_n and M_m. We can write M_n = 2^n - 1 and M_m = 2^m - 1. Since m < n, we can express 2^n as (2^m)^q * 2^r. Therefore, M_n can be written as (2^m)^q * 2^r - 1.
Now, let's consider the GCD of M_m and M_r, where r is the remainder of n upon division by m. By definition, GCD(M_m, M_r) is the largest number that divides both M_m and M_r. We can write M_m = 2^m - 1 and M_r = 2^r - 1. Since r is the remainder of n upon division by m, we can express 2^n as (2^m)^q * 2^r. Therefore, M_r can be written as (2^m)^q * 2^r - 1.
Now, we can see that both M_n and M_r have the same form, (2^m)^q * 2^r - 1, which means that they have a common factor of (2^m)^q. Therefore, GCD(M_n, M_m) = GCD(M_m, M_r).
I hope this helps! Let me know if you have any other questions.
FAQ: Divisibility of Mersenne numbers?
What is the definition of a Mersenne number?
A Mersenne number is a number that can be written in the form of 2p - 1, where p is a prime number.
How do you determine if a Mersenne number is divisible by a specific number?
To determine if a Mersenne number is divisible by a specific number, you can use the Lucas-Lehmer test. This test involves a recursive formula that checks if the remainder of the Mersenne number divided by the specific number is equal to 0.
Are all Mersenne numbers divisible by 2?
Yes, all Mersenne numbers are divisible by 2 as 21 - 1 = 1.
How many Mersenne numbers are known to be prime?
As of 2021, there are 51 known Mersenne prime numbers. These are the only known Mersenne numbers that are also prime numbers.
Can a Mersenne number be divisible by more than one number?
Yes, a Mersenne number can be divisible by more than one number. For example, 211 - 1 = 2047 is divisible by both 23 and 89.
