DIY Particle Accelerator (with magnetic ball)
In summary, the "DIY Particle Accelerator (with magnetic ball)" project demonstrates how to create a simple particle accelerator using everyday materials. The setup involves a magnetic ball that is propelled through a tube, utilizing magnetic fields to accelerate it. The project highlights basic principles of physics, including magnetism and particle motion, while providing a hands-on learning experience in experimental science. Safety precautions and detailed instructions for assembly are also included to ensure a safe and educational exploration of particle acceleration concepts.
acun
Hi, currently I am working on a particle accelerator. In the project, basically, by the magnetic force generated by the coil, the magnetic ball is accelerated in a circular path. I first thought that giving current all the time to the coil wouldn't cause problems. However, as it turned out if the current is given to the coil continuously, the magnetic ball oscillates and eventually stops ( at 3:44). I couldn't understand why it happens, any help is appreciated.
You have answered the question by yourself in the video, which makes me think you didn't really get here looking for help, but just to show your project.
Nice one.
Well, you clearly didn't understand the question. I am still doing my project, the project you see in the video belongs to Hyperspace Pirate YouTube channel and it is a FINISHED project (probably I should have emphasized it more). I liked his project and as a guide, I am using his project. I added a video link in case I couldn't explain my problem very well. In his video, he says "Because the electromagnet will always pull it in from either side", clearly you found this a comprehensive explanation, but I didn't. My question is still there. Why electromagnet pull it in from either side? What is the physical explanation of it?
I misunderstood it as well. Huh.
It is the physical effect behind a solenoid actuator. A divergent magnetic field will attract a ferrous piece of material into the higher concentration region of the B-field in the solenoid.
https://www.doeeet.com/content/eee-components/passives/solenoids-explained/
https://science.howstuffworks.com/solenoid.htm
So to make a "particle accelerator" like this work, you will need some extra sensors to detect where the balls are, and turn on the attractive solenoid current (and resulting divergent magnetic field) as the ball approaches, and switch the current off around the time when the ball is passing through the middle of the coil.
Does that make more sense now? :smile:
Or you need to time the magnets to turn on and off at the right times, and then roll the ball with the right speed.
You are assuming *way* too much coordination on my part...!
  • Haha
Likes Vanadium 50 and Tom.G
I hate to provide too much help, especially since the OP was a) unclear, and b) got all huffy about it, as if it were out fault. However, consider one magnet. When the ball is rolling towards the magnet, and the magnet is on, the ball will feel the force towards the magnet and speed up. Then, when it passes the magnet, it will again feel a force towards the magnet, and slow down.
You want the magnets off for this, until the ball gets closer to the next magnet in the chain, then you can turn it on again. This is most easily accomplished with a low frequency AC source and a half-wave rectifier.
There is lots more that can be said, but it is the OPs project, not mine.
Pity the OP seems to have lost interest. The physics of making this work has some interesting aspects to it. Oh well.
FAQ: DIY Particle Accelerator (with magnetic ball)
What is a DIY particle accelerator with a magnetic ball?
A DIY particle accelerator with a magnetic ball is a simple, homemade device that uses magnetic fields to accelerate a small magnetic ball along a track. It is often used as an educational tool to demonstrate basic principles of particle acceleration and magnetism.
How does the magnetic ball get accelerated in a DIY particle accelerator?
The magnetic ball gets accelerated through a series of magnetic fields created by strategically placed magnets along the track. As the ball moves closer to each magnet, it is pulled forward by the magnetic force, gaining speed. This process continues as the ball moves from one magnet to the next, effectively accelerating it.
What materials do I need to build a DIY particle accelerator with a magnetic ball?
To build a DIY particle accelerator with a magnetic ball, you will need a magnetic ball (such as a neodymium magnet ball), several strong magnets, a non-magnetic track for the ball to roll on, and some basic tools like glue and tape to secure the magnets in place. Additional materials may include a ruler or measuring tape to ensure precise placement of the magnets.
Is it safe to build and use a DIY particle accelerator with a magnetic ball?
Building and using a DIY particle accelerator with a magnetic ball is generally safe if proper precautions are taken. It is important to handle strong magnets carefully to avoid pinching fingers or damaging electronic devices. Additionally, the project should be conducted in a controlled environment, away from sensitive equipment and with appropriate supervision, especially if children are involved.
What educational concepts can be learned from a DIY particle accelerator with a magnetic ball?
A DIY particle accelerator with a magnetic ball can help learners understand several key concepts in physics, including magnetic fields, forces, acceleration, and energy transfer. It also provides a hands-on experience with constructing and experimenting with basic scientific apparatus, fostering a deeper understanding of experimental design and problem-solving.
