Do 40 Watt 1 Ohm resistors exist
In summary: It is also very large and expensive. In summary, the conversation discusses using a power supply to draw 40 Amps and the potential danger of doing so. The possibility of using car battery cables, resistors, and light bulbs as alternatives is also mentioned. The conversation also touches on the use of carbide lights and party lines in the past, and how technology has advanced since then. A specific resistor that may work for this project is mentioned, but it is noted that it may not be suitable for RF work and is quite large and expensive.
houlahound
908
223
My local hobby store says no.
I want to draw a full 40 Amps from my power supply to play with a few formulas that give the magnetic field strength as a function of distance and current from a wire. The wire will be car battery cables. I have a calibrated Gauss meter for field measurements.
Would this set up work, what catalogues have a 40 Watt 1 Ohm resistor?
Have you worked out how much power that resistor is really going to be dissipating ?
If nothing else the set up is potentially dangerous with real possibility of getting burns and arc flashes .
The resistors are readily available though :
[/PLAIN]
Near enough
[/PLAIN]
Dead on but not quite as good
Your volts, amps, watts do not make sense.
I could be missing something ...
40 watts through a 1 Ohm resister - that 6.3 volts and 6.3 amps.
40 amps through a 1 Ohm resistor - requires an emf of 40 v, thus your resistor needs to be 1600 watts.Try hooking up your power supply to lamps or headlights in series/parallel. ( 12 volt headlight draw about 40 to 60 watts, or are about 5 Ohms.)
Likes CWatters
Holy crap that's the resistor from hell.
Thanks all links.
Didn't think the numbers through before i posted.
My power supply, switched mode, is rated at 40 Amps. It is a variable voltage to 12 volts. I use it for my radio but never measured what current it draws. My license has limited watts for transmission. Don't know what antenna power equates to 40 Amps from the power supply.
That is a 2000W answer to a 40W question - in short yes, they exist... there are a few ways to do this. But car headlamps are a good - low cost solution. Ray Bans anyone?
I got some carbon rods about half inch diameter from an old time movie projector, will put them in sliding contact to make a variable resistance...what could go wrong?
Cool link, I wanted to build a lighting museum at one point, still might.
I am prolly the only living guy that lived in a time and place that carbide lights were the only source of lighting.
The good thing was we could take them to fishing holes and blow them up and get a feed of fresh fish, try doing that with yr fancy schmancy LED's.
LOL --- you going to read, or you going to fish?
i thought i was the only one here that old.
Used to do spelunking in Missouri.
Ha, ever use a party line ie a piece of fencing wire strung between trees for miles. A dynamo powered phone with a lead attached to the line by swinging a rock tied to one end to wrap around the party line. Lightning would blow your ears out or worse.
Everyone could listen to your conversations, and everyone could talk at the same time. Might have been why multiplexing and frequency division on a single optical fibre was born.
I still have a dynamo, use it to show kids induction, gives a hell of a boot.
If anyone would have tried to say one day we will have an internet they would have been burned at the stake for witchcraft.
Likes jim hardy
Thanks all links.
That resistor is wire wound, so may or may not be suitable for RF work.
Related to Do 40 Watt 1 Ohm resistors exist
1. Do 40 Watt 1 Ohm resistors actually exist?
Yes, 40 Watt 1 Ohm resistors do exist. They are not very common, but they are available from certain electronic component suppliers.
2. What is the purpose of a 40 Watt 1 Ohm resistor?
A 40 Watt 1 Ohm resistor is typically used in high power applications such as power supplies, amplifiers, and electric heaters. It is designed to dissipate a large amount of power while maintaining a specific resistance value.
3. Can I use multiple resistors to achieve a 40 Watt 1 Ohm resistance?
Yes, it is possible to use multiple resistors in parallel or in series to achieve a 40 Watt 1 Ohm resistance. However, it is important to make sure that the resistors can handle the power and that their combined resistance is accurate.
4. Are 40 Watt 1 Ohm resistors safe to use?
Yes, as long as they are used within their specified power and temperature ratings, 40 Watt 1 Ohm resistors are safe to use. It is important to follow proper handling and installation procedures to prevent damage or injury.
5. How do I know if a 40 Watt 1 Ohm resistor is the right choice for my project?
The decision to use a 40 Watt 1 Ohm resistor will depend on the specific requirements of your project. You should consider the power and resistance values needed, as well as the temperature and tolerance ratings of the resistor. It may also be helpful to consult with an expert or refer to a resistor selection guide.
