Do all airfoils (infinite wing) have a flow separation?
In summary: Regardless of wing geometry, spanwise flow signals that there is a spanwise pressure gradient that exists. This is fundamentally different than the behavior of a 2D boundary layer on a 2D wing geometry. In that sense, a 2D wing with spanwise flow has a lot of fundamental similarities (from a stability and transition point of view) to a swept wing, which has spanwise flow by default.
MaxKang
Do all airfoils(infinite wing) have a flow separation at a finite or zero AOA? I wonder if there exists such an airfoil that despite the presence of adverse pressure gradients, exhibits no flow separation phenomena, perhaps turbulent intensity could be high enough to sustain enough speed near the surface of a wing so that a back flow does not occur. Do most commercial aircraft have a flow separation?
Thank you!
Flow separation results in increased drag, a decrease of lift, and possibly a stall. Most airplane wings do not have flow separation in normal flight. The flow is laminar.
CORRECTION: Should not say "The flow is laminar." (see @boneh3ad post #3 )
I'd be careful saying the flow is laminar. Most airplane wings have turbulent boundary layers over the majority of their surfaces.
Likes FactChecker
Indeed the boundary layer and its turbulent flow increase as laminar flow breaks down, particularly after the point of peak thickness. The extent of this breakdown is affected by surface friction, aerofoil shape, velocity and Reynolds Number. Spanwise flow, such as exists with finite wings (and spanwise changes of geometry) may trouble the trailing edge and hasten the breakdown of chordwise flow, but the effect is negligible at low angles of attack. An infinite wing is therefore not immune to flow separation, regardless of aerofoil choice. All aircraft exhibit flow separation, although suction holes are being considered for Flying Wings (or BWBs as they are now termed) to minimize this.
Your question is a little confused. Flow separation results in turbulence but the boundary layer can remain within acceptable limits or, in extreme cases, be controlled by vortices.
This isn't true. In fact, spanwise flow can (and does) fundamentally alter the laminar-turbulent transition mechanism in a boundary layer. This is why swept and unswept wings have fundamentally different transition behavior.
You're right boneh3ad. But since the topic was about aerofoils and infinite wings, I took the comparison to be limited to straight wings. I suppose an infinite swept wing is no less likely than an infinite straight one but that would be a whole new topic.
In a truly 2D boundary layer on an infinite swept wing, the transition process is dominated by 2D waves called Tollmien-Schlichting waves. Adding in a spanwise component means, at the very least, that you now have another competing mechanism called the crossflow instability. How much spanwise flow dictates whether or not that becomes important. My point was simply that spanwise flow cannot be assumed to have a negligible effect, even at low ##\alpha##. You can get a wing to transition due to crossflow at ##\alpha = 0^{\circ}##, which obviously has a great effect on whether or not separation occurs and where.
Related to Do all airfoils (infinite wing) have a flow separation?
1. What is flow separation?
Flow separation is the detachment of the boundary layer of air from a surface, such as an airfoil, due to adverse pressure gradients and/or changes in the direction of airflow. This can lead to loss of lift and increased drag on the object.
2. Why do some airfoils experience flow separation while others do not?
The occurrence of flow separation is dependent on various factors such as the shape and angle of the airfoil, the speed and density of the air, and the surface roughness of the airfoil. Different airfoils are designed for different purposes and operating conditions, so some may be more prone to flow separation than others.
3. Can flow separation be prevented on all airfoils?
Flow separation can be minimized by designing airfoils with smooth surfaces and appropriate angles of attack. However, it is almost impossible to completely eliminate flow separation on all airfoils, especially at high speeds and turbulent conditions.
4. How does flow separation affect the performance of an aircraft?
Flow separation can significantly reduce the lift generated by an airfoil, which can affect the overall lift-to-drag ratio of an aircraft. This can result in decreased efficiency and increased fuel consumption. Flow separation can also cause instability and lead to loss of control in extreme cases.
5. Can flow separation be controlled or managed?
In some cases, flow separation can be controlled by using devices such as vortex generators or boundary layer control systems. These can help to delay or prevent flow separation on airfoils. However, these methods may add weight and complexity to the aircraft design. Additionally, careful design and engineering of the airfoil shape and angle of attack can also help to manage flow separation.
  • Aerospace Engineering
13K
  • Classical Physics
  • Mechanics
