PeterDonis
Mentor
- 49,059
- 25,147
stevebd1 said:##\sqrt{\Delta}=0## occurs at the event horizon ##(r_+)##
Ah, yes, you're right, I was misremembering which coefficient is which.
stevebd1 said:the static limit is defined by ##g_{tt}=0##
Yes, which means that an integral curve of ##\partial / \partial t## is null at the static limit and spacelike inside it. That is why there can't be any static observers (observers following integral curves of ##\partial / \partial t##, i.e., who have constant spatial coordinates) inside the static limit.
stevebd1 said:##v_s=(\Omega_s-\omega)R/\alpha## becomes meaningless at the photon sphere
Yes, I see, I was mixing up ##v_s## and what you were calling "frame dragging velocity"; the latter is what becomes meaningless at the static limit (since at and inside the static limit there are no static observers).
Let me rephrase some of this in the terminology I am used to seeing. The angular velocity of a ZAMO (zero angular momentum observer) is given by
\Omega_Z = - \frac{g_{t \phi}}{g_{\phi \phi}} = \frac{2 M a r}{\rho^2 \left( r^2 + a^2 \right) + 2 M r a^2 \sin^2 \theta}
This angular velocity is what you have been calling the "frame dragging rate" ##\omega##. In the region outside the static limit, where there are static observers (observers with zero angular velocity, whose spatial coordinates do not change), we can convert ##\Omega_Z## to a velocity, the velocity of a ZAMO relative to a static observer at the same spatial location, by basically the same method you are using to convert ##\Omega_s##, the angular velocity required for a stable orbit, to a velocity; that is, we have
v_Z = \Omega_Z \frac{R}{\alpha}
where ##R## and ##\alpha## are the reduced circumference and redshift factor as you have defined them. This could be called the "frame dragging velocity", provided we remember that it is only valid outside the static limit.
This also makes clear that what you are calling ##v_s##, the "velocity" required for a stable orbit, is not velocity relative to a static observer; it is velocity relative to a ZAMO (since ##\Omega_s - \omega = \Omega_s - \Omega_Z## is what appears in the formula). Since there are ZAMOs all the way down to the horizon, ##v_s## will be meaningful all the way down to the horizon as you have defined it. But we would only be able to define a velocity for a stable orbit relative to a static observer outside the static limit; that velocity would be
v_S = \Omega_s \frac{R}{\alpha}
(note that ##\Omega_s## appears here instead of ##\Omega_s - \omega##).
