Do Black Holes End up as Quark Stars? and quantum gravity
In summary, the paper discusses the possibility that collapsing black holes may actually end up as quark stars rather than singularities. This is based on the idea that the Pauli exclusion principle could prevent the collapse of a black hole and result in an explosion, leaving behind a stable quark star as the remnant core. This concept challenges the traditional understanding of black holes and could have implications for string theory, loop quantum gravity, and other areas of physics. However, the paper has not been published in a peer-reviewed journal and has not been widely accepted by experts in the field. While it is not implausible, it remains a speculative idea.
  • #36
Probably the sentence should have been "I think at 0.9 SR the gravitational acceleration would be about 1.23 that at 1.0 SR."
  • #37
PeterDonis said:
The TOV equation assumes static equilibrium. But static equilibrium is not possible for an object with a surface radius less than 9/8 SR = 1.125 SR, by Buchdahl's Theorem. Any object with a surface radius smaller than this must be collapsing; it cannot be static. So the TOV equation does not apply. (Also, the "gravitational acceleration" goes to infinity at 1.0 SR; the TOV equation is not the equation that determines the gravitational acceleration.)
I think "the gravitational acceleration goes to infinity at 1.0 SR" is just plain wrong. Gravitational acceleration = force/mass = F/m. Why should a contracting object exert infinite force at some point? That would be like creating energy for free.
  • #38
Have you actually done the math? This is a common homework problem for physics students studying GR; it is not at all contentious.
In GR, gravity is not a "force", and you can't use Newtonian reasoning like this. The proper acceleration required to maintain a constant altitude goes to infinity at the horizon because of the geometry of spacetime, not because of any "force" becoming infinite.
  • #39
Please give an internet source with the solution.
  • #40
With your rude tone, you don't deserve this, however here is such a link:
http://en.wikipedia.org/wiki/Proper_acceleration#Four-vector_derivations
Note the formula for acceleration needed maintain hovering positions, measured locally by an accelerometer:
This becomes infinite as r decreases to rs.
  • #41
You are the one making the extraordinary claim (that GR is wrong), so it's up to you to give references. However, PAllen was nice and gave you the formula. Please bear in mind the PF rules about personal theories and making extraordinary claims without references to back them up. If you continue to repeat erroneous claims, you will receive a warning.
Likes mfb
  • #42
"With your rude tone, you don't deserve this, however here is such a link"
Please accept my apologies if I am coming across as rude. Perhaps you are interpreting tenacity for rudeness. I'll be posting one last question about black hole spin rates shortly. Do not feel obligated to answer it if I'm trying your patience.
  • #43
Don't the rather slow and finite spin rates of the fastest spinning black holes imply a large object within the black hole? Its logical that the equatorial velocity of the fastest spinning black holes would be a large fraction of the speed of light. If an equator has a radius of 10 - 25 km and a spin rate of 1000 revolutions per second, its tangental velocity would be 0.2c - 0.5c, which seem reasonable. But if the equator only had a radius of 1 km and a spin rate of 1000 RPS the equatorial velocity would only be 0.02c, which seems illogical for the fastest spinning black holes.
  • #44
A black hole with spin can have any spin, and this is unrelated to any surface or object inside the horizon. The BH would end up with roughly the same spin as just before final collapse.The GR solution describing such objects is the Kerr solution:
See:
https://en.wikipedia.org/wiki/Rotating_black_hole
and https://en.wikipedia.org/wiki/Kerr_metric
  • #45
No. I don't understand why you think it would.
A rotating black hole doesn't have an "equatorial velocity". It has an angular momentum, and you can compute an angular velocity from this that is sometimes loosely interpreted as the "angular velocity of the horizon". But the hole doesn't have a surface, so the angular velocity doesn't translate into an ordinary speed. An object rotating around the hole with the angular velocity of the horizon, at the horizon, would have to be moving at the speed of light; no actual object can do this (just as no actual object can "hover" at the horizon of a non-rotating black hole).
In short, you are thinking of the hole as an ordinary rotating object. It isn't, and trying to reason as though it is will lead you to incorrect conclusions.
  • #46
A couple of things here. firstly black holes are observed to spin slower than they are actually spinning due to gravitational and relativistic redshift. For instance, when an article says '..the black hole is spinning at close to the speed of light..' they should add 'as observed from infinity'. Also what is being measured isn't strictly speaking the BH itself, but the frame dragging rate of the spacetime being dragged around the BH. The tangential velocity of the frame dragging rate for a black hole (as observed from infinity) at various r is-
[itex]v=\omega R[/itex]
where [itex]\omega[/itex] is the frame dragging rate (or angular velocity) and [itex]R[/itex] is the reduced circumference, but the actual local tangential velocity is-
[itex]v=(\omega R)/\alpha[/itex]
where [itex]\alpha[/itex] is the reduction factor or redshift. For the full equations for [itex]\omega, R[/itex] and [itex]\alpha[/itex], see this old library post- What is frame dragging.
Secondly, if the BH has any kind of spin, no matter how small, it will have an ergosphere [itex](r_{e+})[/itex] just outside the horizon [itex](r_+)[/itex], and if it has an ergosphere, there will be a region where spacetime is rotating faster than c relative to infinity so technically, all BH's locally spin at c at the ergosphere boundary. For the equations for [itex]r_{e+}[/itex] and [itex]r_+[/itex], see this old library post- https://www.physicsforums.com/threads/radius-of-a-black-hole.762981/
When observed from infinity, this rapid rotating of the ergosphere will not be detected, and the event horizon will appear to spin at anything up to c (with c being maximal, i.e. a/M=1), whereas locally, the boundary of the ergosphere will always be spinning at c which will increase exponentially as you proceed through the ergosphere to the event horizon (it's also worth noting that a BH's spin is normally measured by the location of the marginally stable orbit (MSO) which is at 6M for a static BH (a/m=0) and at M for a BH at maximum spin (a/m=1).
  • #47
Actually, you can't observe a black hole's spin directly at all. You can only observe the motion of objects close to its horizon, and note that, the closer to the horizon they get, the more constrained their angular velocity is. In the limit of an object at the horizon (which is not actually physically possible, as I've said before), the angular velocity of the object can only have one value, which is often (somewhat sloppily) called "the angular velocity of the horizon".
As I said before, translating this angular velocity into a "speed" has a number of issues involved. See below.
No, what is being observed, as above, is the motion of objects close to the horizon. The possible worldlines for such objects are affected by the frame dragging rate, so by measuring them, you can indirectly measure frame dragging. But what you measure, even indirectly, is not a velocity; at best, it's an angular velocity. See further comments below.
v=\omega R$$
where ##\omega## is the frame dragging rate (or angular velocity) and ##R## is the reduced circumference, but the actual local tangential velocity is-
##v=(\omega R)/\alpha##
where ##\alpha## is the reduction factor or redshift.
What is the physical meaning of these velocities? How would you measure them? I think that, if you try to answer these questions, you will find a number of issues lurking that you haven't considered.
stevebd1 said:
if the BH has any kind of spin, no matter how small, it will have an ergosphere ##(r_{e+})## just outside the horizon ##(r_+)##, and if it has an ergosphere, there will be a region where spacetime is rotating faster than c relative to infinity
This is, at best, extremely sloppily phrased, and at worst, simply wrong. I strongly recommend taking some time to think through the physical meaning of what's going on. Spacetime does not "rotate", and you can't observe spacetime directly; you can only observe the motion of objects. An object inside the ergosphere cannot be static; that is, it cannot remain at constant spatial coordinates. In other words, it cannot have zero angular velocity. But that in no way translates to "rotating faster than c relative to infinity"; I don't know where you're getting that from.
I don't know where you're getting this from either. What references are you using?
  • #48
'At a point r_e it becomes impossible to counteract the rotational sweeping force. The particle is in a kind of space-time maelstrom. The surface determined by r_e is the static limit: from there in, you cannot avoid rotating. Space-time is rotating here in such a way that you cannot do anything in order to not co-rotate with it.'
Source- Introduction to Black Hole Astrophysics - Page 51
'..the (outer) event horizon of a Kerr black hole is surrounded by a second critical surface, the static limit, which has the shape of an oblate spheroid and touches the event horizon at the poles. The space between these two surfaces is called the ergosphere. Within the ergosphere the spacetime is dragged in the direction of the spinning black hole at a speed greater than c with respect to the outside universe at rest, while at the static limit this speed equals c.'
Source- Extreme Environment Astrophysics - Page 17
'In a rotating black hole, the ergosphere is associated with the stationary limit, the location at which space-time is flowing at the speed of light'
Source- http://www.astro.cornell.edu/academics/courses/astro201/ergosphere.htm (Cornell Centre for Astrophysics and planetary science)
'All objects in the ergosphere become dragged by a rotating spacetime.'
(the phrase rotating spacetime is highlighted and actually links to the frame-dragging page)
Source- Penrose process (Wikipedia)
While I understand that frame dragging cannot be measured directly at the event horizon or at the boundary of the ergosphere, it can be predicted by establishing where the marginally stable orbit is (which is what I state at the end of my post). A number of recent articles have stated that '..the black hole is spinning at half the speed of light.' or '..the black hole is spinning at close to the speed of light making it almost maximal'. I imagine these statements are based on where the MSO is which is normally defined by the inner edge of the accretion disk where there's plenty of matter sending pulses of radiation. For example, if a black hole has an MSO at 4M, then working backwards using the equations (eq 32, http://relativity.livingreviews.org/Articles/lrr-2013-1/articlese2.html ) to establish the MSO, the rate of spin can be established, in this case, the spin would be a/M=~0.56. Based on this, using [itex]\omega R[/itex], it can be predicted that the frame-dragging rate at the event horizon is 0.305c as observed from infinity, (the black hole is spinning at nearly a third the speed of light)
One source of [itex]\omega R/\alpha[/itex] is-
[tex]v_s=(\Omega_s-\omega)\frac{R}{\alpha}[/tex]
where [itex]v_s[/itex] is the local velocity required for a stable orbit and [itex]\Omega_s[/itex] is the angular velocity required for stable orbit. This equation can be rewritten as-
[tex]v_s=(\Omega_s-\omega)\frac{\Sigma^2\sin\theta}{\rho^2\sqrt{\Delta}}[/tex]
which can be seen in some form in this paper, equation at the top of page three. Remove [itex]\Omega_s[/itex] and you have the local tangential velocity of the frame-dragging rate. Remove the [itex]\alpha[/itex] component and you have the tangential velocity of the frame-dragging rate as observed from infinity. I've also seen the equation in various forms elsewhere.
This is backed up to some extent when you look at the boundary for the ergosphere (or the static limit). If we look at the ergosphere of a 3 solar mass BH with a spin parameter of 0.95 (numbers rounded up). Note that r is the coordinate radius and R is the reduced circumference in the azimuth plane-
[tex]r_e=M+ \sqrt{M^2-a^2 \cos^2\theta}[/tex]
See what is frame dragging to calculate [itex]\omega, R[/itex] and [itex]\alpha[/itex]
For [itex]\theta=90[/itex], frame-dragging rate at [itex]r_e[/itex] (8861.099m) is 3.6937e-05 rads/s, R=10,674.7743m, [itex]\alpha[/itex]=0.394296 which means v=1c
For [itex]\theta=45[/itex], frame-dragging rate at [itex]r_e[/itex] (7712.59695m) is 4.8909e-05 rads/s, R=6559.6475m, [itex]\alpha[/itex]=0.320827 which means v=1c
For [itex]\theta=5[/itex], frame-dragging rate at [itex]r_e[/itex] (5861.7987m) is 8.06154e-05 rads/s, R=629.7636m, [itex]\alpha[/itex]=0.050769 which means v=1c
which collaborates with the previous statements that spacetime is being dragged at 1c at the ergosphere boundary (or the static limit).
I'll admit, there appears to be a coordinate singularity at [itex]\theta=0[/itex] though that just might be the way I've got things set up.
[itex]\omega R[/itex] also features in this link (in this case, [itex]R[/itex] is written as [itex]\varpi[/itex]), albeit in an algebraic sense. Wheeler also mentions 'tangential velocity [itex]Rd\phi/dt[/itex] as recorded by the Kerr bookkeeper' in Exploring Black Holes (where [itex]d\phi/dt=\omega[/itex]).
  • #49
stevebd1 said:
One source of ωR/α\omega R/\alpha
What are ##R## and ##\alpha##?
stevebd1 said:
##v_s## is the local velocity required for a stable orbit
I assume that by "local velocity" you mean "velocity relative to a static observer at the same spatial coordinates". But in the ergosphere there are no static observers--that is, there are no timelike worldlines with constant spatial coordinates/zero angular velocity; all timelike worldlines have positive angular velocity. So "local velocity" as you are using the term has no meaning in the ergosphere. (Your second expression for ##v_s## makes this clear, since ##\sqrt{\Delta} = 0## at the static limit, and becomes imaginary inside the static limit since ##\Delta## itself is negative.)
As you get closer and closer to the horizon, the range of allowed angular velocities for timelike worldlines gets smaller and smaller; in the limit at the horizon, there are no timelike worldlines at all that do not fall into the hole, and the outgoing null worldlines that stay at the horizon all have one fixed positive angular velocity, which is sometimes referred to as the "angular velocity of the hole" (a more precise term would be "angular velocity of the horizon"). This is the correct way of saying what the various sources you quote say sloppily.
stevebd1 said:
Remove ##\Omega_s## and you have the local tangential velocity of the frame-dragging rate.
What do you mean by "remove ##\Omega_s##? And what do you mean by "the local tangential velocity of the frame-dragging rate"? Remember that, as above, there are no static observers inside the static limit, so there is no meaning to the concept of "local velocity" relative to such observers.
If you are not familiar with the concept of Zero Angular Momentum Observers (ZAMOs) in Kerr spacetime, I strongly recommend learning about it. This family of observers gives a much better way of physically realizing things like what you are calling the "frame dragging rate" without having to use the sort of sloppy terminology that the sources you refer to use. This paper has a good discussion of ZAMOs:
http://arxiv.org/abs/1408.6316
Another very good source is Visser's paper on Kerr spacetime:
http://arxiv.org/abs/0706.0622
stevebd1 said:
Remove the ##\alpha## component and you have the tangential velocity of the frame-dragging rate as observed from infinity.
I'm not sure what you mean by "remove the ##\alpha## component", but if you mean removing the "time dilation factor" from the formula to adjust for the "rate of time flow" at infinity, it's important to recognize that the numbers you get that way have no physical meaning; they are just "bookkeeper" numbers, as the Wheeler reference you mention indicates. Calling such a number "the velocity observed at infinity" is, IMO, very misleading; it's the sort of thing that leads to misconceptions like thinking that objects "freeze" at a black hole's horizon and never fall inside.
  • #50
[itex]\sqrt{\Delta}=0[/itex] occurs at the event horizon [itex](r_+)[/itex], the static limit is defined by [itex]g_{tt}=0[/itex] where
[tex]g_{tt}=1-2Mr/\rho^2[/tex]
[itex]v_s=(\Omega_s-\omega)R/\alpha[/itex] becomes meaningless at the photon sphere where [itex]v_s=1[/itex] which ranges from 3M for a static BH to 1M for a/M=1 (eq 30, http://relativity.livingreviews.org/Articles/lrr-2013-1/articlese2.html ) (though for an object of mass, the last stable orbit (MSO) ranges from 6M for a/M=0 to 1M for a/M=1). [itex]\ v_s[/itex] reduces to the static solution for a/M=0.
[itex]R[/itex] is the reduced circumference where [itex]R=(\Sigma/\rho)\sin\theta[/itex], [itex]\ \alpha[/itex] is the reduction factor (or redshift) where [itex]\alpha=(\rho/\Sigma)\sqrt{\Delta}[/itex]. [itex]\ R[/itex] is equal to coordinate r in schwarzschild metric but in Kerr metric, [itex]R[/itex] becomes slightly greater than coordinate r. [itex]\ \alpha[/itex] reduces to [itex]\sqrt{1-2M/r}[/itex] when a/M=0.
(For the definitions of [itex]\Sigma, \rho[/itex] and [itex]\Delta[/itex] see this link).
  • #51
stevebd1 said:
##\sqrt{\Delta}=0## occurs at the event horizon ##(r_+)##
Ah, yes, you're right, I was misremembering which coefficient is which.
stevebd1 said:
the static limit is defined by ##g_{tt}=0##
Yes, which means that an integral curve of ##\partial / \partial t## is null at the static limit and spacelike inside it. That is why there can't be any static observers (observers following integral curves of ##\partial / \partial t##, i.e., who have constant spatial coordinates) inside the static limit.
stevebd1 said:
##v_s=(\Omega_s-\omega)R/\alpha## becomes meaningless at the photon sphere
Yes, I see, I was mixing up ##v_s## and what you were calling "frame dragging velocity"; the latter is what becomes meaningless at the static limit (since at and inside the static limit there are no static observers).
Let me rephrase some of this in the terminology I am used to seeing. The angular velocity of a ZAMO (zero angular momentum observer) is given by
\Omega_Z = - \frac{g_{t \phi}}{g_{\phi \phi}} = \frac{2 M a r}{\rho^2 \left( r^2 + a^2 \right) + 2 M r a^2 \sin^2 \theta}
This angular velocity is what you have been calling the "frame dragging rate" ##\omega##. In the region outside the static limit, where there are static observers (observers with zero angular velocity, whose spatial coordinates do not change), we can convert ##\Omega_Z## to a velocity, the velocity of a ZAMO relative to a static observer at the same spatial location, by basically the same method you are using to convert ##\Omega_s##, the angular velocity required for a stable orbit, to a velocity; that is, we have
v_Z = \Omega_Z \frac{R}{\alpha}
where ##R## and ##\alpha## are the reduced circumference and redshift factor as you have defined them. This could be called the "frame dragging velocity", provided we remember that it is only valid outside the static limit.
This also makes clear that what you are calling ##v_s##, the "velocity" required for a stable orbit, is not velocity relative to a static observer; it is velocity relative to a ZAMO (since ##\Omega_s - \omega = \Omega_s - \Omega_Z## is what appears in the formula). Since there are ZAMOs all the way down to the horizon, ##v_s## will be meaningful all the way down to the horizon as you have defined it. But we would only be able to define a velocity for a stable orbit relative to a static observer outside the static limit; that velocity would be
v_S = \Omega_s \frac{R}{\alpha}
(note that ##\Omega_s## appears here instead of ##\Omega_s - \omega##).
  • #52
The detailed answers here mostly describe what happens in the vacuum outside the singularity or object in a black hole. Does anybody want to add something about the following statements from the original poster's paper: "As a result of the continual gravitational collapse of the black hole, a stage will be reached when ... the entire matter in the black hole will be converted into quark - gluon plasma permeated by leptons. . ... We have an ultrahigh energy particle accelerator in the form of a gravitationally collapsing black hole, which can, in the absence of any physical process inhibiting the collapse of the black hole to a singularity, accelerate particles to an arbitrarily high energy and momentum without any limit."
  • #53
In the classical model of gravitational collapse to a black hole, yes, the collapsing matter will heat up, in principle to unbounded temperatures, and will pass through various states of matter appropriate to those temperatures (quark-gluon plasma permeated by leptons is just the state of matter appropriate to a very high temperature).
Defining the energy of individual particles in the collapsing matter is problematic, however, because the region of spacetime in which the collapse occurs is not stationary; in other words, there is no time translation or symmetry, so there is no natural definition of energy. All we can say is that the stress-energy tensor describing the collapsing matter obeys the local conservation law that its covariant divergence is zero.
  • #54
Even if your analysis has problems defining energy there should be conservation of energy in a collapsing black hole; energy is not created. If the collapsing contents can not be accelerated to infinite energy the resulting object should have a finite size.
  • #55
If you can't define "energy", how can you check whether it's conserved? In a non-stationary spacetime, there is no global definition of "energy", so there is way to even given meaning to the question of whether energy is conserved.
Locally, energy is conserved--more precisely, as I said before, the stress-energy tensor obeys the local conservation law that its covariant divergence is zero. But that's only local; it doesn't give you any way to define a globally conserved "energy".
This has no meaning because there is no way to define what "accelerated to infinite energy" means. The only local notion of "energy" is the one I referred to above, that the stress-energy tensor obeys a local conservation law. If you actually look at the underlying math, instead of trying to reason using imprecise ordinary language, you will see why this is the case.
  • #56
  • #57
No matter what math you use and even if your model can't define energy, there's a good argument that the total kinetic energy is less than or equal to Mc^2
  • #58
Ok, then please give the argument, in detail, with references. I think you will find that, since "kinetic energy" is frame-dependent, the argument does not prove what you think it does.
  • #59
kodama said:
this paper
Do Black Holes End up as Quark Stars ?
R.K.Thakur
(Submitted on 25 Feb 2007)
The possibility of the existence of quark stars has been discussed by several authors since 1970. Recently, it has been pointed out that two putative neutron stars, RXJ 1856.5 - 3754 in Corona Australis and 3C58 in Cassiopeia are too small and too dense to be neutron stars; they show evidence of being quark stars. Apart from these two objects, there are several other compact objects which fit neither in the category of neutron stars nor in that of black holes. It has been suggested that they may be quark stars.In this paper it is shown that a black hole cannot collapse to a singularity, instead it may end up as a quark star. In this context it is shown that a gravitationally collapsing black hole acts as an ultrahigh energy particle accelerator, hitherto inconceivable in any terrestrial laboratory, that continually accelerates particles comprising the matter in the black hole. When the energy \textit{E} of the particles in the black hole is ≥102GeV, or equivalently the temperature \textit{T} of the matter in the black holes is ≥1015K, the entire matter in the black hole will be converted into quark-gluon plasma permeated by leptons. Since quarks and leptons are spin 1/2 particles,they are governed by Pauli's exclusion principle. Consequently, one of the two possibilities will occur; either Pauli's exclusion principle would be violated and the black hole would collapse to a singularity
This looks wrong to me. If we disregard GR for a second, there is no limit how small a ball of degenerate matter supported merely by Pauli exclusion principle can be. It's untrue that it can't be compressed.
For example, if you add more carbon to a carbon white dwarf, it _shrinks_. How is that possible? Easy. If some of degenerate electrons are pushed to states with higher momentum, you now can cram more electrons into same volume, without violating exclusion principle. And since there is no limit how high momentum can be, therefore there is no limit to the possible density of electron degenerate matter.
By the same reasoning, degenerate quark-gluon plasma is compressible too without violating exclusion principle.
  • Beyond the Standard Models
