Do both strands of DNA contain genes?
  • Thread starter Eagle9
  • Tags
    Dna Genes
In summary: Yes, the two mRNAs that are produced during transcription AT THE SAME TIME can actually make “double helix” of mRNA.
Eagle9
238
We know that the gene is part of DNA molecule in organism. I would like to know - are the both strands of DNA equally loaded/”filled” with genes? Or maybe only one strand contains genes? If both strands contain genes then can one gene on one strand “overlap” the other gene on the other strand? On the picture below we see that the Gene 3 on the lower strand partly overlaps the Gene 2 on the upper strand, does this happen?
Biology news on Phys.org
jedishrfu said:
The DNA article on wikipedia answers this. Basically only one strand has coding info the other has anti-codons.
https://en.wikipedia.org/wiki/Coding_strand
This is incorrect. Both strands of DNA can encode genes (though the coding sequence of one gene will always be on one strand). Anti-codons refer to segments of tRNA molecules, not parts of a gene.
Transcription will often occur from both strands of the DNA at a particular locus producing a sense transcript and an anti-sense transcript. http://www.nature.com/nrg/journal/v14/n12/full/nrg3594.html used to be thought of as an unwanted byproduct of gene regulation, though there are a growing number of examples where the antisense transcripts have functions as long non-coding RNAs (see for example, the Xist and Tsix transcripts involved in X-chromosome inactivation). I am not aware of any examples where a coding sequences on the Watson strand overlaps with a coding sequence on the Crick strand, though there may be some strange DNA viruses where this is the case. There are certainly examples of genes that can encode multiple genes on the same strand of DNA in different reading frames (see for example, the programmed frameshifting that occurs in the gag-pol gene of HIV).
Likes Torbjorn_L, PWiz, mfb and 2 others
Thanks
Yes of course
Ygggdrasil said:
Watson strand
Ygggdrasil said:
Crick strand
Well, it is a first time I encountered these names :cool:
It would be interesting to clarify this problem :smile:
Ygggdrasil said:
Transcription will often occur from both strands of the DNA at a particular locus producing a sense transcript and an anti-sense transcript. Antisense transcription used to be thought of as an unwanted byproduct of gene regulation, though there are a growing number of examples where the antisense transcripts have functions as long non-coding RNAs (see for example, the Xist and Tsix transcripts involved in X-chromosome inactivation).
Excuse me, but I do not quite understand what it means. Imagine that we have got DNA and there are two genes located on different strands exactly in front of each other and transcription occurs and we have two RNAs. Do you mean that transcription of one (let’s say upper) will be called sense transcript(ion) and the second one will be called anti-sense transcript(ion)?
Likes Silicon Waffle
Yes, if the sense transcript comes from the top strand, it will have the sequence CGUGCGUCUG. The antisense transcript would be transcribed from the bottom strand, and be complementary to the sense transcript (CAGACGCACG). The process of making this complementary RNA molecule is called antisense transcription while the molecule itself is referred to as the antisense transcript. Note that the antisense and sense transcripts arise from transcription at distinct promoters.
Although antisense transcripts have some region that is complementary to their corresponding sense transcript, they do not always fully overlap the sense transcript and can have regions that do not overlap with the sense transcript. For example, consider this figure from the http://dx.doi.org/10.1038/nrg3594 article I linked to earlier:
Here the sense (protein-coding) transcript is shown in blue and the antisense transcript is shown in red. In case (a), the AS transcript partially overlaps with the 5' end of the sense mRNA but the AS transcript also contains regions that do not overlap with the sense transcript. In contrast, in case (d), the sense and antisense transcripts almost fully overlap and thus the two molecules would be reverse complements and bind very strongly via base pairing.
O, do you mean that the two mRNAs that are produced during transcription AT THE SAME TIME can actually make “double helix” of mRNA or something like that?
They are unlikely to be produced at the same time because the RNA polymerases producing the sense and antisense transcripts would collide and interfere with each other during transcription. However, when the antisense transcript is made, it can bind to already existing sense transcripts to form a double-stranded RNA. Similarly already existing antisense transcripts could bind to newly made sense transcripts.
Likes Torbjorn_L and Silicon Waffle
Afaik ...
A gene is a set of bases in one strand of the DNA which encodes the information necessary to construct a useful protein.
The opposite DNA strand is it's exact complement in terms of encoding but does not construct anything useful
It serves the purpose only of replicating it's complimentary and active gene, ( which is necessary for replication).
However the active protein-build instucting gene can be on either side of the DNA chain.
Am I somewhere near right?
Examples apparently do exist where two protein-coding genes transcribed on opposite stands of the DNA overlap. Here are two papers describing examples in bacteria (http://nar.oxfordjournals.org/content/27/8/1847.full) and mammals (http://www.biomedcentral.com/1471-2164/9/169).
Likes Torbjorn_L
Thanks, I wanted to know exactly this :cool:
So, the conclusion is that the genetic sequence on one strand partly determines the genetic information on the other strand. In other words, organism’s traits are somehow interconnected. If one trait changes, then the second trait will also change if these two genes are overlapped, at least partly.
Sure, but genes do not need to be overlapping for traits to be interconnected. That one trait can influence the expression of another trait encoded by a different gene is a phenomenon known as epistasis and is quite common in genetics (as opposed to overlapping genes which are relatively rare).
Likes Torbjorn_L
Do both DNA strands contain coding genes? please reply me fast
The gene, (a sequence of bases called nucleotides), which codes for the production of any particular protein is on one strand, while the opposite strand serves as a template for DNA replication.
However the active protein generating sequence isn't always in the same strand for every protein.
There are some rare cases where both strands contain active protein coding instructions at the same site within the DNA.
DNA provides the 'blueprints' from which other cellular apparatus constructs proteins.
These proteins, slightly different for different individuals, are then used by the organism for it's physical growth, (making new cells) as well as many other things.
http://www.uvm.edu/~cgep/Education/Gene2Prot.html
http://genetics.thetech.org/about-genetics/how-do-genes-work
Likes mfb
Related to Do both strands of DNA contain genes?
1. Do both strands of DNA contain the same genes?
Yes, both strands of DNA contain the same genes. This is because the two strands of DNA are complementary and are made up of the same nucleotide pairs, which determine the genetic code.
2. Can genes be found on only one strand of DNA?
No, genes can be found on both strands of DNA. The two strands of DNA work together to create a complete genetic code, so genes are present on both strands.
3. How are genes arranged on the two strands of DNA?
Genes are arranged in the same order on both strands of DNA. This means that the sequence of nucleotides on one strand is complementary to the sequence on the other strand, allowing for the genetic information to be read and translated.
4. Are genes located in the same place on both strands of DNA?
Yes, genes are located in the same place on both strands of DNA. This is because the two strands are complementary, meaning they have the same sequence of nucleotides and therefore the same genes in the same locations.
5. Do both strands of DNA code for the same proteins?
Yes, both strands of DNA code for the same proteins. The genetic code is universal, meaning that the same sequence of nucleotides will always code for the same protein, regardless of which strand of DNA it is on.
  • Biology and Medical
