Do Cauchy-Riemann Conditions Guarantee Analyticity?
In summary, analytic functions identities are mathematical expressions that describe the relationship between two or more analytic functions. They are important in simplifying complex functions and are commonly used in fields such as physics and economics. These identities are derived using algebraic manipulation, trigonometric identities, and properties of complex numbers. However, there are limitations to their use as they can only be applied to analytic functions and may only hold for certain values of the complex variable.
ognik
643
Hi - just started complex analysis for the 1st time. I have been a little confused as to the chicken and egg-ness of Cauchy-Riemann conditions...
1) Wiki says:
"Then f = u + iv is complex-differentiable at that point if and only if the partial derivatives of u and v satisfy the Cauchy–Riemann equations (1a) and (1b) at that point"; that seems clear enough to me.
My book however says:
"Cauchy–Riemann conditions are necessary for the existence of a derivative of f (z); that is, if df/dz exists, the Cauchy–Riemann conditions must hold"
To me the highlighted part implies that if you can differentiate f(z), then the C-R conditions will hold, which kind of contradicts the "if and only if" of the wiki definition? I'd appreciate is clarity on that...
Also I have read that the pd's must ALSO be continuous for the existence of a derivative of f (z)?
2) I understand that if f(z) is differentiable as above - at & near some point $ {z}_{0} $, then f(z) is 'complex analytic' at that point. This apparently means that if complex analytic, the Real and Imag parts each always satisfy the Laplace equation?
So - we test a complex equation to see if the C-R conditions are satisfied, if they are then the eqtn is analytic (at that point, everywhere makes it an entire function) AND we know the Laplace eqtns hold ?
3) To confuse me further, in search of a clearer explanation I found stuff on the web which says: "All complex functions f(z) are infinitely differentiable and, in fact, analytic where defined"?
I am a tad confused between the above 3 points and would appreciate something like a bullet list of what I really need to understand.
4) Soldering on, an identity exercise I am stuck on is:
The functions u(x, y) and v(x, y) are the real and imaginary parts, respectively, of an analytic function w(z).
Show that $ \pd{u}{x}\pd{u}{y}+\pd{v}{x}\pd{v}{y} = 0 $ and give a geometric interpretation
Sounds simple, Cauchy-Riemann applies for analytic function, so $ {u}_{x} = {v}_{y} $ and $ {u}_{y} = -{v}_{x} $
$ \therefore {u}_{x} - {v}_{y} = 0 = {u}_{y} + {v}_{x}$, pd both sides w.r.t. y gives
$ {u}_{xy} - {v}_{yy} = {u}_{yy} + {v}_{xy}, \therefore {u}_{xy} - {v}_{xy} ={u}_{yy} + {v}_{yy} $ ... not useful.
I also tried $ {u}_{x} = {v}_{y} \therefore {u}_{xy} = {v}_{yy} $ and
$ {u}_{y} = -{v}_{x} \therefore {v}_{xy} = -{u}_{yy} $
$ \therefore {u}_{xy} + {v}_{xy} = {v}_{yy} -{u}_{yy} $ also not useful
I also fiddled with the laplace eqtns to no avail ($ \nabla^2{u} = 0 = \nabla^2{v} $ )
A hint please?
I think I should break this down a bit :-)
Wiki has a definition: "A function is analytic if and only if its Taylor series about x0 converges to the function in some neighborhood for every x0 in its domain"
Isn't the point about all Taylor series that they will converge to the function?
And am I right to say that, to be able to build a Taylor series, the function has to be infinitely differentiable anyway?
Another from Wiki: "The sole existence of partial derivatives satisfying the Cauchy–Riemann equations is not enough to ensure complex differentiability at that point. It is necessary that u and v be real differentiable, which is a stronger condition than the existence of the partial derivatives"
What is the difference between 'real differentiable' and 'the existence of partial derivatives'?
1) The Wikipedia definition and your book's definition are both correct. The key difference is that the Wikipedia definition is a necessary and sufficient condition, while your book's definition is only a necessary condition. In other words, the Cauchy-Riemann conditions must hold for a function to be complex-differentiable, but they are not the only conditions for a function to be complex-differentiable.
2) Yes, if a function is complex-differentiable at a point, it is also complex analytic at that point. This means that the function satisfies the Cauchy-Riemann equations and the Laplace equation. However, the converse is not necessarily true - a function can satisfy the Cauchy-Riemann equations and the Laplace equation without being complex-differentiable.
3) This statement is not entirely accurate. It is true that all analytic functions are infinitely differentiable, but not all complex functions are analytic. Analyticity is a stronger condition than differentiability.
4) You are on the right track. Using the Cauchy-Riemann equations, you can express the partial derivatives of u and v in terms of each other. Then, use the fact that u and v are the real and imaginary parts of an analytic function w, and use the Cauchy-Riemann equations again to express the mixed partial derivatives in terms of the second partial derivatives. This should lead you to the desired result.
FAQ: Do Cauchy-Riemann Conditions Guarantee Analyticity?
What are analytic functions identities?
Analytic functions identities are mathematical expressions that describe the relationship between two or more analytic functions. They are used in complex analysis to simplify calculations and prove theorems.
Why are analytic functions identities important?
Analytic functions identities are important because they allow us to manipulate and transform complex functions into simpler forms, making it easier to solve problems in areas such as physics, engineering, and economics.
What are some common examples of analytic functions identities?
Some common examples of analytic functions identities include the sum and difference identities, product identities, quotient identities, and power identities. These identities can be used to simplify trigonometric, logarithmic, and exponential functions.
How are analytic functions identities derived?
Analytic functions identities are derived using algebraic manipulation, trigonometric identities, and the properties of complex numbers. They are often derived by substituting a complex variable into a function and then using algebraic techniques to simplify the expression.
Are there any limitations to using analytic functions identities?
Yes, there are limitations to using analytic functions identities. They can only be applied to analytic functions, which are functions that can be represented by a convergent power series. Additionally, some identities may only hold for certain values of the complex variable, so it is important to check the validity of an identity before using it in a calculation.
