Do Coherent States Imply 0 Energy Uncertainty?
uxioq99
Consider the state ##\psi_\lambda = N e^{\lambda a^\dagger} \phi_0## where ##\phi_0## is the ground state of the harmonic well and ##a^\dagger##. What is the energy uncertainty ##\Delta E## of ##\psi_\lambda##?
##\Delta E = \sqrt{\langle E^2 \rangle - \langle E \rangle^2}##
By considering the power series for ##e^x##, I assert that ##N=e^{-\lambda^2/2}## and that ##a\Psi_\lambda = \lambda \Psi_\lambda##. Because the Hamiltonian may be written ##\hbar \omega(a^\dagger a + 1/2)##, ##\langle E \rangle = \hbar \omega(\langle a \Psi_\lambda, a \Psi_\lambda \rangle + 1/2)## by the definition of the adjoint. Then, ##\langle E \rangle = \hbar \omega (|\lambda|^2 + 1/2)##. Likewise, ##E^2 = \hbar^2 \omega^2((a^\dagger a)^2 + a^\dagger a + 1/4)##.
\begin{align}
\langle \Psi_\lambda | a^\dagger a a^\dagger a | \Psi_\lambda \rangle
&= (a^\dagger a | \Psi_\lambda \rangle)^\dagger (a^\dagger a | \Psi_\lambda \rangle) \\
&= |\lambda|^2 \langle a^\dagger \Psi_\lambda, a^\dagger \Psi_\lambda \rangle \\
&= |\lambda|^2 \langle a\Psi_\lambda, a\Psi_\lambda \rangle \\
&=|\lambda|^4 \langle \Psi_\lambda, \Psi_\lambda \rangle \\
\end{align}
Therefore, ##\langle E^2 \rangle = (|\lambda|^4 + |\lambda|^2 + 1/4)=\langle E \rangle^2##. Is it really possible that a coherent state has ##0## energy uncertainty? How would that not contradict the energy time uncertainty principle?
Thank you all in advance.
Can you state, precisely, the energy time uncertainty principle? As it applies to the harmonic oscillator?
Coherent states are not eigenstates of the Hamiltonian and thus the energy does not take a determined value. I'd not bring in the energy-time uncertainty relation, which is subtle and has nothing to do with the simpler question about the energy uncertainty of a coherent state.
The most simple representation of the coherent state is in terms of the energy eigenstates ("Fock states"):
$$|\Phi(\alpha) \rangle=c_0 \sum_{n=0}^{\infty} \frac{\alpha^n}{\sqrt{n!}} |n \rangle, \quad c_0 = \exp(-|\alpha^2|/2), \quad \alpha \in \mathbb{C}.$$
From this you can get the probaility to find ##n## "phonons" by
$$P(n)=|\langle n|\Phi(\alpha)|^2,$$
and from this you can evaluate ##\langle n \rangle## and ##\Delta n^2## easily. Then you only need
$$\hat{H}=\hbar \omega (\hat{n}+1/2 \rangle)$$
to get ##\langle E \rangle## and ##\Delta E^2=\langle (E-\langle E \rangle)^2 \rangle.##
uxioq99 said:
\begin{align}
&= (a^\dagger a | \Psi_\lambda \rangle)^\dagger (a^\dagger a | \Psi_\lambda \rangle) \nonumber\\
&= |\lambda|^2 \langle a^\dagger \Psi_\lambda, a^\dagger \Psi_\lambda \rangle \nonumber \\
&= |\lambda|^2 \langle a\Psi_\lambda, a\Psi_\lambda \rangle \nonumber\\
&=|\lambda|^4 \langle \Psi_\lambda, \Psi_\lambda \rangle \nonumber \\
\end{align}
Note ##\langle a^\dagger \Psi_\lambda, a^\dagger \Psi_\lambda \rangle \neq \langle a\Psi_\lambda, a\Psi_\lambda \rangle##
Likes topsquark, uxioq99 and MatinSAR
@TSny Thank you, I forgot that they didn't commute. My brain was still operating in "elementary mode".
And also note
$$\hat{a}^{\dagger} |\Psi_{\lambda} \rangle \neq \lambda^* |\Psi_{\lambda} \rangle.$$
Note the INequality sign!
The trick in evaluating expectation values or matrix elements of operators between coherent states is to bring everything in normal ordering and then act with the creation operators on the bra and the annihilation operators on the ket. For this you only need
$$\hat{a} |\Psi_{\lambda} \rangle=\lambda |\Psi_{\lambda} \rangle.$$
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
