cianfa72
- 2,429
- 255
- TL;DR Summary
- About the Feynman's argument that electromagnetic fields have/hide momentum
Hi, reading Feynman's lectures on section 10-5 I came up with a question.
He claims that electromagnetic fields have momentum. He gives an example of two charges A and B in a electromagnetic field. When the charge A is suddenly moved (as I understand by an external force w.r.t. the "A + B" system) it will feel a reaction force (from the field I believe) meanwhile B has felt nothing.
He says that A will pick up some momentum (from the field reaction) while B will not since it has felt nothing and therefore it has not yet changed its momentum. So if we consider only the system "A + B" the conservation of momentum will not check out in that tiny time interval.
However my point is the following: the law of conservation of momentum only holds when the net external force is null. Therefore maybe here the point is that Feynman considers the small time interval from when the external force is actually removed from A, so that the system "A + B" will be acted by internal forces from the EM field alone.
Then if we assign momentum to the field the conservation of momentum "magically" checks out even in that tiny time interval (the system being now "A + B + EM field").
Note that in the above Feynman's argument charges A and B are actually the sources of the EM field considered.
What do you think about? Thanks.
