Undergrad Do electromagnetic waves fade with distance in vacuum?
Electromagnetic waves do fade with distance due to the inverse square law, which causes energy density to decrease as the wave spreads over a larger area. However, the frequency of the electromagnetic wave remains constant regardless of distance. Signals from outer space retain enough energy to be detected despite the fading, as they start with significant initial energy. Telescopes can capture these signals even after they have traveled thousands of light years. Understanding these principles clarifies how we can detect distant cosmic signals.
yashraj
TL;DR
Do electromagnetic wave gets weaker with the increasing distance from the source in its travel ?
I want to know that when a charged particle accelerates then the electromagnetic wave so produced will loose it's strength or can say fades with distance or not ? If yes then what happens to its frequency and also tell me if electromagnetic waves fades away with increasing distance from the source then how physicists detects signals from the outer space which have travelled thousands of light years ?
Welcome to PF.
As an EM wave radiates out into space, the energy is distributed over the surface of a radially growing sphere. That causes the EM wave energy density to be reduced by the inverse square law.
The frequency of the EM wave remains the same.
The signals detected from space start out with incredible energy. After the inverse square law has been applied, there is sufficient energy remaining, to enter the aperture of the telescope, and for the signals to be detected.
Baluncore said:
Welcome to PF.
As an EM wave radiates out into space, the energy is distributed over the surface of a radially growing sphere. That causes the EM wave to be reduced by the inverse square law.
Thank you for the answer. I was actually thinking almost same but I wanted to make sure that I was right.
Thread 'What is the pressure of trapped air inside this tube?'
As you can see from the picture, i have an uneven U-shaped tube, sealed at the short end. I fill the tube with water and i seal it. So the short side is filled with water and the long side ends up containg water and trapped air. Now the tube is sealed on both sides and i turn it in such a way that the traped air moves at the short side. Are my claims about pressure in senarios A & B correct? What is the pressure for all points in senario C? (My question is basically coming from watching...
  • · Replies 17 ·
  • · Replies 36 ·
  • · Replies 25 ·
21K
