Do electrons move in an electric field or in a conductor?
In summary, the force that causes electrons to move in a conductor is the electric field, and in AC, it is an electromagnetic wave that travels along the wire. The electrons not only react to this electromagnetic field, but also emit their own electromagnetic waves, causing a slowdown of the traveling wave and acting as an antenna. There are two types of electricity: the charge moving along the wire, and the surrounding electromagnetic wave. The EM wave travels along the outside of the conductor and can be affected by the insulation used. Additionally, the dimensions of the wire can impact its resistance.
Symmetry777
32
Is this correct?
“The force that gets the electrons moving is the electric field. In AC, it is actually an electromagnetic wave traveling along the wire. Note that the electrons not only react to the electromagnetic field, but also are sources; the oscillating electrons themselves emit electromagnetic waves which in part cause an effective slowdown of the traveling wave, and in part just get emitted from the wire (the wire effectively acts as antenna).”
http://physics.stackexchange.com/questions/135255/how-similar-is-comparison-between-the-principle-behind-Newtons-cradle-versus-ac
Yes, electrons move in a conductor. Electron drift rate will soon be an exercise in your basic physics class.
Likes Symmetry777
Well yes but really it is charge that is being drifted by a voltage. There are 2 types of electricity:the charge moving along a wire and the electromagnetic wave surrounding that charge as it moves along the wire.
Likes Symmetry777
google electron drift --- the electrons really do just drift
2 types ... not in the way you are suggesting
Also the EM wave travels along the outside of the conductor ... The conductor only acts as a waveguide
This becomes apparent when with a insulated conductor, where a decrease in the speed of the EM wave is observed
and as a result insulated conductors have an associated velocity factor which is primarily governed by the type and thickness of the insulation
Dave
the resistance is impacted by the dimensions of the wire itself, of course it flows on the outside! why would electromagnetic waves be able to penetrate a conductor, that is how radio interference is prevented...
Thank You
FAQ: Do electrons move in an electric field or in a conductor?
Electrons can move in both an electric field and in a conductor.
What is the difference between the movement of electrons in an electric field and in a conductor?
In an electric field, electrons are forced to move in a specific direction due to the presence of an electric charge. In a conductor, electrons are free to move and can flow in any direction.
How do electrons move in an electric field?
Electrons move in an electric field by experiencing a force due to the presence of an electric charge. This force causes them to move in a specific direction.
Why do electrons move in a conductor?
In a conductor, electrons are not bound to any particular atom and are free to move due to the presence of an electric potential difference. This movement of electrons is what allows electricity to flow through a conductor.
Can electrons move in a conductor without an electric field?
No, electrons cannot move in a conductor without an electric field. The presence of an electric potential difference is necessary for the movement of electrons in a conductor.
