I Do equipotential lines fall on the equiprobability contours?
Equipotential lines and equiprobability contours may align closely near the core of a 2D charge distribution, particularly when the standard deviations σx and σy are equal. As the distance from the core increases, the equipotential surfaces tend to become circular for equal standard deviations. The discussion raises questions about the relationship between these contours in general terms, not limited to specific particle distribution functions. Clarification is sought on whether the normalized distribution function (NDF) is Gaussian. Overall, the relationship between equipotential and equiprobability contours remains a nuanced topic in the context of charge distributions.
Mikheal
TL;DR Summary
Are equipotential lines fall on the equiprobability contours of charge distribution?
For 2D charge distribution ρ(x,y)=Ne PDF(x,y), where PDF is the normalized probability density function with its peak on (0,0) and has standard deviations σ x. and σ y. Are the contours with the equal probability "PDF(x,y)=const" the same as the equipotiential contours?, I tend to think that near the core of the distribution, they will be similar, and as the distance from the core increases, the equipotential surfaces will be circles for σxy.
Edit 1: I am speaking in general, not about certain particle distribution functions, such as 2D Gaussian with different σ x and σ y, 2D bi-Gaussian, 2D super-Gaussian, Flat-top, ....
Edit 2: I know that for 2D Gaussian with σ x = σ y, they fall on each other.
Is NDF a Gaussian? Your question needs to be a little bit more definitive.
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
