Do Event Horizons Really Exist?
  • I
  • Thread starter Tollendal
In summary: This is the part that I am questioning: if Hawking radiation still persists even in the simplified case of a black star, then wouldn't the radiation be drawn back in by the star's gravity?
Tollendal
47
If not, it seems to me Hawking radiation can't exist also.
This is a puzzling question in light of the LIGO result.
1. There's plenty of evidence that point to the existence of black holes
2. Consequently, since these event horizons accompany black holes, then the evidence supports the existence of these event horizons.
So what is the problem here?
Zz.
Dear ZapperZ,
I reffer you to to the following publication, for instance (there are many others. as the matter is far from decided:
Barceló, Carlos
; Liberati, Stefano; Sonego, Sebastiano; Visser, Matt
Affiliation: AA(Instituto de Astrofísica de Andalucía, CSIC, Camino Bajo de Huétor 50, 18008 Granada, Spain), AB(International School for Advanced Studies, Via Beirut 2-4, 34014 Trieste, Italy and INFN, Sezione di Trieste, Italy), AC(Università di Udine, Via delle Scienze 208, 33100 Udine, Italy), AD(School of Mathematics, Statistics, and Computer Science, Victoria University of Wellington, New Zealand)
Publication: Physical Review D, vol. 77, Issue 4, id. 044032
"While the outcome of gravitational collapse in classical general relativity is unquestionably a black hole, up to now no full and complete semiclassical description of black hole formation has been thoroughly investigated. Here we revisit the standard scenario for this process. By analyzing how semiclassical collapse proceeds we show that the very formation of a trapping horizon can be seriously questioned for a large set of, possibly realistic, scenarios. We emphasize that in principle the theoretical framework of semiclassical gravity certainly allows the formation of trapping horizons. What we are questioning here is the more subtle point of whether or not the standard black hole picture is appropriate for describing the end point of realistic collapse. Indeed if semiclassical physics were in some cases to prevent formation of the trapping horizon, then this suggests the possibility of new collapsed objects which can be much less problematic, making it unnecessary to confront the information paradox or the runaway end point problem."
And so? Does it really claim that BH doesn't have event horizon?
Besides, is there a reason why you accept this, and discard others? How did you pick and choose?
BTW, next time, don't hide anything. You should have cited this paper in the very beginning, rather than ask a rather vague question.
Zz.
Dear ZapperZ,
My doubts were about the existence (or not) of black holes, as the matter is far from settled. I was asking if Hawking radiation persist even in the case of much simpler black stars. Wikipedia gives the following explanation:
"A black star is a gravitational object composed of matter. It is a theoretical alternative to the black hole concept from general relativity. The theoretical construct was created through the use of semiclassical gravity theory. A similar structure should also exist for the https://en.wikipedia.org/wiki/Einstein-Maxwell-Dirac_equations system, which is the (super)classical limit of quantum electrodynamics, and for the Einstein-Yang-Mills-Dirac system, which is the (super)classical limit of the standard model.
A black star need not have an event horizon, and may or may not be a transitional phase between a collapsing star and a singularity. A black star is created when matter compresses at a rate significantly less than the freefall velocity of a hypothetical particle falling to the center of its star, because quantum processes create vacuum polarization, which creates a form of degeneracy pressure, preventing spacetime (and the particles held within it) from occupying the same space at the same time. This vacuum energy is theoretically unlimited, and if built up quickly enough, will stop gravitational collapse from creating a singularity. This may entail an ever-decreasing rate of collapse, leading to an infinite collapse time, or asymptotically approaching a radius less than zero.
A black star with a radius slightly greater than the predicted event horizon for an equivalent-mass black hole will appear very dark, because almost all light produced will be drawn back to the star, and any escaping light will be severely gravitationally redshifted. It will appear almost exactly like a black hole. It will feature Hawking radiation, as virtual particle pairs created in its vicinity may still be split, with one particle escaping and the other being trapped. Additionally, it will create thermal Planckian radiation that will closely resemble the expected Hawking radiation of an equivalent black hole.
The predicted interior of a black star will be composed of this strange state of spacetime, with each length in depth heading inward appearing the same as a black star of equivalent mass and radius with the overlayment stripped off. Temperatures increase with depth towards the centre."
Tollendal said:
Dear ZapperZ,
First of all, you shouldn't use "Wikipedia" articles with me. I don't buy them.
Secondly, that was what I asked you earlier. You should have just come right out and stated that you are not convinced that black holes exist.
Thirdly, note that I said that there are evidence pointing to the existence of black holes. NOWHERE in my post did I claim that this is settled (as if there's such a thing for this type of phenomenon). My question to you is, why do you believe or accept contrary evidence in some, but dismiss the evidence pointing to its existence in others? How did you pick and choose what to accept? That question that I asked to you earlier, you ignored.
The degree of certainty in something like this is less than what you get in, say, superconductivity phenomenon. And there are more data that are still being sought after. So of course people still discuss, debate, and argue about it. But look at how much we know, how much evidence there is for and against, and you decide why you decide on one versus the other.
Zz.
If you read the very quote from Wikipedia that you posted, you will find the answer to this question, at least to the extent that it has an answer, since "black stars" are a speculative concept. Thread closed.
FAQ: Do Event Horizons Really Exist?
What is an event horizon?
An event horizon is a theoretical boundary around a black hole where the escape velocity exceeds the speed of light. This means that anything, including light, that crosses the event horizon will be unable to escape the gravitational pull of the black hole.
How do we know event horizons exist?
While we cannot directly observe event horizons, their existence is supported by various pieces of evidence such as the behavior of matter and light around black holes, the predictions of general relativity, and the detection of gravitational waves.
Can we see an event horizon?
No, we cannot see an event horizon because it is a point of no return for anything crossing it. However, we can indirectly observe its effects on surrounding matter and light.
Are event horizons always perfectly spherical?
No, it is possible for event horizons to have irregular shapes due to the rotation or distortion of the black hole.
Could we ever cross an event horizon?
Based on our current understanding of physics, it is highly unlikely that we could survive crossing an event horizon. The immense gravitational forces would cause spaghettification, stretching us into thin strands before ultimately crushing us.
