Do exactly the same chemicals react with each other
In summary, this is a chemical reaction that can result in the production of a new, different molecule.
icakeov
379
27
Not sure if this is well know but for some reason, I don't know if exactly same chemicals make chemical reactions with one another and if yes, how common that is?
Chemistry news on Phys.org
Your question is not clear to me.
If there was an environment with only one compound in it, for example destilised water, I understand that water molecules don't chemically react with it each other. At least not on Earth I imagine.
But I was wondering if there is such a compound which in some way, changes its molecular property by interacting with another same compound. I guess the other compound would also change into the same thing...
I"m not sure what you mean - let's take this to be an answer.
Polymers, examples:
multiple glucose molecules which are chemically bonded into a chain == starch.
From wikipedia:
Starch is very similar to cellulose. But cellulose is a fiber that you can't digest. The thing that makes these two polymers different is simply how the glucose molecules are put together in the polymer chain
polypepetides can be chains of the same amino acid - like where G=glutamic acid G-G-G-G-G
Likes icakeov and BillTre
@BillTre - not clear to me either. But polymers meet his definition. Probably not his intent.
Likes icakeov
Ah I see what you mean Jim, if same molecules start boding together, that essentially is a chemical reaction and the result is a different molecule. So from that angle the answer would be yes.
I was more thinking if the actual internal structure of the molecule could ever change by being around a molecule or molecules just like itself.
Thanks for the reply btw!
How about O forming O2, or H forming H2?
Is that the kind of thing you mean?
I think the unbonded atoms (which some might call molecules) would be unstable.
or what about 3O2's forming 2O3's? (all more than a single atom)?
Likes icakeov
Yes, that's a great example. hah, what's that expression.. can't see the forest for the trees.
But that still does just create a "chain" sort to speak.
I was more thinking of a molecule, say some acid for example that will react every time it is surrounded by itself... And turn into another type of acid. I can't imagine this could happen as they would have to turn into either something else (so someone would have to donate an atom or two, I guess they would have to argue it out? ;) ), but they cannot change into a same thing, because they would just remain the same thing.
Sorry this might be obvious, but it just never occurred to me to question it, just in case...
Or: radioactive decay -> alpha particle -> interacts with neighbor nucleus. You should consider reading about chemistry.
Your question is 'a too nebulous what if '; too many answers fit.
Likes icakeov
Thanks Jim, this is totally a basic question. I just for some reason questioned it
Bottom line, creating poly-chains seems to be the only option a molecule has when reacting with itself.
A good example of this phenomenon is nitrogen dioxide. NO2 can react with itself to form N2O4. So, under certain conditions (e.g. low temperature or high pressure), a vial of nitrogen dioxide will convert mostly to dinitrogen tetroxide, whereas under other conditions (high temp or low pressure), it will stay as nitrogen dioxide.
Another example of this phenomenon is formaldehyde. Formaldehyde is fairly reactive substance that can react with itself to form various polymeric forms (e.g. paraformaldehyde). As a diffuse gas, formaldehyde can exist mostly as monomers, but once this gas condenses, you begin to start forming these polymers.
Likes icakeov
A bit tricky, if the molecule reacts with itself you can't start with a pure compound :wink:
Google for disproportionation.
Likes icakeov and jim mcnamara
Related to Do exactly the same chemicals react with each other
1. Do all chemicals react with each other?
No, not all chemicals react with each other. Chemical reactions occur when two or more substances combine to form new substances with different properties. Some chemicals may not react with each other due to differences in their chemical structure or stability.
2. Are there any chemicals that do not react with anything?
Yes, there are some chemicals that are considered inert, meaning they do not undergo chemical reactions with other substances. Examples of inert chemicals include noble gases such as helium and neon.
3. Can two chemicals that have the same formula react with each other?
Yes, two chemicals with the same formula can still react with each other. This is because the chemical formula only represents the types and ratios of atoms present in a substance, not the way they are bonded or arranged.
4. Is the reaction between two chemicals always the same?
No, the reaction between two chemicals can vary depending on the conditions such as temperature, pressure, and concentration. Even with the same chemicals, different reaction conditions can result in different products or rates of reaction.
5. Can chemicals react with each other without any external factors?
Yes, some chemical reactions can occur without the need for external factors such as heat, light, or a catalyst. These are called spontaneous reactions and they happen naturally due to the inherent properties of the chemicals involved.
  • Chemistry
  • Chemistry
