Do I have choice what resolution to stream using boxes like Roku?
Streaming video on a 25MBPS internet connection presents challenges, particularly when considering resolution and multiple devices. 4K streaming requires the full bandwidth, limiting usage to one device at a time. Users can choose to stream in lower resolutions, such as SD or HD, to accommodate multiple devices. Services like Netflix automatically adjust video quality based on available bandwidth, which can help manage streaming across several TVs.Setting devices like Roku to a lower connection speed can potentially optimize bandwidth usage, allowing for multiple streams without exceeding the internet limit. Buffering occurs when the video playback is interrupted due to insufficient download speed, leading to screen freezes. It's crucial to verify actual internet speeds through testing, as advertised speeds may not reflect real-world performance.For those with limited data caps, such as satellite internet users, traditional cable services may offer a more reliable and cost-effective solution for consistent TV access. Combining cable TV with basic satellite internet can provide a backup option during outages, making it a practical choice for some users.
yungman
Hi
Sorry about the stupid question. I am completely green on tv streaming. I have a limitation of 25MBPS internet connection. I know 4K video needs 25MBPS speed. That is I can ONLY run one tv.
I really don't care about the clarity and resolution. I have modern smart tv, but I am still feeding with RCA composite video. I am a sound guy, my stereo is tip top, but I don't care about the screen.
Can I make a choice what resolution video to stream? That is can I just want to stream SD or at best HD videos so I can use multiple tv, computers with just 25MBPS internet connection.
Thanks
Alan
Computer science news on Phys.org
Netflix I believe automatically adjusts resolution down if you are having bandwidth problems.
Of course, another solution is to trade in the 4K TVs for a HD, or even less than HD.
What will happen if I have 4 TV station watching 4 different channels at the same time with max internet download speed of 25MBPS only?
This article said I can set the speed of Roku, would that solve my problem if I set Roku to 8MBPS so even if I run 4 tv, it's still using 24MBPS. Am I reading this right?
https://www.technipages.com/roku-set-connection-speed
Also this article said I can set the video quality to reduce buffering:
https://www.lifewire.com/fix-roku-keeps-buffering-5208692
What is BUFFERING? Does it mean screen freeze while trying to downloading?
Will the screen freeze if the download speed of the internet is too slow?
It sounds to me as though you are taking the advertised maximum internet speed of 25 MBPS for granted. I would be very surprised if you could count on getting the advertised speed. You should run some speed tests before you do too much planning.
I did more reading. For satellite internet, there is a very low data cap. Like Hughesnet, cheaper one only has 15GB. Which is very low for streaming tv. Even the more expensive has limit of 100GB.
I think now I understand why people still using DirecTV and other cable TV while streaming devices are much cheaper. Looks like it's cheaper to go to say Xfinity tv, then just keep the basic satellite internet provider for emergency. If any storm or earthquake cut off the cable tv, I can just pull out antenna to get on air local tv to watch live shows. With this arrangement, cost would be like $90 for tv, $70 for satellite internet, total of $160/mo. That is still cheaper than getting an expensive satellite internet.
Any other suggestions are welcome.
Thanks
Alan
This week, I saw a documentary done by the French called Les sacrifiés de l'IA, which was presented by a Canadian show Enquête. If you understand French I recommend it. Very eye-opening. I found a similar documentary in English called The Human Cost of AI: Data workers in the Global South. There is also an interview with Milagros Miceli (appearing in both documentaries) on Youtube: I also found a powerpoint presentation by the economist Uma Rani (appearing in the French documentary), AI...
