Do Light Waves Have Amplitude?
In summary, waves have three properties: frequency, amplitude, and speed. When discussing light as a wave, its frequency and speed are always referenced but not its amplitude. It is unknown if light has a fixed amplitude for all wavelengths or if it can change. Sound waves can increase in loudness due to multiple sources or increased amplitude, but light can only increase in brightness through multiple sources. The intensity of light may only depend on the amount of light present, and the amplitude of a light wave may be fixed. However, the concept of amplitude for a single photon is debated. Some argue that the amplitude of light can be defined as the energy of a single photon, while others argue that it is not applicable in this context.
  • #36
Hi, DaleSpam
DaleSpam said:
Thanks. From the article
In Figure 1: The average photon numbers of the three states from top to bottom are <n>=4.2, 25.2, 924.5
Amplitude of electric field in the graphs, 2.9, 7.1, 43 correspond 4.2/2.9^2 = 25.2/7.1^2 = 924.5/43^2 = 1/2
Growing width of wave lines by noise in lowering number <n> is imstructive on what's going on to me. Thanks.
Further may I expect amplitude of electric field for <n>=1, single photon, be sqrt of 2 = 1.41? Thus electric field of SINGLE PHOTON shows noise band of width about 3 with its center line is waving by amplitude 1.41.
Regards
Science news on Phys.org
  • #37
Drakkith said:
I don't see how photons are not part of this discussion. The OP specifically used the example of an electron emitting a photon as it changes energy levels. Is there something different with using a photon than with a "wave"?
I just spotted this and have to take issue. A single photon is not 'enough' to describe a wave. In just the same way that a single electron can only arrive in one spot after passing through a diffracting structure, then a photon can also arrive at only one receiving atom. It is only when the statistics of large numbers are involved that the wave quantities become relevant.
There is no implication, whatsoever, that a single photon 'is' a wave. Its presence, along with all the other photons constitutes a wave, of course - but that is putting things totally the other way round.
None of these problems need arise unless one insists on finding contradictions between wave and quantum models. Both models are just models that happen to describe certain phenomena better or worse than the other model. Don't lose any sleep over the 'really' thing; it's pointless.
  • #38
sweet springs said:
Hi, DaleSpam
May I assume amplitude of electric field for <n>=1 Single Photon is sqrt of 2 = 1.41? This single photon graph shows almost flat noise of width about 3 but the center of noise vibrates subtly with amplitude 1.41.
Regards.
DaleSpam's reply was clearer and far more useful than my hurried non-explanation,
in which I tried to introduce the concept of a coherent state (quantum equivalent to
the classical wave) without actually explaining it (or giving a link). What I tried to
warn you about, and I'll do it again here, is the fact that a coherent state doesn't
(can't) contain a precise number of photons. So, a state with <n> = 1 is NOT the
same thing as a single photon. This is a common misunderstanding.
To illustrate the difference between a <n> = 1 coherent state and a single photon,
in the former the electric field is oscillating with a given frequency and has a very
small amplitude with a lot of noise; in the second, the electric field is all noise with
a not oscillating, constant mean value of zero. That is, the frequency of the associated (null!) electric field is not that of the photon.
  • #39
I see. Well, that's interesting. What exactly causes multiple photons to be "wavelike" yet just one to not be?
  • #40
The sheer quantity of them makes the wave more and more well defined. Think in terms of interference patterns for low photon counts. One photon arrives at the screen, telling you nothing about the wavelength (from the diffraction pattern). A few hundred will start to form a pattern that is better defined and tells you more about the pattern - wavelength. But it takes many more than that to establish, from the exact positions of nulls, what the actual wavelength of the 'wave' of which they are a part.
Now, before you come back with the following, I will deal with it. You will probably tell me that the wave equation λ = c/f should tell you the wavelength and that you could measure the energy / frequency of a single photon. But I say that is begging the question because, without a load of photons, you don't have an established wave for that equation to apply to. Remembering that the equation comes from the wave treatment and not the QM treatment. (I think that is a reasonable argument. How about you?)
  • #41
Yes, this is correct except for the interpretation that <n>=1 is the coherent state of a single photon. A coherent state does not have a definite number of photons, in fact, the number of photons is Poisson distributed. So, the amplitude of a coherent state with <n>=1 is 1.41, as you suggested, but the actual number of photons in that state is uncertain (although 92% of the time it will be 2 or fewer).
In a coherent state the number and phase form an "uncertainty" relationship. The Poisson distribution has the property that its standard deviation is equal to its mean. So, the lower the mean of the Poisson distribution, the lower the uncertainty in the number of photons, and therefore the greater the uncertainty in the phase. So a coherent state with <n>=1 would have a very uncertain phase.
  • #42
I understand what you're saying, but I don't know enough to agree or disagree with it. For now I'll accept it as a reasonable example. Thanks!
  • #43
Hi, Dalespam
Thank you for your kind tutoring.
Now I think I understand that coherent state, which corresponds to classical em wave, is eigenstate of non-Hermite annihilation operator and one photon state we are looking for is eigenstate of Hermite number operator. Are eigenstates of the latter representation, Fock states, expressed by combination of coherent states and how?
Thank you in advance.
  • #44
That is a good question. I think that the answer is yes, but I do not know how. I would recommend that you start a new thread in the QM section and ask this question. I would very much like to see the answer also.
  • #45
Hi, DaleSpam.
I posted new thread
https://www.physicsforums.com/showthread.php?p=3520757#post3520757
Regards.
