B Do materials surrounding magnets affect how superconductors levitate?
The discussion focuses on an experiment involving magnetic levitation and the potential effects of surrounding materials on the performance of a type 2 superconductor. The experimenter is considering using various materials like iron, nickel, copper, and wood around the magnets to observe changes in the levitation speed and time of the superconductor. The outcome is uncertain and depends on how these materials influence magnetic fields and other factors. A suggestion is made to test the magnet's strength with different materials before involving the superconductor. The conversation emphasizes the importance of material properties in magnetic interactions.
SBrownJC
I'm currently doing an experiment with magnetic levitation but I don't know if my independent variable will even affect my results at all. I am planning on building a rail of magnets and levitating a type 2 superconductor on it. I wanted to change the material surrounding the rail of magnets and/or the superconductor. Will this have any effect when I record the time and speed of the superconductor?
Maybe. Depends on what the material is, how it affects the fields, how much it needs to fore you to notice and probably a half dozen other factors.
So if I place an iron, nickel, copper, wood, and other sheets above the magnets and cover the superconductor with the same then it would move at different speeds when pushed at with constant force?
This will be pretty easy to test and verify. You don't need the superconductor setup, just the magnet.
See how many paperclips a magnet will pick up with various materials interposed.
Whose experiment is this? Yours or mine?
  • Haha
Likes DaveC426913
Mine
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
