I Do objects of different mass but same size/shape accelerate the same?
  • I
  • Thread starter Thread starter greypilgrim
    Mass Shape
To verify that bodies of different mass accelerate the same in free fall without a vacuum, they must be of the same size and shape to ensure equal drag forces. When air resistance is considered, mass influences the acceleration due to differing drag forces acting on objects of varying sizes. Newton's second law shows that drag divided by mass affects acceleration, meaning larger mass requires more drag force to maintain the same rate of fall. Consequently, objects do not fall at the same rate unless they are identical in size and shape. Understanding these principles clarifies the impact of air resistance on free fall acceleration.
greypilgrim
Hi.
I remember having learnt in school that if you'd like to verify that bodies of different mass accelerate the same in free fall, but don't have a vacuum available, the bodies should be of same size and shape (e.g. spheres).
This made sense to me back then because drag should be the same then. But if I write down Newton's 2nd law with gravitational forces and drag and divide by the mass, mass doesn't go away completely, but is still there in "drag/mass", giving rise to different accelerations.
Am I doing something wrong, or do you really need objects of different size (or shape) for them to accelerate the same?
greypilgrim said:
Hi.
You may be misremembering. When air resistance is taken into account, bodies of the same mass only fall at the same rate if they are the same size and shape.
Exactly. You would need more drag force on the object with the greater mass.
When air resistance is taken into account, objects generally do not fall at the same rate. The drag force per per unit mass is the variable in the equation.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
