Do orbits in diamagnetic materials align to external magnetic fields?
In summary, diamagnets like copper and bismuth exhibit some degree of diamagnetism due to the paired electron orbits being accelerated and braked in their orbits when exposed to external magnetic fields. However, unlike ferromagnets, the imaginary orbits do not realign in diamagnets. The orientation of the spins in diamagnetic compounds does not change.
leviterande
106
Hi, I am having a question about diamagnetism. I understand that ferromagnets realign with external magnetic fields. I know that besides diamagnets like copper, bismuth, that all matter exhibit some diamagnetism to some degree. I wonder though if these paired electron filled orbits of diamagnets realign with the external magnetic field? This seems like very simple self explained question since, how other wise diamagnetism would be formed?. But, I am not 100% sure that I understand this correct?
So , do the electron spin and electron orbits of diamagnetic materials like copper realign to magnetic fields?
Thanks
Best Regards
All materials with a magnetic moment will experience a torque in applied magnetic fields.
Do you know how diamagnetism works?
Hi, yes but diamagnets have a zero net magnetic moment, electrons are paired. still there is still a small eddy current like effect with the paired electrons left when an external magnetic field is applied so the magnetic field of an ordinary stationary magnet respells diamagnets a the paired electrons are both accelerated and braked in their orbits. Anyway, I was wondering if the imaginary orbits also realign in diamagnets just like ferromagnets. I am just not sure.
Well - a perfect diamagnet expels all external fields - i.e. a superconductor.
So the question doesn't mean anything in those terms.
Note: metals exhibit diamagnetism but the free electrons are not localized to orbitals.
I think you need to revisit the theory:
http://en.wikipedia.org/wiki/Diamagnetism#Theory
... reasonable start.
thanks, I will see :)
I am trying to understand this, as I am reading as much I can, but I have to really understand one thing first, it would be so helpful to know so with fear of getting out of topic :
The electron can only have two spins only as it orbits around the nucleous. If we apply a magnetic field on an unpaired electron (say in a non conductor so the electron is bound to the orbit), the electron spin will reorient only either up or down to the external magnetic field( and yes as it precess around the field).
Now, without external magnetic fields. since the electron orbit is basically "an external magnetic field" the electron should either always and only spin parallel or anti parallel to the orbit. Do I understand this part correctly? if my point isn't clear here is a simplified question:
An electron orbit is occurring on a plane of x,y, this electron is always and only spinning as well in the same x,y plan of the orbital regardless if the spin is up or down. So, Is the electron spin plane always the exact same as the orbit plane of the same electron?
thanks
The orientation of the spins doesn't change in diamagnetic compounds. In the simplest case, a Helium atom, the spins are paired into a singlet and the question about the orientation of the spins makes no sense. Rather under the perturbation of the magnetic field, the s-orbitals admix some contribution of functions with higher angular momentum - namely p - so that they accquire some magnetic moment.
Related to Do orbits in diamagnetic materials align to external magnetic fields?
1. How do orbits in diamagnetic materials align to external magnetic fields?
Orbits in diamagnetic materials do not align to external magnetic fields. In fact, diamagnetic materials are repelled by external magnetic fields and will orient themselves in a direction perpendicular to the field.
2. What is the difference between diamagnetic and paramagnetic materials?
Diamagnetic materials have atoms with paired electrons, which creates a net magnetic moment of zero. Paramagnetic materials have unpaired electrons, which creates a net magnetic moment and causes them to be attracted to external magnetic fields.
3. Can diamagnetic materials be magnetized?
No, diamagnetic materials cannot be magnetized. They do not have the ability to retain a magnetic field and will lose any induced magnetism once the external magnetic field is removed.
4. Do all materials exhibit diamagnetic properties?
Yes, all materials exhibit some level of diamagnetic properties. However, these properties are usually very weak and are often masked by the stronger paramagnetic or ferromagnetic properties of the material.
5. How can diamagnetism be observed in everyday life?
Diamagnetism is not usually observable in everyday life. However, some common materials that exhibit strong diamagnetic properties include bismuth, gold, and water. These materials can be levitated in a magnetic field due to their repulsion to the field.
  • Electromagnetism
  • Electromagnetism
  • Materials and Chemical Engineering
  • Electromagnetism
