Do parallel mirrors keep accelerating away from each other?
In summary: Think of a mirror light sail reflecting star light, as compared to a pair of parallel light sails.The single sail extracts only a tiny fraction of the light's energy.The pair extracts all of it in the form of kinetic energy (if none of the photons are absorbed).I just thought that was interesting.
unlimitedbacon
Lets say you have two perfectly reflective parallel mirrors in a frictionless vacuum. You fire off a beam of light between them, so that it bounces between them continuously. Do they continuously accelerate away from each other due to radiation pressure? I think the answer must be no, but I can't figure out why.
Science news on Phys.org
What makes you think they won't?
Well I don't see where the energy would be coming from. They would both be gaining kinetic energy right?
I took a shower and thought about it a little more. I guess you could pose the same question with two paddles and a ping pong ball. As each paddle accelerates, its velocity relative to the ping pong ball is reduced. So each bounce is not as hard as the last and the velocity of the paddles approaches an upper limit.
With light, though, its velocity from the perspective of each mirror would always be the same (c), right? So it seems like they would just keep accelerating forever, but that can't be right. Can it? It seems very perpetual motiony.
As light reflects from a mirror that is receding, what happens to the light's frequency and wavelength?
Ok I think I got this. Thanks for pointing me in the right direction.
Since the mirrors are moving apart, the light would be redshifted. So the faster the mirrors go, the lower the frequency and longer the wavelength. The energy of a photon is related to its frequency by E = hf (where h is the Planck constant). And its mass is related to its energy by m = E/c^2. So its effectively loosing mass with each bounce, and thus loosing momentum. For a photon moving at c, the momentum p = mc = hf/c^2 * c = hf/c. So it does kinda work the same as the ping pong ball.
Light is weird.
Likes jbriggs444
Yes, exactly.
Light is weird.
While you get the idea, your explanation is incorrect since you are using a photon mass. https://www.physicsforums.com/threads/do-photons-have-mass.511175/ on this. Photon has no rest mass and so, it cannot work the way you have described. It does, however, have momentum (and yes, a photon can have momentum but with no mass). It is this momentum that is changing in your situation, not its mass.
Zz.
Nobody has mentioned an interesting aspect of this scenario. If a photon bounces off a mirror, it transfers momentum p=2hf/c. If it bounces off parallel mirrors a large number of times, the light is redshifted to zero. In that scenario, the total energy of the photon e=hf, is transferred to kinetic energy of the mirrors.
Think of a mirror light sail reflecting star light, as compared to a pair of parallel light sails. The single sail extracts only a tiny fraction of the light's energy. The pair extracts all of it in the form of kinetic energy (if none of the photons are absorbed).
Zz.
Maybe I understand this conceptually but not mathematically. I did not think that its rest mass changes. The link says E = pc, so in the end you still get p = E/c = hf/c.
Neat. You could inject sunlight into the system by making one of them a one way mirror.
A perfectly reflecting (on one side) one-way mirror is a violation of the second law of thermodynamics.
Related to Do parallel mirrors keep accelerating away from each other?
1. How do parallel mirrors accelerate away from each other?
Parallel mirrors do not actually accelerate away from each other. It is an optical illusion caused by the reflection of light between the mirrors.
2. Why do parallel mirrors appear to accelerate away from each other?
As light bounces back and forth between the mirrors, it creates the illusion of multiple images that appear to move further away from each other.
3. Is there a limit to how far apart the mirrors can appear to be?
There is no physical limit to how far apart the mirrors can appear to be. However, at a certain point, the reflections become too faint to be seen by the human eye.
4. Do parallel mirrors always create the same illusion of acceleration?
No, the illusion of acceleration between parallel mirrors depends on the angle at which the mirrors are positioned and the distance between them. This can change the perceived acceleration or even create a different optical effect.
5. Can parallel mirrors be used to create an infinite loop?
Yes, if positioned at the right angle and distance, parallel mirrors can create an infinite loop of reflections, giving the illusion of an endless tunnel. However, this is only possible in theory as there are practical limitations to the distance and precision of the mirrors.
  • Classical Physics
  • Optics
  • Quantum Interpretations and Foundations
10K
