Do people actually attempt to solve this kind of puzzle manually?
  • Thread starter musicgold
  • Tags
    Puzzle
At this point I am stuck. Can you please help me to progress further?In summary, the conversation discusses a math problem involving finding a set of three evenly spaced square numbers. The conversation explores different approaches and techniques to solve the problem, including using algebra and Pythagorean triples. The conversation also references a book on Fermat's Last Theorem and suggests trying different combinations of numbers to solve the problem.
musicgold
304
This is not a homework problem. I was trying to solve a puzzle from a book : 536 curious problems and puzzles. Puzzle no. 199 in the attached picture.
The three terms should look like:
##2 a_1 + d , ~~ 2 a_1 + 2d , ~~ 2a_1 + 3d ##
After trying a few combinations of a1 and d, I looked up the answer and the anwer was: 482, 3362, 6242, where d is 2880.
After seeing such a complicated answer a few questions popped into my head:
1. Could someone have actually manually worked this puzzle out or did the author just ran a simulation to find such unique facts to create a puzzle?
2. Did people in the time before logarithms actually attempt to solve such problems? If yes, how would they go about it?
P.S. I have read a book on Fermat's Last Theorem and know that people did work for years and years on such problems, but would love to get some additional perspective. It would be great if you could refer me to a book or site that discusses such ideas.
Thanks
In general, if you are thinking "three elements of an arithmetic series" start with a-b, a, a +b. Now your squares are 2a - b, 2a and 2a + b. a is even. I'd start from there.
The book was published after logarithms were invented. How do i know? It's not written in Shakespearean English.
Likes DaveE and Keith_McClary
Let me add that I have done this problem now. Yes, my starting point will get you there, but the path is not short or pretty or terribly enlightening. Lots of algebra - you can't be afraid to dive right in and you can't be afraid to change variables. Twice.
Forsooth!
As a final PS, there are multiple solutions, e.g. 4562, 20402, and 36242, with square roots of pairwise sums of 158, 202 and 238.
My favorite solution is 2,2,2.
Likes jim mcnamara and phinds
How did you know a is even?
If 2a is a perfect square, a must contain the other factor of 2 and thus be even.
Likes DaveE
And, just for fun,
Prove or find a counterexample that every number that forms a solution ends in 2.
Forsooth!
Lots of algebra - that was my main problem in the first place; I couldn't think of any algebraic technique to tackle this problem. All I could do was to try various combinations a and b, that too using a calculator.
Could you give me more hints?
Thanks
Substitute. p2+q2 and 2pq might have some utility.
Thanks
Here are some ideas. What we are looking for is three evenly spaced numbers that are all squares. It's not hard to see that ##1, 25, 49## satisfies this. But, the problem is set up so that the middle number is ##2a## so must be even. So that one doesn't workl. A quick check shows that there doesn't appear to be a small solution with the middle number even. So, let's use some algebra.
Let the middle number be ##n^2##, the large number be ##(n + m)^2## and the lower number be ##[n - (m + r)]^2##. It's an exercise for you to explain why we have ##m + r## here. How do I know this number is larger than ##m##? ##r## is the key here. Note also that ##n## must be even.
Now we subtract these squares to give the common difference, which simplifies to:
##2nr - r^2 = 2m^2 + 2mr##
This equation cannot be satified if ##r## is odd. So, let's start trying some even ##r##. Over to you.
Likes etotheipi
PS The first solution I get out is ##4, 100, 196##, which corresponds to ##a = -92, d = 96##. But, the problem requires ##a \ge 0##, so that criterion needs to be included somewhere.
Likes etotheipi
If the three numbers are [itex]A - d, A, A + d[/itex] then the pairwise sums are [itex]2A - d, 2A, 2A + d[/itex]. We can set [itex]2A = k^2[/itex] and [tex]
\begin{align*}
2A - d &= (p - q)^2, \\
2A + d &= (p + q)^2.
\end{align*}
[/tex] Now because the difference between [itex]2A + d[/itex] and [itex]2A - d[/itex] is even, we have that [itex](p +q)^2[/itex] and [itex](p - q)^2[/itex] and hence [itex]p + q[/itex] and [itex]p - q[/itex] themselves are either both even or both odd. It follows that their sum ([itex]2p[/itex]) and difference ([itex]2q[/itex]) are both even, so [itex]p[/itex] and [itex]q[/itex] are integers with [itex]p > q[/itex].
Subtracting these yields [itex]d = 2pq[/itex]. Both of these equations then reduce to [tex]
k^2 = p^2 + q^2.[/tex] If [itex]A - d > 0[/itex] then [tex]
p^2 + q^2 > 4pq[/tex] which will be satisfied if [itex]p > 4q[/itex]. So the problem is to find a pythagorean triple [itex](q, p ,k)[/itex] with [itex]p > 4q[/itex] and [itex]k[/itex] even. (If we find one with [itex]k[/itex] odd, then we can use [itex](2q, 2p, 2k)[/itex].)
Likes etotheipi and PeroK
I am still stuck. Here is my attempt:
Let the three numbers be ## A−d, ~ A, ~A+d ## then their pairwise sums are
## 2A−d, ~ 2A, ~ 2A+d ##.
Let's assume that the three square numbers are ## p^2, ~ k^2, ~ q^2 ##, respectively.
Then I used ## A = \frac {k^2} {2} ## to get the following values of ##d##.
## d = k^2 - p^2##
## d = q^2 - k^2##
Equating the two values of d gave me
## q^2 +p^2 = 2 k^2##
Adding ##pq ## terms on both sides to get perfect squares, we get
## (q+p)^2 = 2k^2 + 2 pq ##
## (q-p)^2 = 2k^2 - 2pq##
I don't know how to proceed from here to be able to guess A and d.
I see that my solution is very similar to to that of pasmith, but I don't follow how he is assuming ##d = 2pq##.
Thanks
You're struggling because your plan to solve this is not a good one. You have two equations in three unknowns, and the solutions are integers. Your plan is to try and solve two equations in three unknowns, ignoring the fact that the numbers are integers, and hoping that when the numbers pop out - which they won't (2 equations, 3 unknowns - they will be integers.
This is not a good plan.
Likes musicgold
pasmith, could you explain me how you can make the following assumption?
pasmith said:
[tex]
\begin{align*}
\end{align*}
[/tex]
You can always write two numbers A and B as p + q and p - q.
But you're back to your same non-working plan.
2,2,2
482, 3362, 6242
4562, 20402, 36242
39042, 272322, 505602
are all solutions. Indeed, there are an infinite number of solutions. So you're plan of having two equations in three unknowns miraculously popping out a solution is not a good one. Nor is hoping for a second miracle that the number is an integer.
The path you are on will not take you to a solution no matter how hard you work at it. You need another one.
Likes musicgold
I think this problem is quite hard. You might like first to try the easier problem I posted in post #10 just to find an equation for all squares in an arithmetic progression. That was my approach, although I didn't find a way to filter my solutions to the ones that fit this problem. But, in a way, it's a nicer problem to find them all.
Likes musicgold
[itex]2A - d[/itex] and [itex]2A + d[/itex] are required to be squares. So set [itex]2A - d = a^2[/itex] and [itex]2A + d = b^2[/itex]. Subtracting one from the other gives [tex]2d = b^2 - a^2 = (b + a)(b - a).[/tex] Now at least one of [itex]b - a[/itex] and [itex]b + a[/itex] is even (because the product is even), which means that the other is also (because [itex]b + a = (b - a) + 2a[/itex]). Hence we may set [tex]2q = b - a, \qquad 2p = b + a[/tex] so that [tex]a = p - q, \qquad b = p + q.[/tex]
Likes musicgold, etotheipi and PeroK
Can you please point me to a webpage or book where I can read more on the approach you are using?
Two questions:
1. If the pairwise sums are equidistant from each other on the number line, why are we assuming a strange term like ## (m + r)## in defining them? Is this kind of shortcut to simplify calculations?
2. I am able to reach up to this step: ##2nr - r^2 = 2m^2 + 2mr##. However, again, I don't know how to proceed from here. Now I have 3 variables to guess: n, m and r. In my initial brute force approach, I was dealing with only two variables - the initial term and the difference d. What am I missing?
Thanks for bearing with me.
musicgold said:
Two questions:
1. Take an example like ##1, 25, 49## which is ##1^2, 5^2, 7^2##. The difference between the larger pair ##7 - 5## must be greater than the difference in the smaller pair ##5 - 1##. In this case ##n = 5, m = 2## and ##r=2##.
You can show this in general. Suppose we have ##a^2, b^2, c^2##, then ##c^2 - b^2 = (c-b)(c+b) = b^2 - a^2 = (b-a)(b+a)##. We know that ##c + b > b + a##, so we must have ##c - b < b - a##.
2. Now you have all the solutions. It's not a question of brute force. You can choose almost any ##r, m## and you get a solution for ##n##. Note that ##r## must be even. There are an infinite number of them. For example:
##r = 2, m = 1## gives ##1, 25, 49##
##r = 2, m = 2## gives ##7, 13, 17##
And you can generate as many as you want.
Note: unfortunately, I can't see a way to restrict this full set to just the ones we want for the given problem.
Likes musicgold
There is only so much floundering one can stand.
With sufficient substitution, one can determine the sequence is [itex](p^2+q^2)^2/2[/itex] +/- or 0 [itex]4pq(p^2-q^2)[/itex] with p and q being positive integers, either both even or both odd. Without loss of generality, p > q.
We want all three terms to be non-negative, so [itex](p^2+q^2)^2 > 8pq(p^2-q^2)[/itex]
OK, so what's the smallest q can be? One.
Can p be 3? No, [itex](p^2+q^2)^2 < 8pq(p^2-q^2)[/itex]
5? Same problem. 7? Same problem. 9 works. That gives us 482-3362-6242
From here, we can keep plugging in: each value of p gives a new sequence: 2162-7442-1272 for 11, then 5714-14450-23186 for 13, etc.
Next smallest? Two.
Then the smallest q can be is 16, and that gets us 1544-33800-66056. Eighteen gets us 7712-53792-99872, and so on forever.
Next smallest? Three.
The first q that works is 23, for 1202-144722-288242.
This is a way to systematically generate as many solutions as one wants.
Likes musicgold
Next smallest? Two.
Thank you. Happy Teacher's Day to all my teachers.
Related to Do people actually attempt to solve this kind of puzzle manually?
1. What is the purpose of manually solving puzzles in the field of science?
The purpose of manually solving puzzles in the field of science is to develop problem-solving skills, improve critical thinking abilities, and gain a deeper understanding of the underlying principles and concepts involved in the puzzle. It also allows scientists to test and refine their theories and hypotheses through hands-on experimentation.
2. How do scientists determine which puzzles to solve manually?
Scientists typically choose puzzles that are relevant to their field of study or research interests. They may also select puzzles that have practical applications or can help them understand complex systems or phenomena.
3. Is manual puzzle solving still relevant in the age of advanced technology?
Yes, manual puzzle solving is still relevant in the age of advanced technology. While technology can assist in solving puzzles more efficiently, manual solving allows for a deeper understanding of the problem and can often lead to more creative solutions.
4. What are some common techniques used in manual puzzle solving?
Some common techniques used in manual puzzle solving include trial and error, deductive reasoning, and breaking the problem down into smaller, more manageable parts. Scientists may also use visual aids, such as diagrams or models, to help them solve the puzzle.
5. How can manual puzzle solving benefit scientific research?
Manual puzzle solving can benefit scientific research by fostering critical thinking skills, promoting collaboration and teamwork, and providing a hands-on approach to testing theories and hypotheses. It can also lead to new discoveries and insights that may not have been possible with technology alone.
  • STEM Academic Advising
  • General Discussion
  • STEM Educators and Teaching
  • Science and Math Textbooks
