Do perfect squares exist in physics?
In summary, the conversation discussed the presence of perfect squares and 90 degree angles in nature. The question was raised if these shapes are only made up by mankind or if they also exist in physics. The discussion explored various examples such as crystal structures and the relationship between electric and magnetic fields in an electromagnetic wave. The concept of emergence and the use of geometry and mathematics to model nature were also mentioned. The conversation concluded with the suggestion to google for images of electromagnetic waves and the Lorentz force to further understand the concept of right angles in nature.
mare veen
Hello, I am a visual artist and currently working on a project about ‘being’. Under the assumption that ‘being’ or ‘to be’ is never square I was wondering if in physics (or astronomy/cosmology/biology etc) perfect squares or 90degrees corners exist. Isn't a square and perfect 90degrees corner only made up by mankind or is it also present in physics?
Anyone out there who can help me? Thank you!
fresh_42 said:
Here's another one: https://en.wikipedia.org/wiki/Halite
And do the mathematical models which involve squared distances count?
Thank you! I’m mainly in search of visual/imaging proof.
Geometry and mathematics in general are used to model nature. Whether mathematics itself is natural or invented is an often debated question that probably has no definite answer. You could, in fact, have a similar debate about whether physics is discovered or invented. But that's more the philosophy of science than science itself.
One example of a right angle in nature is the relationship between the electric and magnetic fields in a light wave. Theoretically, at least, they are at right angles to each other.
Also, the magnetic force on a charged particle is at right angles to its velocity.
Likes fresh_42
Thank you so much PeroK. Do you have an image or wikipedia site that hows this? Sorry, a bit new to the subject.
If you google for "electromagnetic wave" and "lorentz force" and see what images come up.
Thanks!
The regular geometric patterns such as circles, lines and hexagons that emerge in nature are termed "emergent properties". https://en.wikipedia.org/wiki/Emergence
Crystal structure is probably the best example which explains why they are given mystical properties by the new age. https://en.wikipedia.org/wiki/Crystal_structure
Most people use common salt, (NaCl), every day, but they do not realize the cubic perfection.
https://en.wikipedia.org/wiki/Sodium_chloride
https://en.wikipedia.org/wiki/Crystal_structure#Prediction_of_structure
There are also some macro properties where right angles can be seen. For example, if you suspend a weight on a long thread or hair, the thread will form a right angle with the horizon. Gravity works to produce two situations that are orthogonal, one hanging vertical on a thread, the other being the horizontal surface of a liquid.
FAQ: Do perfect squares exist in physics?
1. What are perfect squares?
Perfect squares are numbers that can be expressed as the product of two equal integers, such as 4 (2 x 2) or 25 (5 x 5). In other words, a perfect square is the result of multiplying a number by itself.
2. Do perfect squares exist in physics?
Yes, perfect squares exist in physics. In fact, they are used to describe many natural phenomena, such as the energy levels of an atom or the distance traveled by an object in free fall. They are also commonly used in mathematical equations to represent physical quantities.
3. How are perfect squares used in physics?
Perfect squares are used in physics to simplify and solve mathematical equations. They also have practical applications in measuring and describing physical quantities, such as distance, time, and energy.
4. Can perfect squares be negative numbers in physics?
No, perfect squares cannot be negative numbers in physics. In order for a number to be a perfect square, it must have a non-negative square root. Therefore, perfect squares are always positive numbers in physics.
5. Are there any famous examples of perfect squares in physics?
One famous example of a perfect square in physics is the square of the speed of light in a vacuum, which is equal to the value of the physical constant c. Another example is the Planck's constant, which is the square of the reduced Planck's constant, also known as the Dirac constant.
