Do Photons Gain Infinite Mass at Light Speed?
In summary, the mass of light, or photons, is extremely small and nearly negligible. Photons are considered to be massless particles as they travel at the speed of light and have no rest mass. This is due to the fact that photons have no physical size or volume and are composed solely of energy. The energy of a photon is directly proportional to its frequency, meaning that higher frequency photons have more energy and lower frequency photons have less energy. While the mass of light may seem insignificant, it plays a crucial role in understanding the behavior of light and is a fundamental concept in the field of physics.
  • #36
nakurusil said:
Yes, I know that.
no, you're saying something else.
[itex]\mu_0[/itex] has had a defined value long before c did. [itex]\mu_0[/itex] gets its defined value from how they defined the SI unit of current (the Ampere) which, along with the SI unit of time, defines the SI unit charge. don't know if it was Faraday or Boyle or Coulomb or who it was that first measured the inverse-square nature of the electrostatic force, but i imagine that they may have had a crude measured value for [itex]\epsilon_0[/itex]. presumably with Maxwell, they got to relate [itex]\epsilon_0[/itex] and [itex]\mu_0[/itex] to c which was measured independently (i presume by the likes of Michaelson) and offered both experimental confirmation of the unified E&M theory of Maxwell, but also offered a better value for [itex]\epsilon_0[/itex] since they can relate it to the defined [itex]\mu_0[/itex] and a more accurately measured c. but c was still measured, in terms of the existing meter and second. until they redefined it in 1960 and 1983. they defined the meter in terms of c as they did so that the length of the new definition agreed, as well as they could determine at the time, with the length of the old definition. it's possible now that the distance between those two little scratch marks in the prototype meter bar is measured (using the present definition of the meter) to be something slightly different than a meter (present definition). i would chalk that one up to experimental error or advancement of metrology since 1983 rather than to a change in the speed of light since 1983.
but [itex]\mu_0[/itex] did not magically come out to be [itex]\mu_0 = 4 \pi \cdot 10^{-7}[/itex] because of how they defined c (or the meter, however you wish to put it).
some of this might be semantic, but you are objectively mistaken to say that [itex]\mu_0 = 4 \pi \cdot 10^{-7}[/itex] because of how they defined c. that's just incorrect.
  • #37
nakurusil said:
You missed the point , entirely. I reacted to MeJennifer's statement that said textually c is a constant because...
lessee...
MeJennifer said:
MeJennifer said:
Actually the reason c is a constant has to do with how the meter is defined.
you said:
nakurusil said:
[tex]\mu_0[/tex] value is chosen such that [tex]1/\sqrt(\epsilon_0 \mu_0)=299,...[/tex]
i'm placing my bets with MeJennifer.
  • #38
duordi said:
Interestingly C was defined by definition in 1983.
Permittivity (E)of free space is defined by C and the Maxwell equations.
Permeability (u) is measured.
oh, i missed this! this is where the evil misconception started. most certainly the Permeability of Free Space [tex]\mu_0[/tex] is not measured, but defined as a consequence of the definition of the unit of electrical current, the Ampere.
  • #39
Can't someone get ahold of the latest CODATA and figure out how these values were obtained?
Zz.
  • #40
what do you mean, Z? the stuff at NIST: http://www.physics.nist.gov/cuu/ reflects the CODATA values but [itex]c, \epsilon_0, \mu_0, Z_0[/itex] are not CODATA measured values. they are defined in SI. I'm sure you know that, Z. but I'm not sure what you're asking for here.
  • #41
jtbell said:
If at some point the speed of light is shown not to be constant, then the definition of the meter will surely be changed to reflect this.
JT, how would we ever know if the speed of light is changing? what would be the standard against which we measure the speed of light? when we measure anything, ultimately what we have are dimensionless quantities that we conceptually attach dimensionful units to. but since these dimensionless quantities are ratios of like-dimensioned physical quantities, if this ratio changes, how would one know which of the like-dimensioned physical quantities to attribute this change to?
  • #42
rbj said:
lessee...
MeJennifer said:
You are still missing the point. I give up, not worth it.
  • #43
what duordi said and you confirmed and reiterated is factually incorrect (about the permeability [itex]\mu_0[/itex]).
what MeJennifer said is factually correct.
whatever your point is, i guess i did miss it.
  • #44
NOT. Or maybe you think it is correct?
  • #45
Here is the http://www.physics.nist.gov/cuu/Units/meter.html"
NIST said:
The meter is the length of the path traveled by light in vacuum during a time interval of 1/299 792 458 of a second.
Furthemore from the same page:
NIST said:
Note that the effect of this definition is to fix the speed of light in vacuum at exactly 299 792 458 m·s-1.
  • #46
Yes, the sentence means that it makes c equal to the specific value of 299,... Do you understand the difference between that and making c a constant?
c is a constant for profound physical reasons, not because of the definition of the meter. You don't simply make c a constant
  • #47
while we're at it, here it is for the Ampere:
The ampere is that constant current which, if maintained in two straight parallel conductors of infinite length, of negligible circular cross section, and placed 1 meter apart in vacuum, would produce between these conductors a force equal to [itex]2 \times 10^{-7} [/itex] Newton per meter of length.
The expression "MKS unit of force" which occurs in the original text has been replaced here by "Newton," the name adopted for this unit by the 9th CGPM (1948). Note that the effect of this definition is to fix the magnetic constant (permeability of vacuum) at exactly [itex]\mu_0 = 4 \pi \times 10^{-7} H \cdot m^{-1} [/itex].
  • #48
It seems that you rather deny the reality of certain things than admit you are wrong. :smile:
  • #49
c is a constant for physical reasons, not because of the definition of the meter. You don't simply make c a constant
if it changed, how would we meaningfully measure it? you might want to read some stuff from Michael Duff http://www.arxiv.org/abs/hep-th/0208093 or http://xxx.lanl.gov/abs/physics/0110060 or just check out the Physical constants or Planck units articles at Wikipedia.
here's a good quote from John Barrow:
[An] important lesson we learn from the way that pure numbers like [itex]\alpha[/itex] define the world is what it really means for worlds to be different. The pure number we call the fine structure constant and denote by [itex]\alpha[/itex] is a combination of the electron charge, e, the speed of light, c, and Planck's constant, h. At first we might be tempted to think that a world in which the speed of light was slower would be a different world. But this would be a mistake. If c, h, and e were all changed so that the values they have in metric (or any other) units were different when we looked them up in our tables of physical constants, but the value of [itex]\alpha[/itex] remained the same, this new world would be observationally indistinguishable from our world. The only thing that counts in the definition of worlds are the values of the dimensionless constants of Nature. If all masses were doubled in value [including the Planck mass mP ] you cannot tell because all the pure numbers defined by the ratios of any pair of masses are unchanged.
you see, whether it is c, h, G, or e, it's not really meaningful to consider the changing of any of these dimensionful physical constants. it's only the dimensionless physical "constants" that mean anything (have "operational distiguishability") if they changed.
still, MeJennifer had it right and, doggedly you have been holding on to your guns, you did not.
  • #50
Who's talking about changing? What exactly do you understand in the post that you just quoted?
Where am I talking about changing? Where did you see that in ANY of my posts?
  • #51
You didn't answer my question, can you try?
How does the meter definition make c a constant? (when c is constant to begin with due to multiple physical reasons). Please try to answer the question without a personal attack, ok?
  • #52
You are giving yourself a distinct impression of trolling.
  • #53
For the second time, please try answering without a personal attack. It is a very simple question. You made a statement, I think that it is incorrect, try to defend it.
  • #54
In the interest of our member's valuable time I rather suggest that a moderator close this topic, enough is enough.
  • #55
what you said is
by "specific value of 299,..." i am presuming you meant "specific value of 299792458 m/s". the fact is, by the very definition of the meter (post 1983), that's what they did. given that means of defining what a meter is, the dimensionful value of 299792458 m/s can be nothing else. now, perhaps that was a bad definition for the meter. it sure as hell would have been bad if they defined the meter to be the distance sound travels in air at STP in 1/(331.5) second. but they're more confident about the stability and repeatability of the speed of propagation of E&M waves.
i think i have a feel for why the speed of E&M propagation should be the same for all inertial reference frames. don't know if it is "profound" or not, but the contrary leads to problems. don't know of this is how Einstein would put it but it's how i gleaned it from the some of the words of Einstein. it really just comes from Maxwell's Eqs. and the knowledge (verified by the "negative" outcome of the Michaelson-Morley experiment) that there is no ether medium that E&M is propagated in.
consider the propagation of sound, for instance. if the wind is steady and blowing across your face at some velocity [itex]v[/itex] from left to right and you measure the speed of some sound coming from your left, you will measure it to be [itex]2v[/itex] faster than if it came from your right. that is because you are moving relative to the "ether" (air) medium that carries the sound wave. but there is no such medium for light or any other E&M wave.
so then, how do we tell the difference between a moving vacuum and a stationary vacuum? if we can't, if there really is no difference between a moving vacuum and a stationary vacuum, that such a concept is really meaningless, then whether the light that you are measuring originated from a flashlight mounted on a rocket moving past you at [itex] c/2 [/itex] or from a stationary (relative to you) flashlight, how does that change the fact that this changing E field is causing a changing B field which is causing a changing E field which is causing a changing B field which is causing a changing E field, etc.? that propagation of an E field and B field disturbance, which has velocity [tex] 1/ \sqrt{ \epsilon_0 \mu_0 } [/tex]? how is it different for you or for the observer that is traveling along with the flashlight at [itex] c/2 [/itex]? whether you are holding the flashlight or moving past it at high velocity, Maxwell's Eqs. say the same thing regarding the nature of E&M in the vacuum and you will both measure the speed of that propagation to be [tex] 1/ \sqrt{ \epsilon_0 \mu_0 } [/tex].
so that might be the "profound" reasons for choosing the definition of the meter in terms of c as they did, but given that definition of a meter, the speed of light cannot come out to be anything different. there is nothing more profound about it (or that of any dimensionful universal "constant") which is why we should all be dubious of either renowned researchers or of crackpots making claims of changing c or G or whatever. we got to just ask "how would we even measure or perceive such a change in the first place?"
  • #56
Go RBJ
I would choose to defend RBJ.
The difference in your approaches have to do with definitions created by humans versus physical reality.
Yes C is defined technically by standards of time and length by humans.
Physical reality doesn't care spit about our standards.
If C is a constant then C is a constant regardless what our definitions say.
It is impossible to contemplate variation in the speed of light if we cling to the definitions commonly used because they consider the speed of light a constant.
Einstein and Maxwell cut their own path and RBJ should be allowed to do the same if he so chooses.
By the way if all matter in the universe doubled the universe may go from open to closed.
It would that is not undetectable.
  • #57
rbj said:
what you said is
I never imagined that such a straightforward issue can get so messed up.
Let me try one more time: my contention to MeJennifer post is that it is not the "definition of the meter that makes c a constant".
1. c was known to be a constant long before 1983 when the current definition of the meter was coined out. We all know why c is a constant, we all know all the experimental confirmations and the mess we would be in if it weren't (as a parens, I never brought in any isue about changing c, so I do not understand your persistance in bringing it in in your posts)
2. So , we all violently agree that c is a constant, ok?
3. The re-definition of the meter in 1983 simply assigned the value of precisely 299792458 m/s to the constant. Did not make c a constant, c was already known to be a constant for about 80 years.
An interesting question is how did the metrologists arrive to the 299792458 number. Do you know?
  • #58
antariksh said:
Just a thought, according to Einsteins relativity mass changes with speed and tends to become infnite as it approaches 'c'. Since photons too have mass, why doesn't their mass become infinite since they travel at c?
I'm not sure whether your question was answered to your satisfaction so let me take a crack at it.
The (relativistic/inertial) mass of a particle is the m in mv where v is the velocity of the particle and the vector quantity p = mv is conserved. This quantity is called the momentum of the particle. So mass is defined so that momentum is conserved in all frames of reference. Since a photon has momentum it has inertial mass. The value of its intrinsic mass (aka "proper mass") is zero.
Pete
  • #59
photon
Pete
Hi Pete. Nice to find you on the Forum.
Is it wrong to say that in the case of the tardyon, momentum and mass transform in such a way that p/m=u and p'/m'=u' ,u and u' being related by the addition law of relativistic velocities and so mass and momentum transform via different transformation factors. In the case of the photon
we should have for the same reasons p/m=p'/m'=c momentum and mass transforming via the same transformation factor which happens to be the Doppler factor. Has the conservation some relevance in that case?
  • #60
Why not? By the very definition of relativistiv mass, m, p = mv in every inertial frame. This, i.e. "m" is just the time component of the 4-momentum of the particle.
In the case of the photon we should have for the same reasons p/m=p'/m'=c ...
Which is exactly what you'd find if you calcluate it.
..momentum and mass transforming via the same transformation factor which happens to be the Doppler factor. Has the conservation some relevance in that case?
Not that I'm aware of.
Pete
  • #61
By the way, its nice to find you still posting here too Bernhard. I'm not sure how long I'll be here but I don't think there will be anymore conflicts with myself and the moderator.
Pete
  • #62
well, if all of the physical mass in the universe doubled and the Planck Mass did not, certainly an important dimensionless property of the universe changed. but if the mass all of the objects/particles of the universe and the Planck Mass doubled, i don't think that would be detectable.
but there are people (Duff sites Paul Davies among others) of repute that do not agree that it must be and even that it is decreasing. the wiki VSL article says something about what the proponents of VSL would claim are detectable. and my question about that is how they would measure that? Duff is making a statement that not only is the notion of a sole varying dimensionful constant changing untrue, but is meaningless.
yeah, but the one i like is [itex] 1 l_P/t_P [/itex].
not that value, no. i think Foucault measured it to be about 298xxxxxx m/s. I'm looking at an old (pre-1983) textbooks and CRC Handbook and it lists c as 2998xxxxx m/s or 2997925xx m/s. now that might be due to rounding, but i know that pre-1960 (when the meter was a platinum-iridium bar) there have been adjusted values to the measured c (there would have to be better increasing accuracy in the measurement).
An interesting question is how did the metrologists arrive to the 299792458 number? Do you know?
i remember reading somewhere from NIST, perhaps http://www.mel.nist.gov/div821/museum/timeline.htm , that when the make a change in definition of a unit, they do it so, given the existing measurement of some previously un-fixed quantity, that the numerical value they pick in the new definition will leave that value unchanged. so probably, the expectation value from the most recent measurements was between 299792457.5 m/s and 299792458.5 m/s and they decided to round it to the nearest integer m/s and carve it into stone.
  • #63
Totally irrelevant in our discussion. Could you please stick to the point, this repeated diversion contributes nothing.
Again, you are missing the point. The point is that the whole action merely assigned a value to the constant . Did not make c constant as per MeJennifer's claim. This has been the discussion for the last 20 posts. Can we agree on this and end it?
  • #64
bull****. you made a point (number 1) that you are using to support what you claim, and i added qualification to it rather than to assent to it unqualified.
do you know how apply forensic principles to an argument you make? how to argue fairly and persuasively?
tsss. :-/
no, you are making a case based on assumptions some that are either not completely correct without qualification and i am calling you on that.
whether or not it has been discussed in the past 20 post, your statement is wrong. the measured value of c was not constant until they defined it so. now, if you believe that this is only due to different measurement errors in various measurements over time (which i think you do and it is also what i think) then you can say simply that, that these non-constant c values are due to measurement error (that is now precluded by the current definition but was not precluded by the pre-1960 definition) of a principly constant value. but some people do not think it is constant in principle and even claim they have evidence which indicates it is not constant. in other words, they disagree with Einstein, the correctness of whom you are using as a basis for your argument.
but when they redefined the meter, particularly in 1983, in terms of the meter as so defined, that did make c constant. the definition of the meter is the cause, the fact that c is constant m/s is the effect. MeJ was correct, you are not.
rather than cheaply say "oh! you are missing the point! lest you have to defend some of what you say, why not defend it or concede it or just drop it?
  • #65
Yes, I know. I also know an attempt to diversion when I see one.
So, did the assignment of the value 299,etc. to the constant representing c "make c constant"? A simple yes or no suffices.
  • #66
Let me make it easier for you, I asked Tom Roberts what happened in 1983, he's old enough and experienced enough, here is what he answered: they got together and they voted on the value to choose based on the results of the latest experimental measurements. Then, they assigned the agreed upon value to c. In your opinion : did this action "make c a constant" , or was c already constant? A or B?
Tom confirmed another thing: how do you think that the values used in the voting process were determined? What type of meter standard was used in the measurements?
  • #67
Identical distortions
I have a suggestion regarding the relativistic gravitational equation.
I understand that you can not use relativistic mass in the Newton gravitational equation due to the distortion of space-time.
If however the distance R between two objects is measured by the same means that gravity travels to us the Newton gravitational equation may then be usable if the relativistic mass is used in place of the rest mass.
Say for instance I determine distance R by viewing a distant mass object.
The view path is curved with the gravitational field identically as it travels to me.
All space time variants which would affect gravity also affect the photon image except for the properties of the distant object at the time the image departed.
I can use this distorted view of the distant object to determine an “apparent velocity” with respect to myself and an “apparent distance” R that the object is away from me.
By using the relativistic mass to correct for distortion due to the velocity properties of the distant mass at the time of image departure and the apparent radius R along the photon image path which is distorted identically to the gravitational distortion path the exact gravitational force experienced should be determined by using the Newton gravitational Equation with relativistic mass substituted for rest mass.
The basic premise here is that a mass is dumb and responds to gravitational information as it perceives it and not based on where it "actually" is in direction distance and time.
This reasoning would indicate that if we are only interested in the gravitational forces we expereince we need not be able to calculate the distortions of time space and locate the distant masses in time space but only measure the resultant distorted properties of the photon image directly, and apply constraints to Newton’s gravitational equations which correct for the apparent velocity properties of a distant mass at the time of photon image departure to determine the actual gravitational force which will be experienced.
Your thoughts?
