Do photons interact with spacetime?
In summary, the conversation discusses how Relativity explains the behavior of light in reference frames and how photons, being massless, have the same speed in all reference frames. It is important to note that photons are not explicitly mentioned in Relativity, which is a classical theory based on the behavior of light as electromagnetic waves. Additionally, the stress-energy tensor, which is affected by all forms of energy, including light, determines the curvature of spacetime. The concept of an invariant speed, also referred to as the speed of light, is a fundamental property of spacetime.
platosuniverse
29
The way I understand this is that Relativity says space-time is like a field that's affected by the way mass moves through it. Photons are massless so is this why the speed of light is the same in all reference frames?
Spacetime is affected by everything with energy, this includes photons.
This is completely unrelated to what you wrote before.
The laws of physics are the same in all reference frames. The same speed for massless particles it the only option, everything else would make different reference frames different.
You have to be careful about mentioning relativity and photons in the same breath. There aren't any photons in relativity; it's a classical theory motivated by the behavior of light considered as classical electromagnetic waves. Thus, this thread might be off to a better start if the title were "Does light interact with spacetime?"
You also must be careful when you say that spacetime "is like" anything. Those words "is like" imply that you're making an analogy, and an analogy isn't the real thing. An analogy may help you form a mental picture, but conclusions drawn from the analogy are suspect.
But with that said... the curvature of spacetime is determined by the stress-energy tensor. Electrical and magnetic fields do contribute to the stress-energy tensor, so in that sense light does interact with spacetime.
In addition to what's been said above, it's a fundamental property of spacetime that there is an invariant speed. It turns out to follow fairly simply from that fact that "massless" and "travels at the invariant speed" are the same statement in different words. The first massless thing we discovered (before anyone understood my last sentence) was light, so the invariant speed is often called the speed of light. Arguably, that is slightly conceptually misleading.
Likes Imager
FAQ: Do photons interact with spacetime?
How do photons interact with spacetime?
Photons, as particles of light, do not have mass and therefore do not experience gravity. This means that they do not interact with spacetime in the same way that massive particles do. However, they do follow the curvature of spacetime caused by massive objects, such as stars or black holes.
Can photons be affected by gravitational lensing?
Yes, photons can be affected by gravitational lensing, which is the bending of light by the gravitational pull of massive objects. This effect was first predicted by Einstein's theory of general relativity and has been observed in many astronomical phenomena.
Do photons contribute to the expansion of the universe?
No, photons do not contribute to the expansion of the universe. In fact, the expansion of the universe is driven by dark energy, which is a mysterious force that acts opposite to gravity and causes the universe to accelerate its expansion. Photons, being massless particles, do not have any effect on this expansion.
How do photons travel through curved spacetime?
Photons travel in a straight line through spacetime, but due to the curvature caused by massive objects, their path appears to be bent. This is similar to how a straight line on a curved surface, such as a sphere, appears to be curved when viewed from a distance.
Do photons slow down when passing through a gravitational field?
No, photons always travel at the speed of light, regardless of the gravitational field they are passing through. This is one of the fundamental principles of special relativity. However, their path may appear to be curved due to the effects of gravity, as mentioned earlier.
