Do photons that carry orbital angular momentum have mass?
In summary: But it's not at all clear that the same thing happens in the quantum world, where the wave function is not a pointlike object.In summary, the mass of a helical structure is not zero.
calinvass
159
It is known that particles with rest mass cannot travel at the speed of light.
Can we also say that particles that travel at subliminal velocity, like these OAM photons do, have mass?
It has been demonstrated [1] that these beams can be thought as made of photons that posses intrinsic OAM, and can be seen as 1/2 spin particles.
We know that all fermions which are 1/2 spin particles have mass.
At first I thought that it was straight forward that they have mass, but then I've realized this may not be a general opinion and I've decided to ask.
http://physicsworld.com/cws/article...ngular-momentum-are-the-latest-twist-on-light [1].
These photons are not "particles" in the sense that you are thinking of that term. So the correct answer to your question is "mu"--the question is not well posed to begin with.
This happens to be correct (now that we believe neutrinos have mass), but there is no necessary connection between fermions and having mass; massless fermions are perfectly consistent theoretically (and up until fairly recently we thought neutrinos were such massless fermions, and that caused no theoretical problem at all).
Btw, the full text of the actual paper is here:
http://advances.sciencemag.org/content/2/4/e1501748.full
PeterDonis said:
These photons are not "particles" in the sense that you are thinking of that term. So the correct answer to your question is "mu"--the question is not well posed to ...
The mass of a proton is greater than the mass of its quarks constituents but protons are complex systems, not particles. If helical structures are not particles then, can the same thing happen to these structures? Can we say that the mass of the helical structure is not zero?
What are "helical structures"?
calinvass said:
The term appears in the first figure, on introduction.
Ok, so "helical structures" is just another word for "the spatial part of the photon wave function". But the spatial part is just part of the photon wavefunction, and it's not meaningful to ask whether it, by itself, can contribute to the mass of a system containing many photons. You have to look at the whole wave function.
In fact, even looking at the whole wave function might not be meaningful in this context. Protons as composite systems have a significant contribution to their mass from the interaction energy of the strong interaction between the quarks. There is no way to make a composite system out of photons that has that property. The examples of composite systems of photons having nonzero invariant mass are classical: you can have systems containing multiple photons whose total invariant mass is not zero (because invariant mass is not additive; what is additive is 4-momentum, and multiple null 4-momentum vectors can add to a total 4-momentum vector that is not null).
Likes bhobba and calinvass
FAQ: Do photons that carry orbital angular momentum have mass?
1. Do photons that carry orbital angular momentum have mass?
According to the Standard Model of particle physics, photons are massless particles. However, recent research suggests that photons with orbital angular momentum may have a very small amount of mass due to their motion in a curved trajectory.
2. How is orbital angular momentum different from spin angular momentum?
Orbital angular momentum refers to the rotational motion of a particle around an external axis, while spin angular momentum is the intrinsic angular momentum of a particle. Photons can have both orbital and spin angular momentum.
3. Can photons lose or gain orbital angular momentum?
Yes, photons can gain or lose orbital angular momentum through interactions with other particles or through changes in their trajectory. This can be observed in experiments involving lasers and optical tweezers.
4. What are the applications of photons with orbital angular momentum?
Photons with orbital angular momentum have potential applications in optical communications, quantum computing, and imaging techniques. They can also be used in optical trapping and manipulation of small particles.
5. How are photons with orbital angular momentum generated?
There are various methods for generating photons with orbital angular momentum, including using specialized optical elements, holographic techniques, and nonlinear optics. These methods can create photons with different orbital angular momentum states, also known as modes.
